priya Posted May 25, 2008 Share Posted May 25, 2008 (edited) Hi guys! I am planning to service my Turbo. A CT9. What parts are to be replaced, since I saw there is oil coming up to the Intercooler ? Could you recommend a PRO. to check this..Anyone have this problem? Pls advice. cheers Edited May 25, 2008 by priya Quote Link to comment Share on other sites More sharing options...
madmax Posted May 25, 2008 Share Posted May 25, 2008 priya said: Hi guys! I am planning to service my Turbo. A CT9. What parts are to be replaced, since I saw there is oil coming up to the Intercooler ? Could you recommend a PRO. to check this..Anyone have this problem? Pls advice. cheers Sacha or Nadeera. Quote Link to comment Share on other sites More sharing options...
GihanFX Posted May 25, 2008 Share Posted May 25, 2008 (edited) priya said: Hi guys! I am planning to service my Turbo. A CT9. What parts are to be replaced, since I saw there is oil coming up to the Intercooler ? Could you recommend a PRO. to check this..Anyone have this problem? Pls advice. cheers According to my Knowledge from breather little bit of oil goes to intake and though the turbo goes to the IC, but if more oil coming that means some isue with the Engine or Turbo, Sometimes when the Turbo leaks, oil go through the Turbo cold side to the IC or through the Turbo Hot side to the Exhaust and then u can see bit smoke coming from the Exhaust, If something wrong with the Engine internals (piston play, etc) then oil may go to the Inlet through Breather line, Another thing as i know if u put more engine oil than recomend then oil may go to the inlet through Breather, and if u have VTA type BOV then some oil also comes from the BOV too but if u have the Stock React Type then u cant see cus that oil also go back to the Intake But if u have some tools its easy to remove intercooler and All the pipes of the intake, then wash all those parts using petrol and fill Petrol in to the Intercooler and wash it too, then fix all those and Run the car for like one or two month, again remove and see if there's lods of Oil, if thers oil Take the car to Nilantha, Nadeera or Sacha Edited May 25, 2008 by GihanFX Quote Link to comment Share on other sites More sharing options...
priya Posted May 25, 2008 Author Share Posted May 25, 2008 GihanFX said: According to my Knowledge from breather little bit of oil goes to intake and though the turbo goes to the IC, but if more oil coming that means some isue with the Engine or Turbo, Sometimes when the Turbo leaks, oil go through the Turbo cold side to the IC or through the Turbo Hot side to the Exhaust and then u can see bit smoke coming from the Exhaust, If something wrong with the Engine internals (piston play, etc) then oil may go to the Inlet through Breather line, Another thing as i know if u put more engine oil than recomend then oil may go to the inlet through Breather, and if u have VTA type BOV then some oil also comes from the BOV too but if u have the Stock React Type then u cant see cus that oil also go back to the Intake But if u have some tools its easy to remove intercooler and All the pipes of the intake, then wash all those parts using petrol and fill Petrol in to the Intercooler and wash it too, then fix all those and Run the car for like one or two month, again remove and see if there's lods of Oil, if thers oil Take the car to Nilantha, Nadeera or Sacha Muchung any idea whos is closest to me? Quote Link to comment Share on other sites More sharing options...
Nuwan B4 Posted May 26, 2008 Share Posted May 26, 2008 priya said: Muchung any idea whos is closest to me? Where are you from machan? Quote Link to comment Share on other sites More sharing options...
priya Posted May 26, 2008 Author Share Posted May 26, 2008 (edited) Nuwan B4 said: Where are you from machan? Near Kelaniya Temple! Edited May 26, 2008 by priya Quote Link to comment Share on other sites More sharing options...
