Change of province and Revenue Licence valididty
Its still valid but you need to get a document called 'nobandi patha' (whatever the hell that means) from the current licensing authority before you get the new license from WP.
Continuous excessive vibration in Drive mode with brake applied
Cleaning spark plugs is not something I would do. Misfiring can occur if the plug gap is more or less than the exact amount (its usually in 1/10th of mm's - ex. 1.3mm). If the gap changes while cleaning, the plug wouldnt fire properly. Also if you have an iridium tipped plug, it might break or loose its alignment, thus not firing properly or not firing at all.
- Damaged tire
Civic hybrid 2011vs insight 2011 vs gp5
I know for a fact that GP5 does 13-14kmpl in Colombo traffic. Unable to quote about the other two but I would assume they do slighly lesser.
Beware: Darley Road Accessory Sellers
Machan... go to Maradana Police even now and file a complaint. Maradana police buggers know all these tricks and they will round up all the kuddas and beat them up. Tell them they threatened you and you had to do it for self defense. Do you have the cargills bill? Show that as a proof. I have got work done in Darley Road in the past (things like tinting, fitting steering wheel cover, beadings etc.). Never had any issue. You just need to act like a man and they won't try to harass you.
- Post Whoring - Part 2
Al*i*nz Insurance
One of my previous cars were with Cooperative. I never had any claims so I can't comment on their claims process. But the agent who sold me the policy told me that Cooperative expects police reports for every accident (although they may say otherwise when then try to sell you the policy). Personally, if I get in to any accident, I will always inform the police and always insist on a police report. Law of Sri Lanka says so and people not abiding by the law is the cause for all the problems in the country. So I don't have any problems with Cooperative's (official or unofficial) policy.
Ceylon Motor Show 2017
Who owns that MR2? Not our notorious moderator I hope...
Engine gives a gurgling sound
@vimuthf Definitely pre-ignition knock. Good to know its sorted out. You have signs of gasket leak so don't ignore that,
The Ford Focus Thread
I already own the car for 5 years and 4 months now... and you ask me to stay away??? I never faced the said issue. In fact, for the past 5 years and 4 months, the only repairs I did on the car was replacing a bonnet lock and a rubber bush (apart from the usual battery, tyre, sparkplug changes). Edit: the article in question is about the Mk3 Focus, Mk1 Ecosport etc. The problem here is the gearbox is actually a dual-clutch gearbox, NOT an automatic gearbox. Ford should have never called it an auto gear box anyway. Dual-clutch is essentially a manual gear box with sensor-based gear changes. Jerking during gear changes of DCT boxes are high compared to auto boxes. Imagine changing gears on a manual car without pressing the clutch completely. That's what you get. Not a true defect but an annoyance.
Best Tyre Brand For Nissan B11
B11 had dozens of versions. Probably this was the Sunny that came with most number of versions. As I recall, B11 Sunny - came in at least 4 trim levels (LX, SLX, GL is what I recall) - in both petrol and diesel Laurel Spirit - more upmarket version of the Sunny. Laurel Spirit had another 3 or 4 trim levels Liberta Villa - 2 door and 4 door Langley - 2 door Pulsar and Pulsar EXA (Pulsar itself had two versions - 2 door H/B and 4 door sedan) California Wagon And my personal favourite - Sunny Turbo Leprix During this time, the Sunny name was so popular, even the vanette came as Nissan Sunny Vanette
Looking to buy my first car
Two of my friends independently confirmed that their respective Honda Fits do about 13-14 kmpl in normal Colombo traffic.Vitz should do slightly less than that (but not by much) Service cost for both should be more or less same. You cannot compare a (slightly) bigger hybrid car with a smaller ICE car. They have their merits and demerits. My choice between the two would be the Fit because Vitz looks so effeminate. But that's my personal preference.
Out of your list, I would suggest Hankook. They are pretty good. If they are too expensive, next options will be Federal, Nankang and GT Avoid the two chinese brands if possible.
Toyota Vitz 1000cc Vibration issue
Vitz owners dont replace mounts ?
Suzuki Hustler
There's nothing called Suzuki Gypsy. You are probably talking about a diesel converted Maruti Gypsy. Have you ever been in a 1960s Austin Lorry? That's the feeling you get when you drive a Gypsy. It vibrates like crazy. Having said that, I always liked to own a Gypsy myself. Like the looks of it. Will probably own one someday when I have cash to spare.
- windscreen repair
Here's my line of thinking. Gurgling sound generally comes due to evaporating water. Water could evaporate due to a leak somewhere. It could be the radiator core, hoses fitted to the radiator, loose/damaged radiator cap or there's also the possibility of a leak on the head gasket. It actually happened to me once and I realised the monkey at the service station hadn't tightened the radiator cap after topping up with water. If its the radiator cap, water level should drop drastically. If its through hoses or the core, the level of water drop would depend on the nature of the leak. Oil wouldn't seep in to the radiator in any of these cases. But the fact that you mentioned there's oil in the water suggests you might be at the early stages of a gasket leak. Let's do one more test. Accelerate and see if you are getting whitish smoke from the exhaust. Pls note that I can always be wrong. Pls also wait for some opinions from folks like @Rumesh88 @Davy
- windscreen repair
Check the radiator water level and let us know if its going down or whether there's any trace of oil in it.
Viva Elite for 5 years from now on
Sometime ago I used to advice Autolankans that the ONLY thing they should take a car to Auto M*raj is for washing it. Absolutely nothing else. After some recent publicized events, my advice is DO NOT take your car to Auto M*raj even for a wash. In fact, do not take your car anywhere near Auto M*raj. (If you wish to know my experience, the 'experts' at Auto M*raj poured in CVT oil to a normal auto gear box car which I owned, which eventually caused a failed gear box. The sad part was they are the 'authorized service agents' for Kia.)
- Preferred place of Wash for cars
about mini book
.... now what did I say earlier about locking the thread?
Two Types of Tyres for Car
Its Nexen N5000 Plus - whatever that means... IMHO, Maxxis is not a good comparison for anything when it comes to tires. Maxxis, along with CE#T are right there at the bottom of the food chain when it comes to road noise and comfort. and I suspect Nexen is keeping them company. (I am talking about the versions which are popular in SL). I had a set of Kinforest Chinese tyres on the car, which I replaced with the Nexens. The change was drastic and I regretted it on the first ride itself. The vibrations from the potholes on the road seem to be getting directly transferred to the spines of the ppl inside the car. The Chinese tyres were very comfortable with average performance but the flipside was they lasted less than 25,000km, which is ok for me because I prefer comfort over durability anyway.
I fixed Nexen tyres on my car few months ago (my car comes with factory fitted 17" low profile tyres which are very expensive).The tyres are bumpy and very uncomfortable. They are also very noisy. This is the worst decision I made.
