kamalabc Posted May 27, 2010 Posted May 27, 2010 Dear all my car is MAZDA BF series sedan 16-0xxx It doors up-postings are plan type mode So need to fix door light model up-postings to the same existing door (Velvet up-posting) Please advice me can I do that Quote
harshansenadhir Posted May 27, 2010 Posted May 27, 2010 Dear all my car is MAZDA BF series sedan 16-0xxx It doors up-postings are plan type mode So need to fix door light model up-postings to the same existing door (Velvet up-posting) Please advice me can I do that if you can source set of upholstry panels of the same model with courtesy lights it should be possible. However, try to obtain a sample and trial fit to be more confident. You'll have to add some wiring for the lights if the loom is not available inside the doors. Quote
kamalabc Posted May 30, 2010 Author Posted May 30, 2010 if you can source set of upholstry panels of the same model with courtesy lights it should be possible. However, try to obtain a sample and trial fit to be more confident. You'll have to add some wiring for the lights if the loom is not available inside the doors. Thanks harshan Quote
