Everything posted by Ripper
Drags Saturday Night!
Outrunning cops is so bloody cool but these days it's pretty dangerous... checkpoints all over the place and quite a high chance of getting shot multiple times with those ak's I've out run cops twice in kandy road on bikes... pretty easy since those guys don't take the chances we take good fun until you get caught i suppose
Traffic Jam
that's BS mate they don't care two hoots about civilians not even tamils... the Rathmalana bombing was yet another example of indescriminate bombing... I know a couple of people who died that day all because they were just passing that spot... Our leadership is not doing a good job but tigers should be hunted down like mad dogs
Major Crash At Malabe.....
i think we should show those to deter bad driving... every tid bit helps IMHO
Need Advice On Repairs + Modifications
http://www.knfilters.com/faq.htm you can get a good idea about K&N filters from this link... "clones" are copied versions of the original K&N filter that's available under other brand names for a cheaper price... Oil changes depend on age of vehicle and it's mech condition... quality of oil used... Driving conditions etc. Most decent oil brands give info on general oil change intervals... I'd just change it couple of thousand km's ahead of this figure to be safe... on the hot topic of exhausts... Free flowing pipes get rid of the exhaust gas a little faster than a stock pipe. And this reduces back pressure giving the engine a bit more power on the top end... meaning at higher rpm's But on lower rpm's torque will be less because of reduced back pressure... Though it's out of topic...this is very clear to spot on 2 stroke engines where back pressure has to be controlled into perfection to achieve max performance... You run a 2 stroke bike without the expansion chamber and the pipe it'l rocket down on top end but torque will be gone for good... to make a long story short... lotsa free flow- less back pressure-more fuel-more top speed- less torque I don't believe free flowing pipes are really bad for engines as long as you have your jetting right. Free flowing pipes will lean out your fuel mixture in the cylinders and this will cause the engine to run hot...and that has problems attached with it... If you can adjust your carby to compensate for the lean condition... as far as i know.... engine should be alright... But you gotta remember...car makers have lotsa R&D behind their machines so stock is the best bet for your engine's health... But no one lives forever... calculated risks are fine if benefits are good
dude... if you're replacing the air filter into a "performance" air filter...get the carb also tuned at the same time... If you get a lot of air and not enough fuel into the cylinders...it'll create what's called a "lean burn"... whitish sparkplug residue is a good way to spot it... Ideally the fuel/air mixture shouldn't be too rich or too lean.. Lean burns generate more heat and are not too kind on your engine...especially the valves... Too rich will be bad on fuel economy and will foul your plugs over time... Like Saturn said...a golden tanned plug is indicating a proper burn... http://www.ngksparkplugs.com/techinfo/spar...aq/faqread2.asp
Looking For A American Car . Any Condition
there was a Pontiac for sale on H1taD
low profile tyres do have draw backs on cars that they were not intended for... cars with stock low profile tyres have their suspension designed to handle the extra work load... Others are not... you won't have a smooth ride over rough terrain... Like most people have already said...extruding wheels out is not a good idea buddy.. you'll screw up the balance and handing of the car... you have to make a call whether you want mods for Pure "looks" or for Functionality... I personally don't like no.1 aka ricing but heck it's a personal choice good luck with your project
Autozine Technical School
glad everyone liked it... putting google to good use and got lucky that time feel good to give back something to AL
http://www.autozine.org/technical_school/tech_index.html for the curious minded and the OT show offs
Hoping To Install A Mufflar (a Beat Silencer)
As far as i know... Free flowing exhaust systems REDUCE back pressure... you will get more top-end speed at higher RPM's but less Torque in low RPM's... Fuel consumption is higher for pretty obvious reasons Most of the time these locally made beat barrels or fart cannons are free flowing type and puts out a huge racket when they move around... But what they don't know is that the little top-end speed they gain by a free flowing exhaust is only within a certain range of reduced back pressure... If it's too open you actually loose out on the deal... Which might be the reason for lots of the loud cars on the road are actually not very fast I'm into offroad biking so those factory exhausts are made to keep the low end torque and grunt and most of them are now tunable for jetting settings/altitude corrections etc.... my 2cents
Ball Joint - Lubrication
dude...you gotta give out the make and model etc of the car in question for our guys to give you any good comments
Toyota Avenza
I'm with GTAm...the Fiat interior is super right throughout all their models in SL... I head they are gonna bring down the Bravo also... Fiats most successful car if i'm not wrong... Best bet is to check both of them out and then make the call... just my 0.02 rs.
Fiat Diesel In Sri Lanka?
I like the Bravo also...don't think it's still available is SL
Battery Water !!!!
as far as i know... that voltage is not enough to charge a battery properly... you'd need around 14volts... if you have access to a manual...you can check the resistance of the alternator and cross check with the figure on the manual... I think even if your regulator is faulty...you can get similar results... people tend to think bad regulators only gives you higher voltages but i have experience in it happening the other way around too... good luck
timing belt is what keeps the valve's opening and closing properly on right piston stroke... it connects the crankshaft to valve-train and keeps them synchronized... go to howstuffworks.com and checkout how a 4 cycle engine works...you'll get a better idea of things
Suspendtion Mod For Cars
yep...best bet is to keep it stock we don't have super eXperts in this area to modify properly... you'll end up messing things up
Planning To Buy My First Car
before i got my ae100 sprinter i went and checked out this eg8 advertised on AL...he wanted 11 but we instantly knocked it down to 10.5 even before a test drive... the car was black, 19-, low profiles the works but was absolutely crap in terms of pulling power etc... And it guzzles fuel although being a Vtec... I know i shouldn't generalize and i'm sure i'll get flamed on badly if i speak against civics but do take care if you're going for an older civic... people have done so much of bad things to them over they're lifetime they are not as good as they should be anymore.... the civic i'm talking about was in wattala... for that budget you can get a primera 1.8ltr or 2ltr... 300- but they drink juice... lovely machines to drive though If you can get an AE 110...it's a steal very very difficult to get a good car in good shape... Go for manual if you can....autos suck especially the older autos these cars hold great market value....solid reliability, good fuel economy but not the greatest lookers or driving machines I'm happy with my sprinter though comes down to what you really want out of it good luck
Toyota Avenza
i'm also a toyota fan but i would just checkout the FIAT, doblo... think it's pretty simillar to avanza... I've seen it when i went checkout their grande punto... looks to be pretty decent and solid with very nice interior... don't know much beyond that though
Mazda Axela
it truly depends on what you want out of the car it's definitely a good ride...looks cool... most cars are worth buying if you get what you're looking for and for your budget etc.... give us some details and i'm sure people will chime in right now it's too loose to answer properly
great going saturn....that's one mother load of a post
Building A House In Sri Lanka
i agree with Overdrive the house i'm renting is built for a lady in UK...the work is still going on the upper floor and i have witnessed the way these contractors build when they know the owners are not there... the wood they use are pretty bad quality...just dyed and varnished over...the roof wood materials are sometimes used ones make sure you have somebody you can trust to oversee the process cos even the cleanest contractor guy might get tempted to rip you off... And sometimes it's not the contractor but the supervisors who works under him that rips you off... good luck with your project
Battery Water !!!!
this may be a long shot but here goes... i'm having a electrical issue with my XR250...battery dying abnormally when running... in my research on foreign forums etc. i found out that if the battery overcharges it heats up and evaporate all the liquids inside it... Normally if your regulator is busted this can happen... You can check it when the car is running...get a voltmeter and measure the voltage between the two battery terminals...it should be little over 12v...on my bike the manual says 14v...anything over will over charge the battery... But you have to first make sure that there are no external leaks or cap issues etc etc good luck and keep us posted. These "funny" problems suck and very difficult to spot and to make it worse ends up being a simple thing gone wrong somewhere
Drunken Driver Pays The Price
I don't mind having the TATA as a second vehicle to maybe pull a boat around and take the dirt bikes on trailer on camping trips kinda stuff If only it looked a tad better and was double cab. maybe that's why it's cheaper
Ae 110 Or Fb 15
Cool... Don't be in a rush. go for a manual. Keep and expert handy to check the car out fast once you spot one since these sell really fast especially if the car is in good shape. good luck
ok let me give my 0.02... i might be wrong but here goes 1. i apply breaks first to slow the vehicle speed that matches the gear i'm gonna go down to and then shift down. There are time when i come down from the 5 to second or even first straight after braking appropriately... 2. ac problem is normal i guess on an older vehicle especially if the engine is not producing enough power for many reasons... Steering vibration is not normal so there has to be some worn parts etc. needing to be replaced in that department. Get a mechanic to check it out 3. this is most probably due to bad spark plugs... they need to reach their proper operating temp to work best and as they get old...it takes a while for them get all heated up check the plugs and replace if necessary... and check if the plugs used are of the right temp range for your car. 4. can't really say without checking it out. sometimes what looks pretty simple needs a lot of work especially when it comes to aligning stuff 5. you have to practice to figure out that sweet point where the clutch is starting to slip and start to bite in. practice practice and practice... i don't use breaks unless i'm in a tight situ like another car just 2 inches behind me or a fully loaded car etc. where i would use the handbrake just to be safe i'm sure others will give you better pointers since i'm also just a couple of weeks into this cheers R
