January 19, 200917 yr Hi all, My landrover freelander have a engine problem....so i need to repair my jeep asp.but im still finding a plc.Any one knw a gud plz to make my repair done.
January 19, 200917 yr Hi all, My landrover freelander have a engine problem....so i need to repair my jeep asp.but im still finding a plc.Any one knw a gud plz to make my repair done. is it running an L Series Diesel or a K Series Petrol? which ever way Colonial Motors on Union Place , Colombo 02 will be able to take care it , but mind you they are not cheap Your other option is the current agent Frontier Motors Then there is also Indika , but i don't know if he handles Freelanders. Milroy over in Kelaniya used to , but someone said that he's exclusively BMW now..
January 19, 200917 yr Author what exactly is the problem with the engine?? Actualy brother,, Need to replace the heat sensor I think. After 15min start the engine it will boil. And there r 2 cooling fans .one of them r not working properly.I need to check whether itz a engine problem or somtin else
January 19, 200917 yr Author Actualy brother,, Need to replace the heat sensor I think. After 15min start the engine it will boil. And there r 2 cooling fans .one of them r not working properly.I need to check whether itz a engine problem or somtin else According to ma knowledge, cooling fan is automatically start if heat sensor send voltage(sense) to the fan. But thing is itz not working like that. I think sooooo.but not sure
January 19, 200917 yr Actualy brother,, Need to replace the heat sensor I think. After 15min start the engine it will boil. And there r 2 cooling fans .one of them r not working properly.I need to check whether itz a engine problem or somtin else if its a petrol engine then it could well be a the usual cooling system issues.. is there a coolant loss ?
January 19, 200917 yr Author if its a petrol engine then it could well be a the usual cooling system issues.. is there a coolant loss ? itz a diesel engine .there is no effect on cooling ,i mean air condition
January 19, 200917 yr Author itz a diesel engine .there is no effect on cooling ,i mean air condition i need a plz that i cn solve it, Edited January 19, 200917 yr by Aruna Indrajith
January 19, 200917 yr itz a diesel engine .there is no effect on cooling ,i mean air condition cooling system means the radiator , fans etc etc Edited January 19, 200917 yr by Devinda_Z
January 19, 200917 yr i need a plz that i cn solve it, take it to Colonial - they'll fix anything on a Land Rover - just be warned that they can be a little expensive
January 19, 200917 yr Author take it to Colonial - they'll fix anything on a Land Rover - just be warned that they can be a little expensive ok thnks,cn u find me that colonial motors number,if u dnt mind...... Edited January 19, 200917 yr by Aruna Indrajith
January 19, 200917 yr ok thnks,cn u find me that colonial motors number,if u dnt mind...... 011 2 323 342 /3/4
