i noticed gear oil leakage recently i n my car. leak is few drop after run and stop. parking hrs no any leak.how should i fix this at a low cost.
( Corolla EE 96-1991 wagon)
thank you
2 answers to this question
thank you
cost depends on where the leak is occurring and the reasons behind it...
say for example... sometimes gear oil leaks from where the CV joint fixes into the gear box. There are seals to stop this from happening so once they go bad oil can leak...
If you can hoist the car up and see where oil is leaking from... there are tell tale signs of oil leakage even if its a a few drops here and there...
Or...take it to a garage and get them to check it up for you if you're not too familiar with these kinda stuff....
