Twin Turbo
    51
  1. Check for fuel leaks causing the smell,..
  2. The smell is from the oil in the system leaking into the evaporator box,. The hot air maybe from the heater leaking hot air .
  3. How bouts an alternator conversion?
  4. Hi, upload a pic of A/c control panel with the system running.
  5. Add an injector cleaner,to the tank on next fillup,.. Q: Is the engine loosing oil? Upload a vid of the engine and the smoke.?
  6. Replace all coils and plugs.+ air filter. Your catcoverter may be blocked.
  7. Switch blower on, front windscreen de frost and to freshair with a/c off
  8. Hi and welcome to AL,.. So, you're looking for a reason to not-service your car,..? Q?, what is the current mileage of the car now?
  9. ave you got a budget, ?
  10. Hi and welcome to AL, Too wide an array . shortlist, the Montero can not be compared with a Axela.
  11. Start with a service,..
  12. Was the engine washed before ?
  13. Go Micro? it;'s new with warranty.
  14. The T valve should be rated at 82'c After taking into account the age and mileage of the car, I'd get a major tuneup replacing all. consumables enjoy your car!.
  15. I second that, water ad electricity don't mix. https://www.youtube.com/watch?v=QNdXNU_Grm4
  16. Have you tried flushing the ATF first?
  17. Looks like this is a bad case of tapwater-itis,.. you knoww what to do,..
  18. Start with the autobox, re-pressurize the injectors,..change the fuel filter?
  19. Simple solution would be to replace your car with a new one with with an auto box.
  20. Keep a check on the oil level,/. The white smoke on cold mornings may be condensation.
  21. Take care of the oil l.eaks and see,.. you might see an improvement. TT
  22. The manufacturer has not asked you to use the more expensive stuff, so save your money,./ All you need to do is to change your mind-set. as you car was designed for regular juice. Wishing you happy and cheap motoring,.. TT.
  23. HI, have you checked Pala auto electricals?
  24. HI and welcome to AL .The vacuum system starts from the vac pump on top of the valve cover and vac is applied to the booster by a rubber hose. Repair mans for JDM cars wuill be in JAP . only.
