Car Maniac
Everything posted by Car Maniac
  1. Bro Ripper, I observed that you haven't mentioned about the Havoline motor oil as a good oil, eventhough you have commented about all the other oil brands. So in your view, is Havolin a bad engine oil? Currently Im using Havoline Formula engine oil and my Toyota Petrol car has around 150, 000 km on its clock, so is it better to shift to a new engine oil brand at the next oil change? Because I was also thinking about shifting the brand but I didn't have any excuse to justify on. Now I feel I have something to justify, so please you guys more comment on this case. I'm willing to change to any oil brand at any time so you are open to recommend me the best oil brand for my case. BTW I found this thread very important so thanks all the guys for you contribution.
  2. here another gud one... security car cover
  3. Guys here are my findings! Hope you would like..... :jumping-smiley-013: And I would say, this is a good thread by the way. Have fun
  4. Yeah its unbelievable. My fathers car does around 11 kmpl in the city and only 13-14 kmpl outstation, even after a tuneup at A#W, very decent driving and many major services. Im referring to the squarer model swift (year 2004) right. So if any swift else in the world does around 14 kmpl in city then either I should check what that wonderful car is or I should hammer my car to death. :action-smiley-060:
  5. Superb international car collection bro. You are the one lucky guy!! My congrats................. :alc:
  6. Bro, What is the wattage of the bulbs you used to replace the instrument cluster with? Are those 5 W bulbs which are same size as the bulbs coming for the park lights? I know how to remove the panels infront of the instrument cluster but removing the speedo meter cable and pulling the instrument panel out is a problem for me. Please can someone help me and tell me the way to remove the bulbs and replace with new ones? Procedure is required. Thank you very much!!! My car is a toyota with old black meters. By the way, please recommend me a brand of quality bulb as you mention. Thanks a lot guys.
  7. Happy Birthday Sharkster!!!!!!!!!!!!! Many happy returns of the day!
  8. Dev, you seems to have forgot to put what Bently CEO said after observing all the others above, which is the final part of the story. Its this: :angry-smiley-048:
  9. Car Maniac replied to GihanFX's topic in The Lounge
    Yeah, Gihan bro you are correct. I got your point. Thanks By the way I should warn all of you guys about another possibility which is only second to the issue of water getting into the engine. That is water getting into the ECU. This is a real scene what has happened to one of my fathers friends. He had a toyota corolla 121 and one day he has parked it in the town and has gone to do some work somewhere. Meanwhile it has been rained heavily and the area around his car has been flooded upto around 2 feet and water has got into the cabin. The result was when he came, the whole cabin was full of water around 1 feet inside the vehicle, seats are completely soaked and finally he found the cars engine ECU is also busted because water has somehow gone into the ECU and busted the circuits forever. The higher water level has run over the ECU, dipping it in the water. After that, he had to wait for around two weeks to get an ECU even through the agents and not only that, but also some many many more problems. And finally they have found how water went inside the cabin. It was through one of those circular holes on the steel wall in between the front engine compartment and the cabin, through which wires are gone to lights, engine and all other front devices. Usually those holes come plugged with a circular rubber part to prevent water goes in. But in his case, when he got his car security system installed, that technician has removed a whole rubber plug out from a lowest level hole, to pass through the wire going to the siren inside the engine compartment. So that bare hole has let the water go inside the cabin. A sample rubber plug in the engine bay is shown below. (Arrows are pointed at the plugs and holes) In that corollas case the entire rubber plug like this have been removed so its possible for water to go inside to the cabin easily. So guys please be careful. Specially check whether those rubber plug things are plugged properly or if they are unsecure, get those holes sealed somehow. becos even parking in a flood could possibly cause you a big repair due to what I have shown above. If you are not sure whether your cars cabin is properly sealed, dont park around suspicious flooding places. Good Luck!!!!!!!!
  10. ha ha ha.........
  11. Car Maniac replied to GihanFX's topic in The Lounge
    But machan if Im correct, again it comes to the same route but in a severe way because water will be forced inside to the engine by the turbo (Faster than in a normal engine). So severe results I think. Its how it should logically happen but not sure bro. GihanFX please correct me if Im wrong cos I only have some little knowledge about turbos.
  12. Car Maniac replied to GihanFX's topic in The Lounge
    As far as I know, the science behind this scene is as follows. As you and me know pistons are fastly moving inside the engine (no need it to be above 2000 rpm, even at idle speed an average engine works at 1000 -1500 revolutions per minute.) So this is super fast speed. In these normal engine, air is sucked through air filter into the engine, and when that air is compressed by the pistons moving upwards then due to fuel injections and spark, that air fuel mixture gets ignited and forces the piston to go downwards because of the pressure generated by the combustion in the cylinder. The above is the normal process but when you are going in a flood, if accidently water comes/ enters your air cleaner, due to the vacum created by moving pistons, even that air is sucked inside to the cylinders super fastly. But unlike air fuel mixture, water doesnt get igtnited neither once compressed nor given a spark, so the fast upwards moving piston tries to compress the water and the fact since water doesnt ignite and minimise, that compressed pressure has no other way to release other than forcing the upwards moving piston to move back downwards in a reverse motion, other than cycling forwards in the normal way. and this massive reverse force on the forward moving piston tends to bend the connecting rods, crank shafts...etc to relieve that massive force. Once the connecting rods and cranks get bented sometimes they even come through the engine block to outside so once such thing happens , the owner has no other solution than replacing the engine. This is the best way I could explain you how that works but Im sure it would be bit confusing if some guys without the initial knowledge on motor engine mechanism, try to understand my story. So I would help you as well. Basically the so called reverse force on the front moving pistons could be explained in a simple example like this. When someone is driving a car forward at 100kmph towards a huge rock, as his car hits the rock with a huge thud since the rock doesn't move, the massive force generated by the hit between car and rock should be reliased some other way. and it is the way of putting that force backwards on the car completely so the car will get totally collided. But if the same car at same speed hits a bullock cart of hay moving the same direction that car moves , as the two objects hits each other, the lighter object which is obviously the cart will be thrown forward fast to release the force generated by the accident. So only a minor damage or no damage will be there on the car because it was able to release the force to the bullock cart. A car crashed with a non- moving object - High Damage A car crashed with a front moving object - Less Damage Hope everyone got it. Good luck and wish you all the best to everyone driving in floods!!!!!!!!! Better safe than sorry[/
  13. and even the tiny nickle handles..... whats da point? God knows!!!!!!!!
  14. Car Maniac replied to Pb2k's topic in OTHERS
    Yeah its a really good paint job. Looks like the original paint. Excellent finishing. Does Mercantile Investment Workshop undertake any restoration or paint job or otherwise how to enter there? Thanks if you can let me know.
  15. A normal iron work shop in SL would definitely do a way better job than this! What the he*#? Does anyone know what has happened to the owner of that damn body shop after this job got done? Is he still alive or faced death by the 350Z car owner? :action-smiley-060:
  16. What to do ?????????
  17. superb info. Machan thanks a lot!!!!!!!!!
  18. yeah! I also would like to know about this. Please help if any of you guys have an idea about this process or some instrument face renovation processes similar to this. Thanks in advance.
  19. Yeah I have also heard that brand new 1.3 ones that Toyota LK sells haven't gos ABS as standard. And it could be correct because by most of the ways, the brand new corollas they have are very less in options when compared to Japanese full option but reconditioned same corollas. I think the ABS is not standard because an additional tax is charged on it by the customs when those are being imported to SL. So to keep the corollas price to a minimum, they just import non ABS corollas. Otherwise if toyota LK imports corollas with ABS and other options as standard, then the price of the corolla could go very high. It could be so much than we can even imagine, thanks to the unreasonable taxes and duty of SL customs. But if you want a car with ABS, then you can pay few bucks more and go for one.
  20. this is hell!!!!!!!!!!!!!!!!!!!!!!
  21. Bro, I think you are asking about the Mitsubishi 4DR5 engine of your Jeep right? I will give you two suggestions to find out the solution you want because it seems like you still haven't found the PSI pressure rate from anywhere yet. Option 1. You can call some Mitsubishi Jeep owners who have advertised their 4DR5 engined Jeeps for sale at Auto Lanka site and kindly explain them your situation and ask one of them to check out their vehicle's radiator pressure cap and let you know the correct figure. Because then the pressure value they tell you has lot of credibility because they are saying it after looking at the same 4DR5 engines. If you can visit one of them, then thats better ("Find it yourself" method). Im sure there will be atleast few guys who are willing to help you. Warning: Here the way you ask them matters a lot so be gentle in your words or get the help from a marketing guy. Option 2. Go to Mitsubishi agents - Uni ### Mo and let them solve the problem. If agents dont know, then who else knows??? As far as I know, a pressure cap will not cost you more than 1000 rupees even in an extreme situation and your matter will also get solved easily. And this is the best solution too. Wishing you good luck!!!!!!!!!!
  22. OK machan, you could be correct. But according to the situation here, though the so called N16 is also a B15, that particular model have already been registered as the N16 in Sri Lankan car market. Let it be a guy from south, from Kandy or from Anuradhapura, everyone call it the Nissan N16 or a N series, in common. For our information and knowledge, the fact you are pointing out is ok and acceptable, and I appreciate it because you say the manufacturer details say so. But this is not a fact we can teach to the rest of the Sri Lankan car market who are away from the AL, because as I said earlier, this is a commonly spread term (I call that N16 is a "Card" for the particular model in Sri Lanka.) So if someone goes out and show a N16 car to an ordinary person, saying "it is a B15, not a N16" then he will laugh at the guy. Here no offense machan. I just tried to point you how these "Registered cards for the car models" in Sri Lankan car market works. No worries!!!! :alc:
  23. Car Maniac replied to dinosh's topic in TOYOTA
    Dinosh bro, If you are buying the car for a long run (I mean to use it for atleast 5 years) then the market value and demand of the car is not a big matter of concern. But if you have no idea to use it for many years then the market demand and value matters a lot. As far as I know, for some reason this Toyota Vista is not a very common car in Sri Lankan car market and most of the people are unaware of that. As an example, you dont have to explain anyone about the Market demand of a Toyota Allion or a Corolla, right? Since they have somehow created a reputation among people, anyone knows it or atleast they have heard the name "Allion" once. But Vista's case is different so unless luckyly you find a buyer one day when you are about to sell, it will be hard for you to sell it and since people don't know manythings about that, the market value will also go down. This is why some people are really concerned buying only reputed models of cars, even of reputed brands like Toyota and Nissan. The spare part availability is also a matter for rare cars because many motor store owners dont want to fill up their valuable store rooms with parts for rare cars which rarely get sold. So the only solution left for you will be buying the parts from the agent, paying many extra bucks and finally getting ripped off. As another example for this Vista's unpopularity, if you asked for the fuel figures, market value and so on about a famous car like a Allion. 121 corolla or a vios, Im sure answers and comments would have flooded into your question within minutes from AL guys. But since this car is not very popular, not many guys have experience in it so less number of responses from the members. I hope this would logically explain you the theory behind market demand. Lower the potential buyer's awareness about your car, it is harder to sell. This is only my opinion. So its upto you to decide. Anyway happy car hunting.
  24. great info ripper. Bro, thanks a lot!!!
