TURBOMAN Posted October 21, 2010 Share Posted October 21, 2010 Hi Guys, One of my friends bought a Pajero Gdi(98 model) recently and i also had a ride Very comfortable vehicle,BUT 1.When i speed it up above 80km/hr it went into a side ways oscillatory movement(the best way i can describe that motion) which was little bit hard to recover. It disappeared when i slow down 2.When turning to the left side,theres vibration felt on steering wheel. 3.abnormal sound coming from front wheel unit when climbing hilly roads Please give your expert opinions in this trouble Quote Link to comment Share on other sites More sharing options...
SpEeD FrEak Posted October 21, 2010 Share Posted October 21, 2010 On 10/21/2010 at 12:17 PM, TURBOMAN said: Hi Guys, One of my friends bought a Pajero Gdi(98 model) recently and i also had a ride Very comfortable vehicle,BUT 1.When i speed it up above 80km/hr it went into a side ways oscillatory movement(the best way i can describe that motion) which was little bit hard to recover. It disappeared when i slow down 2.When turning to the left side,theres vibration felt on steering wheel. 3.abnormal sound coming from front wheel unit when climbing hilly roads Please give your expert opinions in this trouble I guess wheel alignment and balancing would solve the problem Quote Link to comment Share on other sites More sharing options...
nira74 Posted October 21, 2010 Share Posted October 21, 2010 Check the wheel alignment and balance as suggested and also the Tyres..... what you described also happens if the steel wires inside the radial tyres have broken due to age or due to hard driving with insufficient air pressure. On 10/21/2010 at 12:17 PM, TURBOMAN said: Hi Guys, One of my friends bought a Pajero Gdi(98 model) recently and i also had a ride Very comfortable vehicle,BUT 1.When i speed it up above 80km/hr it went into a side ways oscillatory movement(the best way i can describe that motion) which was little bit hard to recover. It disappeared when i slow down 2.When turning to the left side,theres vibration felt on steering wheel. 3.abnormal sound coming from front wheel unit when climbing hilly roads Please give your expert opinions in this trouble Quote Link to comment Share on other sites More sharing options...
Devinda_Z Posted October 21, 2010 Share Posted October 21, 2010 could even be a weak ball joint.. Quote Link to comment Share on other sites More sharing options...
TURBOMAN Posted October 21, 2010 Author Share Posted October 21, 2010 Thanx my friends The tires are in good condition. It may be the Wheel alignment or the weak ball joints as you have mentioned. I will check them ill give you a feedback. Quote Link to comment Share on other sites More sharing options...
lilzackie Posted October 22, 2010 Share Posted October 22, 2010 On 10/21/2010 at 5:38 PM, TURBOMAN said: Thanx my friends The tires are in good condition. It may be the Wheel alignment or the weak ball joints as you have mentioned. I will check them ill give you a feedback. And check your both hub razers(bearing) too.i've faced the same problem and my issue was that.. Quote Link to comment Share on other sites More sharing options...
TURBOMAN Posted October 22, 2010 Author Share Posted October 22, 2010 On 10/22/2010 at 1:06 AM, lilzackie said: And check your both hub razers(bearing) too.i've faced the same problem and my issue was that.. Thanx mate Ill check for that too Quote Link to comment Share on other sites More sharing options...
Lance Posted October 22, 2010 Share Posted October 22, 2010 Pajero io is a piece of Crap. Quote Link to comment Share on other sites More sharing options...
TURBOMAN Posted October 22, 2010 Author Share Posted October 22, 2010 On 10/22/2010 at 4:46 AM, Lance said: Pajero io is a piece of Crap. May be Quote Link to comment Share on other sites More sharing options...
hakjay Posted October 22, 2010 Share Posted October 22, 2010 On 10/22/2010 at 4:15 AM, TURBOMAN said: Thanx mate Ill check for that too check the engine mounts and shocks also. I am sure its the engine mounts Quote Link to comment Share on other sites More sharing options...
VVTi Posted October 22, 2010 Share Posted October 22, 2010 Maybe its the driver... Quote Link to comment Share on other sites More sharing options...
outlander Posted October 23, 2010 Share Posted October 23, 2010 On 10/21/2010 at 5:38 PM, TURBOMAN said: Thanx my friends The tires are in good condition. It may be the Wheel alignment or the weak ball joints as you have mentioned. I will check them ill give you a feedback. Turbo, Check the rack ends/bushes + CV joints and Steering joints. If the engine makes noice in higher rpms then it might be engin mounts. Quote Link to comment Share on other sites More sharing options...
TURBOMAN Posted October 23, 2010 Author Share Posted October 23, 2010 On 10/23/2010 at 5:57 PM, outlander said: Turbo, Check the rack ends/bushes + CV joints and Steering joints. If the engine makes noice in higher rpms then it might be engin mounts. Thanx my friend, Ill definitly ask him to get them checked Do you know a good place for repairs ,or else should go for agents? Quote Link to comment Share on other sites More sharing options...
jdnet Posted October 24, 2010 Share Posted October 24, 2010 On 10/22/2010 at 4:46 AM, Lance said: Pajero io is a piece of Crap. I guess your speaking through experience right? Once again here's another new idiot on this site putting out random sentences of bulls***. Quote Link to comment Share on other sites More sharing options...
