December 28, 201015 yr Dear friends, I am to buy a Pajero io. Many confusing ideas around. 1. The GDI system and its price. Is it a high cost replacement ? Is it a very vulnerable part of the vehicle? 2. The gas pedal sensor vulnerability? 3. The use of premium grade petrol? 3. The frequency of servicing injectors/GDI system? Kindly seeking you comments on my Grey areas. ThanX Android
December 28, 201015 yr Run a search there are plenty of threads on it. 1. GDI pump replacement costs 60,000 for a used part. Labour should be about 2000. 2.Not sure what you mean by gas pedal sensor but I've never heard of that issue not have I had issues with the pedal. 3.Only use 95 octane. 4.Injectors don't need to be serviced more frequently than any other car. Use a decent fuel injector cleaner every now and then and you should be fine. Once again, run a search. This has been discussed before.
December 28, 201015 yr 2.Not sure what you mean by gas pedal sensor but I've never heard of that issue not have I had issues with the pedal. does it have electronic throttle?
December 30, 201015 yr Author Thank you guys. For the prompt helping hands extended. I was using this site for the first time. Seems rich with good fellas Android
December 30, 201015 yr does it have electronic throttle? Yes AFAIK...although now that you mention it I really can't remember......All I remember it taking off the trottle and putting it back together....
