51
One side tire binding, low power sometimes, radiator reservoir boiling
Twin Turbo replied to Iroshw's question in Mechanical problems
The binding brakes will make it harder for the car to freely move causing the over heat condition. -
Better get a second opinion from a battery shop.
You may have over tightened the tie-down clamp,cracking the case.
Better luck looking 4 a reco engine.
Lube the fly weight asszy.
- 189 replies
- mitsubishi
- a72v
(and 7 more)
Your car will keep on chugging along till the end of time. ! and make sure you keep up with the services. ? TT.
- 33 replies
- cold start
- driving
(and 4 more)
just check the front sus joints and check alignment. more worth if you spend the money to get a front disc conversation. TT.
Buying a Datsun Pickup D21 vs Y720
Twin Turbo replied to Abeysekara.is's question in Car Buying Information
upload some pics to start . -
would like 2 see it. -
hI, Better get a specialist inspect and report on the vehicle you in tend to buy. from your description, , it; sounds like a chop shop special.. TT. -
How sure are you of the odo meter?
Under local law, fitting an extra pair of driving lights is illegal, - (ref pre posts.)
- 1 reply
- modification
- modifications
(and 1 more)
Congratz bro, start with a full service, change all fluids, filters, and in course make plans for a new timing kit. enjoy the drive ! TT,
Can you expect anything better, start by getting all filters and fluids changed, and the sparkes. get the brakes for binding, re=-fill fuel tank from a different fuel station good luck. TT.
- 5 replies
- 1
- nissan
- nissan pulsar
(and 5 more)
make sure the lucky candidate has power steering.All older 4x4's came with drums all round,..
Hi and welcome to AL. Q: What is the vehicle? you'll need to upgrade other systems like brakes , cooling etc. TT.
Hi, we'll start with a simple solution,.. some correction fluid came to mind,.. Wishing you safe driving,.. Cheers.! TT.
Hi, great timeless classic. just change the sparkies, the 3k engine comes fac tory fitted with extended reach special plugs. TL will stock them. and look at the air filter for good measure,..replace it if it hasn't been running since the 90's ? enjoy the ride, how's the a/c ? post some pics,! TT.
The CVT goes wrong and gives headaches if not maintained.
Convert normal steering to power steering
Twin Turbo replied to Alexander Andrew's question in General
Get the tyre pressure right and alignment checked. cheaper , and will save more fuel. TT. -
hi, get a cover, simple does the job, no more cracks. TT.
Looking To buy an Allion 260 - Need Your Help
Twin Turbo replied to TaylorMade's question in Car Buying Information
Hi, and welcome to Auto Lanka., please look at older posts on this vehicle. Good luck. TT. -
The agents,
Check for deformities in the tyres,..
