Water Mix With Engine Oil???
Dear All,
My motor bike was caught by the recent flood in colombo. Water was mix with engine oil.Therfore I replaced oil with new oil. But still the engine contains water with engine oil. Anyone could know how to remove water from the engine without dataching the engine.
4 answers to this question
Dear All,
Hi Ajith
Just Add Little Engine Oil Mixed with Kerosene oil and just start the bike don't
give much load on the engine with higher rpm just 2000 Rpm is enough.
and remove the engine oil and keep it for some time to drain whole oil from the engine
you may do this procedure few times if you are not satisfied at once. :)
thanks
regards
sumith
i would flush the engine a few times with flushing oil or use diesel to flush it without starting the motor...
if it's a kicker...just remove the spark plug and kick it over a few times...
that's what i did when my MTX200 once went into a canal and got fully submerged :P
Hi Ripper
ha ha, seems you had a nice bath :D
thanks
regards
sumith
Hi Ripper
thanks
regards
sumith
nice is not a word i'd associate it but yeah! a full bath it was :)
