December 28, 201015 yr Hi Guys, I am owning a KIA sportage 96 model petrol Jeep. I have an idea to convert it to diesel and I need to clarify few things. Heard that Mazda R2 engine is perfectly mach with the mounts and the existing 4X4 gear box. or do i have to replace the gear box & engine both? If i found a KIA Sportage diesel engine, can it be fixed to the existing 4X4 gear box without any hassle? Spoke to RMV & they said that i will have to use the same number with the D sign on the plate. Please help me to claryfy this with your valuble ideas & experiance. Thanks
January 6, 201115 yr kia diesal sportage has mazda RF/R2 engines they are quite good bt i ve seem in pakwheel forum(pakistan forum like auto lanka) tat they have to put toyota 3c engines(im hav no idea abt this engine type) my point is tat u can consider toyota engines also. jst do some research in pakwheel forum but having said tat even mazda R2/RF engine is quite good and economical they are used in mazda bongo vans, some vannettes, old versions of suzuki escudo. so good luck in hunting for engines
January 6, 201115 yr Author kia diesal sportage has mazda RF/R2 engines they are quite good bt i ve seem in pakwheel forum(pakistan forum like auto lanka) tat they have to put toyota 3c engines(im hav no idea abt this engine type) my point is tat u can consider toyota engines also. jst do some research in pakwheel forum but having said tat even mazda R2/RF engine is quite good and economical they are used in mazda bongo vans, some vannettes, old versions of suzuki escudo. so good luck in hunting for engines I have decided to move forward with a R2 engine. R2 is the latest version of RF right? By the way, do you have any idea about the gear box? Can I keep the existing gear box or do I have to change that as well? I ve checked with some mechanic guy who works in Car Plan and he said that the existing gear box bell housing perfectly suites with R2, is that correct? Regards.
January 6, 201115 yr The sportage did come in original diesel, so havent you considered that engine? should be less complicated.
