Everything posted by Ruslan
Suzuki Grand Vitara 1996
Not sure latest version of J20A (this came with earlier version of Grand Vitara 2006-2008 models) would suit? If yes then do a search on quick site. Good Luck!
Price of unreg. vehicles increased by Rs. 1 mn, Vehicle importers explain current situation
I think it’s high time Government ban these “Mudalali Jokers” importing vehicles to the country and regulate the industry properly.
Compact SUV around 6 mil
As a User of a Previous Gen Vitara, new one doesn't even come close to the previous one (Was expecting some thing similar to Latest Jimny like vehicle but). but new one stands out from the rest of the CUVs like iRage said. bit sad we are not getting the 1.4 or 1.6 version here due to the insane tax structure.
Which Nano Coating should I go
Talking about Detailing, Recently Kleen*** quoted 27k for My Brothers IST 2007? ? thats of course for the full detailing job.
Personally i would stay with good ol Waxing (Stick to good brand like Meguirs). As iRage mentioned above it would be a mess once it started to show its age and start deteriorate.
Need help..Looking for a Non-CVT car for under 5 Million..
Corolla 141 Facelift 2010 onward s. That's a bulletproof AT box.
Honda Civic 2018
Good stuff Mizzy, where can you get the BG frigi clean and the cost please. This looks like DIY evap coil clean.
- VIN Number in Toyota CHR
Honda Civic 2018
I Guess it's the prolonged humidity stuck in the evap coil (When you switch off the car) which makes the stinky odor. why don't you try an Active Carbon AC filter when you replacing one. i'm having fairly good results using one. got down from Aliexpress. hope it's not the rodents this time.
- 2013/14 CRV or a 2018 CHR G-T
Restoring a Toyota Sprinter Trueno
Wow! Wow! Reminds me older build threads.. superb way to finish the year and Congratulations!! ☺️
- Suzuki Vitara 2019 SZT
New Defender Design??
For me this is Too much sensors to fail. i like the simplicity of the Old Animal. not this Computer gizmodo. love the new Jimny Siera, oh well they thought other wise with the New Vitara, which doesn't even related to old Mule. Sad!.
Honda Civic 2018
True, found out that Toyota T-IV ATF is nothing other than re-branded Mobil 3309. and Valvoline Zerex Asian Vehicle Coolant is the supplier of Toyota Pink SLLC (Super Long Life Coolant).
Suzuki S Cross SX4 Boosterjet 1.0L 2019 UK
Im not sure on this part since Brand New status can be stated in the CR for cars which got down by Authorized Agents (Unless this is imported by A*W). for parts, why don't you check with Wijerama area Part dealers (Few calls would do). i believe its the same engine (K Series Boosterjet) which shared among Baleno, Swift and Vitara. so apart from Body parts, i dont think it would be much of an issue for Running gear. by the way, is this is a AWD Model? for that Price, it's well worth it.
Project A72V
Just Curios, can the R12 Based Compressor will be able to handle R134 Gas?
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Honda Civic 2018
How much did it cost for the Hood PDR? there's a Dent on the roof in my Vitara which i wanted to do PDR. issue is this panel not reachable from under.
Suzuki Rs 2017 highbrid steering rack noise and play
-Edit-
Brake system failure
It's Not ABS System Resetting (Resetting and ABS Auto Bleeding is 2 Different Things). it's called "ABS System Auto Bleed". only Advanced Scanners (Launch Creed or OEM Scanners) would support this feature. General Scanning would not detect Air in the ABS Unit.
Have you Done the ABS unit bleeding using a scanner? i strongly advise do a better diagnostic before throwing cash to replace parts blindly.
Is the Grand Vitara worth it?
Interesting, i don't see any issues if the conversion is done properly.
Hmm, isn't R2 is from Mazda? i know some times Manufactures use, different Manufactures engines for Diesel Variants, for example 3rd Gen Vitara uses Renault F9Q Engine in Diesel Variant. but check whether 1st Gen Vitara uses Suzuki Diesel or something else.
Adding to what Davey said, there's a Method to get rid of the Air in ABS Module using a scanner called "Auto Air Bleeding ABS Module". this will require a fully fledged scanner like launch creed or you might need to consult the the Agents. below link contains how it has been done. once this is done, air trapped inside the Module will enter the brake lines and you should follow the normal bleeding process (Pedal Pump or Vacuum Machine method) to get rid of the trapped air in the lines. you can do this in manual way by Slamming the brakes on a gravel road or ground (where there's no traffic) to activate the ABS and activate all the solenoids in the ABS module, but doubt the success.
CHR 1200cc colombo city Fuel consumption per liter
I'm getting the similar figures (6.5-7.0 kml) on my Vitara which is a 2.0L AWD on similar route (Wijerama - Dematagoda OrionCity). i thought it was a gas guzzler. ?
Honda Civic 2018
Yes, Recently bought Leather Balm and Cleaner Kit. they are Authentic.
