Engine Misses During Morining Start
I have a Mini Van Honda Acty 650 cc Auto, 3 cylinder.
Problem is that the first accelaration in the morning is very difficult, engine tends to misses a lot , very low pick up. however this tendancy ges off when engine reaches the normal tempreature level. I have cleaned the sprak plugs and throttle body to no effect.
Any ideas pls
7 answers to this question
Any ideas pls
Hi Riz
could be moister in the coil pack or distributor cap i guess
where are you parking it overnight ? could be that most probebly
thanks
regards
sumith
Tks Sumth for your reply, but i dont think overnigt parking is the issue, since parked under a shed. other thing this doenst have a distributor, the coil is conneced to the spark plug (distributorless ignition systems)
Hi RIZ
ok. Noted,
does it smoke ? specially when it is cold ?
thanks
regards
sumith
Any ideas pls
how old is your spark plugs. cleaning can only do so much. after a certain time you just have to replace them.
If you haven't replaced them recently i would start there
No not at all.
Hi Riz,
Then I doubt it is something to do with your ECU settings
but i am not sure about,specially Control of fuel mixture
when the engine is cold
thanks
regards
sumith
Any ideas pls
I'd start looking at the coolant temp sensor (One which sends the signal to the ECU ,not the one for the gauge ). If the sensor is faulty and reading high temperature all the time then your symptoms can occur .
Normally there are two sensors in most of the cars but not sure about your one .
if not then check other sensors and condition of the plug leads .
ECU setting wont change unless you mess with it , I wouldn't worry about that
