Hi, please advise as some says not to drive this hyper cvt m6 as an normal auto, they say not to put the pressure on peddle Av once mr suddenly since it is bad for the gear box, as it will put more weight on the gear ratio with high trouq,.... so driving smoothly pushing the peddle gradually as it will shift the gears accordingly to the sped which will not harm the gear box,.....?
And some says don't use the triptronic, once we start using the triptronic only the problems starts, as we put more weight on the gear ratio as the patten of the driving changes,and some says you need to use the triptronic once in a way which you need to get that part also to be function, only if you don't drive on triptronic it will get stuck as the oil will be not pumped to the triptronic side which will harm the gear box....., please advise I'm so confused.... thank you
