Hi guys,
I hv recently replaced my(EK3-Auto) Ac belt & started feel certain vibration on both "P" & "D" positions.
Same stays while slow driving too.
It goes when I turned off the AC,
Any ideas ? do I need to adjust the tightness of the belt?
Hi guys,
I think it is not related to the tension of the belt. Engine may not advance when A/C is on. Check with a Ac tecnician.
Hi guys,
If RPM drops very low the normal RPM range you can feel a viabration. If you are at normal speed any way the RPM will be around 1500 - 2500. So can you seep RPM drop when A/C is on?
Seems more like an issue with the belt- AC & fan run on the same belt in the Ek3 right? Is there a small screech when the revs drop with the gear change or at the moment the AC is turned on? you maybe able to sort it out with a simple belt adjustment.
