I have a Nissan Vanette petrol van 89 mod. there is a hole near the water pump it's look like dekay of the housing. are there any remedies? welding or glue? If I have to buy new housing where to buy? please give your advice. Thank you
Bottom of the water pump is provided with a hole such that, if there is a water leak from the seal of the water pump water drips through the hole. In such a case you have to replace the pump as you can not repair (in Vanettes). pumps are available in motor spare parts dealers as this is a common problem.
