hi guys
i am interested of buying a HRV
i would like to know abt the fuel consumption and the maintenance cost.
thank you
A
Ran a Manual 2wd some time back.
Nippy performance. Good on Fuel (10+ in Colombo) and maintenance cost was almost negligible. Only replaced a brake washer in 3 years of use.
Performance on the Automatic is also pretty good. Fuel consumption is 8-9. Only it has a multimatic gearbox which needs more TLC. Regular transmission oil changes with Honda CVT oil can be a tad costly. You also need to be a little careful if you're buying an Auto because a number of them have problematic gearboxes due to bad maintenance. Check whether there is any juddering or vibration when taking off from standstill. Fixing this problem could set you back about 75k.
Edited by nira74
  • 1 month later...
well said Nira 74....u jus proved u have used a HRV...amawilmada u got da answer !
