August 12, 201016 yr Hi Guys, Today i notice that hold light is blinking. I have a Mazda familia BJ5P. Automatic. Yesterday i noticed that when i put it in D pulling power is very low., then i shifted to lower gear and then shift back to D then its worked fine. But today the Hold light starts to blink, I tried pressing the hold button, no different. then i switch off the ignition and start again now its not blinking. Please advice what was the issue. Do i need to change the ATF?
August 12, 201016 yr Hold button on the BJ series is equivalent to the OD on other makes. There is an obvious issue with your transmission. You better get it checked asap. Just for the record, when was the last ATF change done..? I have PM you a few options. Have a look.
