Dear Friends
I'm willing to buy a Honda Civic Exi 1996 model...and recently i checked a car and the RPM dial was below one...and when i asked from the owner i was told that Fuel injectors has to be cleaned..so it will be back to normal...
Is this true?
thanking you in advance
Dear Friends
Is this true?
What do mean by below one? If it is ideling speed is below 1000 is normal. At the operating temp. it should be 750-800 . If the idling speed is constant and you don't feel any vibration, It is not required to do any thing with your fuel injectors.
Edited by jaga
is it a problem wit the trottle body?
Thnx a lot for the replies....
I took it for a test drive and i had to accelerate too much so that the RPM would go up to 5000 - 6000...
if its a throtle malfunctioning is this the effect?
Your question is not very clear.Could you explain some more?
also tell us whether this is a manual or Auto .
its manual jaga.thr wz a small vibration 2.witout checkin the car a honda expert said that trottle body shud b replaced.owner had cleaned the trottle n showed me the car.then the Rpm wz abt 900.bt i cudnt drive n see whethr the vibration is stl thr.
The originator of this thread is Yohan . I am bit confused how u know the problem of the car. Any way what yohan has said is that engine rev is going up to 6000 RPM. Yes if you dont change the gear and accelarate RPM goes up :D .
If the idle speed is more than the standard, There can be a problem of the Thr.Body or Injectors or ECU.
