Guys,
How Do I chk my fuel gauge is working properly?.
During last few weeks It gave several readings that I need to worry abt my fuel consumption.
Average fuel consumption was 11kmpl where now it has dropped to 8kmpl (same driving/road conditions)
I have noticed some sudden drops of the gauge which doesn't relate with milage.
Before I go for chicking on fuel consumption , need to verify the accuracy of the gauge.
Any ideas pls ....
thanks
Guys,
Any ideas pls ....
thanks
Hi RALPH
what is your car model ? first , best think is to check it's resistance,most of the fuel sensors
are working between 0- 100 Ohms first get a multimeter and check the resistance depending on the
physical fuel in your tank it should very Ex:- 0 -10 ohms mean full tank if it between 85-95 ohms you are about to empty tank likewise
but this ohm ratio may differ from the model to model
thanks
regards
sumith
Edited by Sumiya
Guys,
Any ideas pls ....
thanks
Quick question? how do you calculate fuel consumption? generally you dont use the fuel gauge to do that. You fill a full tank run the car for abour 4/3 the tank and then pump again. Consumption= milage/fuelPumped.. the guage will only tell u approx how much you got in your tank. IMO this could easily be around +/- 5iters from the actual quantity.
Hi RALPH
thanks
regards
sumith
Hm, It seems I hav to go to an Electrician .
thanks any way.
thanks any way.
Hi Ralph
Not necessary dude, if you can tell me your car model and if you know how to use a multimeter i can help you
if not or you may not have time to do all go for an electrician
choice is yours
Regards
sumith
Thats how I hv arrived to my average figures. (thanks to AL)
Basically Its the gauge I'm worrying abt. (I feel that its moving rapidly than earlier & not related to the milage I hv driven.)
Coz aftet 6/7 km drive this morning It has showed a sudden drop comparing to lasts night level.
If the gauge is accurate there is sth no right with the consumption.
I too have noticed this sudden 'fuel behavior' for last couple of months. In my case I had done throttle body n injector cleaning, replaced s-plugs, but it still does not give km/l as it used to. I notice this sudden vsriance in fuel gauge.
I wonder whether someone is playing us out on Petrol
Rgds
Edited by Neville
Rgds
[/qu
R u using da same station for fillups? From where ?
I did mine @ Wattala for last few weeks.
Will change da filling station n c.
