A/c For Bj 43
3000cc
Guys,
After all the hard work I'm planning to fix a AC to my Beast... Need few advices....
1.How much will it cost...
2.What are the parts I can use from other vehicles..
3.Any good place to do it?
4.Is it worth to do dual A/C?
5.Will there be a effect to my engine?
Tnx
  3000cc said:
Guys,
Tnx
commonly used method is fix a hang-on type a/c unit which is 12v and wire from one battery. You would be able to source a matching used compressor either which will fix directly to your engine or will be able to fix using custom made brackets. If you fix a 12v system you'll have to change the battery which is being used for A/C once in every two months or so due to one battery being drained over the other.
However having said that, if you can source an A/C cooler + blower unit of a Toyota Dyna which is 24v you will be able to use it directly on your 24v system.
