maikk99 Posted May 13, 2009 Share Posted May 13, 2009 Hi all I have a toyota carina diesle car with a 2C engine and recently an overall repair was done (including replacing new pistons, ringset etc..) now there is an issue when starting the car when the engine is heated (i.e after about 45 mints travel) in the morning it starts fine from the first attempt but when you run some distance the starter motor struggle to start it groan to turn the battery is a new one so there is no issue with that when i take to the garage who did the repair they told me that it is due to the fact that piston are new and due to the heat of the engine they siezed and the starter motor is not having the power to work them and with some 1000km this should be ok but i doubt this is there any comments for this thanks Mike Quote Link to comment Share on other sites More sharing options...
Tikiri Posted May 13, 2009 Share Posted May 13, 2009 How much have u done after the repair. If its at very early stage after the repair this may happen but that's why u season the engine. Are the Pistons genuine? Probably u will have to give bit more detials I am sure others will be able to shed more light then. Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted May 14, 2009 Share Posted May 14, 2009 Get the Starter motor serviced and check the charging system Quote Link to comment Share on other sites More sharing options...
maikk99 Posted May 14, 2009 Author Share Posted May 14, 2009 Tikiri said: How much have u done after the repair. If its at very early stage after the repair this may happen but that's why u season the engine. Are the Pistons genuine? Probably u will have to give bit more detials I am sure others will be able to shed more light then. thanks tikiri i have done less than 500Km after the repair. pistons are genuine there is no overheating of the engine.the heat controls as usual. there is no oil burn out the thing is in the morning when the engine is cool the starter motor cranks well thanks for the help mike Quote Link to comment Share on other sites More sharing options...
maikk99 Posted May 16, 2009 Author Share Posted May 16, 2009 thanks mate I got the starter motor services and now everything seems ok thanks Twin Turbo said: Get the Starter motor serviced and check the charging system Quote Link to comment Share on other sites More sharing options...
maikk99 Posted May 16, 2009 Author Share Posted May 16, 2009 thanks mate I got the starter motor services and now everything seems ok BTW : does any one know a place which fix RPM meter problems. My RPM meter is not working at all thanks Twin Turbo said: Get the Starter motor serviced and check the charging system Quote Link to comment Share on other sites More sharing options...
