Check it out this guy has gone all the way with an awesome b18b build: 500hp!!!
http://www.honda-tech.com/zerothread?id=1620181&page=1
Here go the specs:
ENGINE
**HEAD
•DFE Enterprises port & polished head
•Ferrea Lightweight Race valves (1mm oversize intake)
•Bronze custom valve guides (shortened & tapered)
•Crower Super Heavy Duty valvesprings
•Crower Retainers
•Crower Titanium Valves
•Adjustable Rocker Arms
Crower 62404 camshafts
Brand new OEM seals/gaskets
JG Edelbrock Victor X Intake Manifold
Skunk2 adj. cam gears
ARP head studs
**BLOCK
Golden Eagle 2.0L
•Arias Pistons (9:1 comp)
•Eagle Rods
•Eagle Big Rod Bolts
•Step decked, O-ringed, line bored, bored and honed
•LS Crank
•ACL Bearings
•Blueprinted and balanced
Golden Eagle headgasket
Fluidyne half size, dual core radiator
12” slim fan
Avid Racing motor mounts
Custom MSPi custom catch can
Brand new OEM belts and gaskets:
•Timing belt, water pump, oil pump
•Tensioner, intake manifold gasket
TURBO
Garrett GT3582R
Custom MSPi Top Mount Manifold
Custom MSPi 3" downpipe
Custom MSPi 3" exhaust
Earl’s SS oil feed/return/coolant lines
Apex'i N1 4” turbo muffler
HKS SSQV BOV
Custom 2.75” charge piping
Hybrid Intercooler
Tial 44mm wastegate w/ 1bar spring
DRIVETRAIN
Competition Clutch - Stage 5 (upgraded PP)
Skunk2 short shifter
Skunk2 shift knob
FUEL
Walbro 255lph HP fuel pump
Precision 1000cc injectors
Aeromotive inline fuel filter
Golden Eagle Fuel Rail
B&M adjustable FPR
Earl’s SS fuel lines
ENGINE MANAGEMENT/ELECTRONICS
Crome EMS
GM 3 bar map sensor
OBD2 to OBD1 conv. harness
Greddy Turbo Timer
Greddy Profec-B Spec II boost controller
Autometer Gauges – Cobalt series
MSD 6AL Ignition control
MSD SS Blaster Coil
MSD Distributor cap
MSD Wires
SUSPENSION
Autopower 4 pt. rollbar
Tokico Illumina Coilovers
Rota Slipstreams (15”)
Skunk2 front strut bar
Skunk2 rear strut bar
machan thats alot of hardare to squeez 500 with a garrett turbo and all. If i'm not mistaken thats a big one..
So, it's got a new head, a new block, new transmission, a turbo, but its still a Honda Integra? Or going by the badge, Acura.
the head and block are modified honda parts along with after market components (turbo, pistons, crank etc). so it would still go as a honda/acura. of course you get some strange hybrid conversions as well such as an AE86 corrolla with a S2000 engine.
Well you still need a chassis that can take that much torque.. :) I can give you a exmple of a failed project :D
machan can you remember the link to that? I once came accross a 70's Datsun with a 99 Silvia engine ;)
exactly....
now that's really some hard work.. to have put together all that... thumbs up for the guy...
i saw it in a BMI vid. Think it was titled "Roaring VTEC" or something. quite nice to see a Hachiroku there.
