terrabytetango
  1. The Rexton is a very good vehicle for what it is. As long as you don't expect it to be a Montero or a Prado, you'll be fine. Lots of extra features plus an extremely plush ride. But be warned, it will not be fuel efficient. If you're picking up a used one, more power to you because the first owner has already borne the bulk of the depreciation, thus giving you a good deal.
  2. Of course, because Initial D is awesome. You should watch the series.
  3. Its the whole circuit. My Vios does the same thing. Two bars when I pull into office, and when I start it up in the evening to go home, flashing indicator.
  4. On the rear of the head lamp assembly, there should be two adjustment screws with indicators embossed on the plastic identifying which is which (x and y axis). Google for optimum headlamp adjustment height, and remember to read the instructions for right hand drive vehicles, not left.
  5. I think you mean when you disengage the clutch, by pressing the pedal. The load is taken off the engine, thus it obviously spins faster, and then settles back down again once the load is applied (clutch engaged after shifting into the next gear). Try letting go of the accelerator when you press the clutch, and then gradually ease on the gas and ease off the clutch to smoothly pick up from the next gear
  6. My former boss has an Aerio, with the 1.6 litre engine, and it never does better than 9 in the city. Are your sure yours is 1.5 and not 1.6? Edit: It was the relatively poor fuel economy coupled with scarcity/cost of parts that dissuaded me from buying one myself. Otherwise, it's a brilliant car and so so comfy even in the rear, plus excellent driving position for the city.
  7. Are you nucking futs?? Apart from upgrades, the only time rotors are replaced is when either they're too warped or when they're too worn i.e. gone beyond the recommended thickness. And with normal use, that is quite literally years, if not tens of years. I was pretty anal about the brakes in my old van (Townaces have shitty brakes which just get shittier when hot) and even after 330,000kms both rotors still had plenty of material on them.
  8. I remember when Paula consistently wore strapless tops, before she had her baby. Also little bit of trivia; she has a twin. Now thats an oriental sandwich I wouldn't mind being in the middle of. Just saying.
  9. They'll show the repeat this weekend, probably on Saturday. Check the ESPN schedules.
  10. Maybe, but it's part of a large Japanese phenomenon named "dekotora" dating back to the 70's, very much like the bosozoku subculture.
  11. Old news, and the topic has already been discussed at length. I even posted a workaround on how you can use your old green test.
  12. Got home and switched the tv on just in time to see Hami cross the line.
  13. Well most manual transmissions make a sound when gears mesh, so its hard to ascertain from your description if what you're experiencing is an actual problem or not. If you have any knowledgeable friends (they need not be experts, just familiar enough with manual transmissions), ask them to drive your car and get their opinion. I would advice against going to a garage by yourself, since newbies are easy prey.
  14. If you are immediately releasing the clutch upon gear change, a clunk is imminent. Otherwise, are you having trouble shifting into certain gears?
  15. If your current phone is less than 2 years old, I suggest waiting for the next iPhone to come out. Right now all the Android handsets are tripping over themselves in a bid to 1up each other in anticipation of Apple's next release. However, Apple really needs a hero product this time around because Siri wasn't enough the last time, and I'm pretty sure in 6 days time something quite spectacular will be released. Then, everyone else will start playing catch up towards the end of the year, thus prices dropping across the board for non Apple products.
  16. i have seen the odd 240 series A20, have yet to see a 260.
  17. +! for iffy MAF
  18. Definitely leaving my car behind this time for the Colombo Night Races. Thanks for the heads up Andrew!
  19. Sites like fuelly came about precisely because quite a few people religiously maintained fuel logs, and some bright spark had a light bulb moment and voila, a tool to track your fuel consumption appeared forthwith. Remember, necessity is the mother of invention.
  20. Merry birth anniversary so.....Cheers..?
  21. The size of the car remains the same, only the engine capacity increases. There's also a 2 liter version with all wheel drive and rear disc brakes.
