  • Replies 92
  • Created
  • Last Reply
Top Posters In This Topic
Any reputed HU, which uses Garmin and support uploading of maps? I need to know before I pull the string on this
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/DVD-Receivers/AVH-P3200BT
I am planning to buy eBay unit for GPS separately.
I have heard Pettah dealers have this for insane prices. Best price in US 350$.
Are they fake ones?
Thanks for your help!
Edited by kaushama
  • 1 month later...
Guys,
I also need Car GPS with DVD(Xtrons). finaly I found one on ebay it will cost 281$. I asked about Operation System(Wince 5.0 core) about this unit. The company Technical Service person said this GPS unit not locked.most of maps works with this unit and come with IGO8 Maps(US & Canada) with SD card. He is very help full person. Can you please tell , if I buy this GPS unit, Can I upload Garmin Map? Please advise me.
Edited by thusithasam
Guys,
I also need Car GPS with DVD(Xtrons). finaly I found one on ebay it will cost 281$. I asked about Operation System(Wince 5.0 core) about this unit. The company Technical Service person said this GPS unit not locked.most of maps works with this unit and come with IGO8 Maps(US & Canada) with SD card. He is very help full person. Can you please tell some one if I buy this GPS unit, Can I upload Garmin Map? Please advise me.
hi machan, yes its possible. go back and read what hyacc did with his gps device. its at post #39.
Hi Guys!
I'm new to this subject and when i was going through the web knowledge regarding Sri Lanka i came across this blog.
You guys have done a lot and your work should really be appreciated! Thumb up guys!
Here comes my requirement;
I have a car navigator which was in built when I bought it - Japanese domestic product - ND3T-W57.
It has a seperate DVD trey to insert the map disk and when i searched in the intenet, i got to know that it is usually an 8GB dual layer DVD. Seems that we can download the firmware from the internet but I was thinking how could i get a propper map and incorporate it to a DVD!
I know this is really a vague description but have any of you come up with such a requrement and won? If any of you good people think you could help me at least advise how to proceed, that would be a great help!
Cheers!
Buddhika
  • 2 months later...
$49.99 Chinese PNA running Garmin Mobile XT for Windows CE with ironbutcher_x's map and poi file.
Hi Haycc,
I recently bought a Car DVD/Navigation with Garmin installed. I found some roads, places are missing. This operates on a MicroSD card. Pls tell me how to update this. Meaning, can only the map be updated or new version of software to be installed? How to add POIs?
Pls see the photos attached for details.
thanks in advance
post-11753-020393900 1297072983_thumb.jp
post-11753-087807600 1297072991_thumb.jp
post-11753-077581500 1297073001_thumb.jp
Edited by dinran
Hi Haycc,
thanks in advance
Find the latst version of poi, then it will be fine :), creat a folder on ur sd card POI and put the poi file to that :) then it will.
Edited by gavindusl
I'm having a issue with my GPS the 49$ gps give me a error saying Not found Application Please install it from SD/MMC, any body can help me on this matter, i'm not getting the GPS application to be loaded on the sreccn.
Thank you.
  • 1 month later...
Hi Friends
I have brought china GPS with windows ce 6 i try to install garmin to my device (running garmin.exe) the massage appear as "Application Error - Application Mortscript.exe encountered a serious error and must shut down"
please help me to solve this problem .
thanking you
Hi Friends
thanking you
seems the EXE is corrupted, try downloading it again..
Dear friends,
I got Garmin XT working in my car in-dash dvd navi and everything seems to be working fine but everytime I try to search the cities, the application closes and cant re-open it! :o I am not sure whats the problem. Does renaming the .img files all in BLOCK CAPITALS important ? ( ie: GMAPBMAP.IMG ) ??
Then to restart the application I have to restart the setup itself.
Is this a problem with the unit or the software or the renaming I did ???
Please help me.
Special thanks to ironbutcher_x and all the friends in the forum ! :) :)
Shall I post some pictures of the unit ??
Chaser123
  • 2 months later...
<!--quoteo(post=130430:date=Aug 23 2010, 07:56 PM:name=sbandara)--><div class='quotetop'>QUOTE (sbandara @ Aug 23 2010, 07:56 PM) <a href="index.php?act=findpost&pid=130430"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Dear Hyacc
I have same GPS which was taken from ebay. Could you please tell me
what you have done for this GPS to convert Garmin.
If you can give it,
it is highly appreciated<!--QuoteEnd--></div><!--QuoteEEnd-->
Download this files
<a href="http://rapidshare.com/files/327368443/GarminMobileXTforWindowsCE_50020w.rar" target="_blank">http://rapidshare.com/files/327368443/Garm...wsCE_50020w.rar</a>
Extract the contents.
Save the following code in a file as Garmin.mscr
Copy this file to Garmin\RunGMXT folder.
Download this file
<a href="http://rapidshare.com/files/61579171/SriLanka.img" target="_blank">http://rapidshare.com/files/61579171/SriLanka.img</a>
Rename it to gmapsupp.img
Copy this file to Garmin folder.
Get the latest poi file from ironbutcher_x. Create a folder as POI inside Garmin folder and copy poi file to that folder.
Copy the Garmin folder to root of your SD Card.
Go to Windows CE in our device and click Start -> Run dialog box and browse to SDMMC/Garmin/RunGMXT and select Garmin.exe and click ok and run it.
(or create a shortcut to desktop. this is the best way to run this application. If you go to Windows Explorer and open this app it'll run very slowly)
Then follow the instructions found in Keygen folder.
<b>"Garmin.mscr"</b>
<!--c1--><div class='codetop'>CODE</div><div class='codemain'><!--ec1-->Errorlevel("warn")
If(WndExists("Garmin Mobile XT"))
Show("Garmin Mobile XT")
Exit
EndIf
#Whether to use Port Splitter
usePortSplitter = 0
cwd = SystemPath("ScriptPath")
queDir = cwd \ "..\Apps\WM"
queExe = "Que.exe"
#Devices with Windows CE 6 already have aygshell.dll hence Que.aygshell.exe will be run instead of Que.exe which is linked to aygshel2.dll
If(SystemVersion("major") = 6)
queExe = "Que.aygshell.exe"
EndIf
#Rename coredl2.dll depending on the current version of Windows CE
Call("RenameCoredll")
If(usePortSplitter)
Call("StartPortSplitter")
EndIf
#Hide Taskbar
Run(cwd \ "TaskbarHide.exe")
#Copy previous stored settings to \Garmin
XCopy(cwd \ "Settings\*.*", "\Garmin", TRUE)
#Run and wait for Garmin Mobile XT to exit
RunWait(queDir \ queExe)
#Save new settings back to SD Card
XCopy("\Garmin\*.*", cwd \ "Settings", TRUE)
#Show Taskbar
Run(cwd \ "TaskbarShow.exe")
If(usePortSplitter)
Call("StopPortSplitter")
EndIf
#Start Port Splitter
Sub StartPortSplitter
Global(cwd)
#If Settings.dat does not exit ask the user to configure Port Splitter
If(not FileExists(cwd \ "Settings.dat"))
BigMessage("Port Splitter's Settings.dat not found.^NL^Port Splitter will now run to configure it.^NL^1. Select input port and baudrate.^NL^2. Check Autostart.^NL^3. Select ouput port.^NL^4. Click Add.^NL^5. Click Start.^NL^6. Click Stop.^NL^7. Click Exit.^NL^If you want to reconfigure it delete:^NL^" & cwd \ "Settings.dat", "PortSplitter Settings")
Run(cwd \ "Port Splitter.exe")
Sleep(500)
#Wait up to 60 seconds for the window to be closed
timeout_ms = 60000
sleep_ms = 250
i = 0
While(WndExists("Port Splitter V1.31") AND i < timeout_ms)
Sleep(sleep_ms)
i += sleep_ms
EndWhile
#Stop Port Splitter in case the user did not click exit
EndIf
#Run Port Splitter if not running
If(not ProcExists("Port Splitter.exe"))
Sleep(500)
EndIf
EndSub
#Stop Port Splitter
Sub StopPortSplitter
#Try first to stop and exit Port Splitter before killing it
If(WndExists("Port Splitter V1.31"))
#Stop button
SendCommand("Port Splitter V1.31", 1010)
Sleep(500)
#Exit button
SendCommand("Port Splitter V1.31", 2)
Sleep(500)
EndIf
#Kill Port Splitter process
If(ProcExists("Port Splitter.exe"))
Kill("Port Splitter.exe")
EndIf
EndSub
Sub RenameCoredll
If(SystemVersion("major") = 4)
If(FileExists(queDir \ "coredl2.wince4.dll"))
If(FileExists(queDir \ "coredl2.dll"))
Rename(queDir \ "coredl2.dll", queDir \ "coredl2.wince5.dll")
EndIf
Rename(queDir \ "coredl2.wince4.dll", queDir \ "coredl2.dll")
EndIf
Else
If(FileExists(queDir \ "coredl2.wince5.dll"))
Rename(queDir \ "coredl2.dll", queDir \ "coredl2.wince4.dll")
EndIf
Rename(queDir \ "coredl2.wince5.dll", queDir \ "coredl2.dll")
EndIf
EndIf
EndSub<!--c2--></div><!--ec2-->
dear friend,
I did what you explaned, but I can't understand this" Save the following code in a file as Garmin.mscr
Copy this file to Garmin\RunGMXT folder"......
which code I need to save? am I need to make a notepad file?...Please explan to me.
I am try to install Garmin.exe file then the error message came, it says "Please chouse a serial port from the list or enter manualy one COMx"
Thanks...
  • 1 month later...
Source - Lakdasun forum
Guys,
I have uploaded a clone from a Sala ProSat Device which includes their highly updated SriLankan Maps along with the Navitel Software, Anyone who can make this work (Requires a Keygen + or a Crack to the Map files) Please Post it here, or anyone with coding experience please try to make this work.
Sala ProSat uses Navitel Navigation software, Which runs on almost all Windows CE devices, Chinese GPS units, Symbian, iOS and Android Platforms.
Making this work may lead to the point of getting read of slow, laggy and outdated Garmin Mobile XT.
LINK
http://www.mediafire.com/download.php?8klv8r2c7fp1zev
Edited by sanjaya1975
  • 5 years later...
