sira Posted February 6, 2008 Posted February 6, 2008 Hi guys, I'm using FB 13 car and recently found the ECC - Electronic Carburetor Controller unit Diagram. if anybody want to have the diagram i can e-mail. just make sure any body who drives FB 13 car you must check the sensors and switches belongs to the ECC unit then your Fuel consumption and pulling power will be increased. Some technicians are not familiar with electronics and they normally don’t check those switches. see bellow FB13 having following switches and sensors 1. Exhaust gas sensor 2. Clutch Switch 3. Speed sensor 4. accelerator switch 5. Idle solenoid 6. mixture solenoid 7. fuel pump solenoid 8. nutal switch( domestic model – press position is OFF) 9. engine heat sensor 10. Power string oil pressure switch Just check those switches and if it nod good replace and see. you will see the difference Quote
The Don Posted February 6, 2008 Posted February 6, 2008 Hi guys, I'm using FB 13 car and recently found the ECC - Electronic Carburetor Controller unit Diagram. if anybody want to have the diagram i can e-mail. just make sure any body who drives FB 13 car you must check the sensors and switches belongs to the ECC unit then your Fuel consumption and pulling power will be increased. Some technicians are not familiar with electronics and they normally don’t check those switches. see bellow FB13 having following switches and sensors 1. Exhaust gas sensor 2. Clutch Switch 3. Speed sensor 4. accelerator switch 5. Idle solenoid 6. mixture solenoid 7. fuel pump solenoid 8. nutal switch( domestic model – press position is OFF) 9. engine heat sensor 10. Power string oil pressure switch Just check those switches and if it nod good replace and see. you will see the difference Hi Sira, why don't you upload the diagram to something like rapidshare and post a link ? Thanks, The Don Quote
disnaka Posted March 2, 2008 Posted March 2, 2008 hi sira... can u plz send the Fb13 ECC - Electronic Carburetor Controller unit Diagram to my e-mail <[email protected]>. thanx.Have a pleasant day. Quote
sira Posted March 3, 2008 Author Posted March 3, 2008 hi sira... can u plz send the Fb13 ECC - Electronic Carburetor Controller unit Diagram to my e-mail <[email protected]>. thanx.Have a pleasant day. it is a huge file. 71 Mb i'm looking a way to send that.fo you have FTP connection ? Quote
priyantha3d2 Posted September 9, 2009 Posted September 9, 2009 can u tell me fuel ecnomy of fb 13 with and without ac pls send link to download fb13 manual book Quote
Prami Posted September 9, 2009 Posted September 9, 2009 (edited) it is a huge file. 71 Mb i'm looking a way to send that.fo you have FTP connection ? Sira, i think you cant email such like a huge file on 71MB. Use this one for the file upload: http://www.mediafire.com/ and share the link. Edited September 9, 2009 by Prami 1 Quote
Dhanuka thathsara Posted April 25, 2020 Posted April 25, 2020 On 2/6/2008 at 3:14 PM, The Don said: Hi Sira, Can you plz send the fb13-ecc-electric carburetor control diagram to my email <[email protected]> The dhanuka Quote
