Hi friends,
I have a FB 15 YOM 99. It has clocked 86 whicih is genuine cos i am the first owner. Today in the evening when i started my car all of a sudden there was a huge jerk ( ABS button lit up for couple of seconds and went off). Then i accelerated a bit and i when i released the pedal the engine stopped. Then i started again and it was knocking for some time and i could see the rpm wobbling. It was steady when i put AC and i drove it for 5 or 6 kms and it was looking ok and i could feel the car not pulling properly.
I am a bit worried, is it the sensor? Would a normal engine tune up fix the problem? I would highly appreciate on any comments. Thank you very much
1 answer to this question
Hi friends,
Remove the battery cable for several hrs or ever night (expert says 15min is enough) and see. if you havent done a tune up for the last 25000KM, then better do.
