My BG3P is poor in fuel consumption. All were checked including ECU (replaced), petrol filter (replaced), wiring (checked), etc... One Mazda lover said that the reason may be due to the 'jets' in the carburetor. Since there was a 'miss' due to the ECU, jets may have been replaced with larger sizes. Pls help if anybody knows the sizes (numbers.
Tx
Well the carburettor repair kit should have the correct size jets and everything you need to re condition your carburettor. Just make sure if your car is fuel injector or electronic carburettor, and if carburettor you have the option of using the carburettor repair kit, reconditioning the carburettor and then turning up the engine and possibly running a lean setting
  • 1 month later...
Tx
jet no -96
call asiri motors
