How to Adjust the Idle RPM on a toyota corolla AE100 - 4E - EFI engine which has a manual gear system
there is an adjuster nut where your throttle cable meets the throttle body... adjusting this would make the accelerator cable either more tighter increasing the rpm or looser making the revs go down...
If you have an idling issue that's connected to the ac...maybe your idle control circuit might be having some issues...
I had a similar fault sometime back on my 5a-fe when the ac goes off after cooling the car, my engine rpm would come down drastically even stalling the car at times...
my problem is the idle rpm is too high.. also the adjuster nut is in it's maximum loosen position thus cannot loosen it anymore...
Edited by anjulau78
