Sylvi
Everything posted by Sylvi
  1. Sylvi replied to MADZ's topic in The Lounge
    Komposiripala, My belated reply was due to a unavoidable cause. I will give you a link under for your listening. http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=9807 Please click left hand side top box Sylvi Wijesinghe.
  2. Members, I too have problem on one of my lines. For three weeks, because I have more lines the regular line every one contact me, is diverted to a another line. I have number of SLT lines with me. Three ADSL lines. It is a big fraud by there SLT management. Once we formed a forum and represented matters to TRC. Very lethargic government institution. Use CDMA connections all my out going I use them, charged to seconds. Any problem one to one replacement. IDD calls also I have found is cheap than SLT. Can use any where in the Island. If you go on a trip but it is not allowed by Authorities. No police men will check they are not aware of same. Even SLT Service staff use CDMA telephones on their Vehicles. Sylvi Wijesinghe.
  3. Members, I have seen a mirror on top of the rear to watch the distance when any one reverse his vehicle. Can watch the wide angle mirror from your rear mirror inside the car Sylvi Wijesinghe.
  4. Dhanushkapg, As komposiripala says replace the hose. Do under if not. If you do not want the heater to work it is best to remove the hose and block the heater water out let. At the same time you have to block the other side of the inlet also. There are end hoses (one side is blocked like water end caps) You can get from motor spare part shops. If you are unable to handle this you can get a Mechanic to do same. All those heater hoses are rubber based canvas lined hoses. Therefore you can put some rubber tube patch solution or some rubber based gum.(Clean the hose water leak hole well) Paste small rubber tube part on the hole. Small patch like, what bicycle repair shops to do a tube patch where the air is leaking use to do. dry same After few minutes rap another cycle tube cut in to 6 inch long ½ inch wide tube rap around the patch then at the end you can tie the end with a wire or some twine thread. Sylvi Wijesinghe.
  5. Ari, Get a Auto knowledgeable Electrician to check your battery terminals main connecting battery wire connections. As well as all connections to + & - battery leads. 2 battery terminals(sulfate) have white stuff or green stuff. Later follow the main + wires connecting the Ignition switch and all other main connections to important accessories. It is most probably on main lead wire. Because entire system gets cut off. According to your post. I do not think you have a Alternator problem. Sylvi Wijesinghe.
  6. Sylvi replied to Le Sabre's topic in General
    Members, All members posted had given their different idea about the past. Sri Lanka no one can stop forward reaction what JRJ activated in that era. We had benefits, including younger generation under 30 years of age. Hope future of Sri LANKA AND generations to come will prosper. So that this blessed island named. Pearl of the Indian Ocean. Back again. Sylvi Wijesinghe.
  7. Sylvi replied to Le Sabre's topic in General
    Members, MasterDon. I agree to your post. Lands have come down little. Later they will increase. When three letters was elected on year 1977 the prices of lands as well as daily workers wages and all other goods were increased. But they brought to new life to Sri Lanka. Prices will go up in future. Sylvi Wijesinghe.
  8. Sylvi replied to MADZ's topic in The Lounge
    Charith H Jayasinghe, There are many things you can watch on the web. Like all telephone conversations of GSM. Overseas Police fire rescue operations conversations. Sylvi Wijesinghe.
  9. Members, Creator of Asia Wonderland regime is creating history all above some few members had mentioned. Thinking will be in power fro few more decades. Sylvi Wijesinghe.
  10. DevicaC, Kleen Park has a Solvent like a paste try them.Rupees 7500/=. Sylvi Wijesinghe.
  11. bat simpson, I do not think anyone imports this type of Batteries to S L. Due to the cost. Singapore you can try them.. I know few campers using in S L 4 12 volts Batteries OF 90 Amperes to get higher amperage during the full night as well as day time. They had few charging problems. I correct them fixing modified Alternator to give high Amperage forom the running engine. To battery get discharged to 75%. A meter to monitor the discharge is about 50000/= Rupees. Only other way is to use a hydrometer. Deep cycle batteries are efficient to your requirement. Lead acid batteries, when they drop below 50% have to use a external charger to recharge them. Can you give discharge amperage of your equipment. Please log into this link I do not know their quality. http://dir.indiamart.com/impcat/deep-cycle-battery.html Following batteries I have experience in USA. http://www.usbattery.com/usb_index.html Please contact me for further clarifications. Sylvi Wijesinghe.
  12. Komisiripala, Yes Sir, I do agree to your post. I only wanted to say they were few professionals who livied in our country. My intenction was not to compare their capabilites with others. Sylvi Wijesinghe.
  13. Dear Rumash88, I did that logingig to other thread by a mistake of mine. I requested the moderators to remove this post of mine from that thread. Any how may be due to my old age I do thiese mistakes, of this nature. Also on the A/L lforum that was the only new thread on the web. Later I realised my mistake, this is the reson I posted my request. I hope my answer is sufficient cause to your post. Sylvi Wijesinghe.
  14. Members, Yes what don had mentioned on his post is correct, all machines shops do not recondition their machines’ in every 5 years or so specially engine rebuilding machines. Machine manufactures recommend carrying out the calibration test of their machines periodically. I do have Myford lathe it is about 45 years old, machine when they sold same to me in UK. They gave me two sets of bearings for the chuck shaft to be changed after testing. Every 3 years. Do testing by Lathe work any shaft 1 foot long, for me to notice any short comings on the surface of the shaft surface uneven cut. At pressent they have Electronic Machines are there to test the accuracy of lathe and all machine shop equipment. Normal old practice is after every Crank shaft regrinding, has to take off the uneven surface of the grinding wheel. To take the oval of the grinding wheel running a tool to get the correct surface of the grinding wheel. I do not think most machine shops do engine rebuilding, any calibration of their engine rebuilding machines periodically. Failure of rebuild engines are mostly due to this method is not practiced by the engine rebuilders. Sylvi Wijesinghe.
  15. Moderators, I realized later, I have posted above post to a wrong thread Please remove this post. Sylvi Wijesinghe.
  16. Members, Reply to cefero A33s, and my comments,for the post by member. First of All thank you for your reply about Professionals in our blessed country. Your last post. You have given the correct answer to that post. Made by a member. No one can question Professionals charges, they do study hard and become genius in their field. I Remember our different field genius Sri Lankans who has gone to their eternal rest. I post and their names of few of them. Late Dr. P.R. Anthonis surgeon was a leader in surgical operations for thousands in Sri lanka Late Mr. RAAMPALA was an engineering field. His era was called the Golden time of our railways. Late “Deshabandu” Dr.A.N.S. Kulasinghe. Pre-stressed concrete originated in Ceylon. I do not want to mention many more names. Sylvi Wijesinghe. I realized later I HAVE POSTED TO WRONG THREAD.
  17. Members, Reply to cefero A33s, and my comments,for the post by member. First of All thank you for your reply about Professionals in our blessed country. Your last post. You have given the correct answer to that post. Made by a member. No one can question Professionals charges, they do study hard and become genius in their field. I Remember our different field genius Sri Lankans who has gone to their eternal rest. I post and their names of few of them. Late Dr. P.R. Anthonis surgeon was a leader in surgical operations for thousands in Sri lanka Late Mr. RAAMPALA was an engineering field. His era was called the Golden time of our railways. Late “Deshabandu” Dr.A.N.S. Kulasinghe. Pre-stressed concrete originated in Ceylon. I do not want to mention many more names. Sylvi Wijesinghe.
  18. cefero A33, First of All thank you for your reply about Professionals in our blessed country. Your last post. You have given the correct answer to that post. Made by a member. No one can question Professionals charges they do study hard and become genius in their field. Best Wishes, Sylvi Wijesinghe.
  19. Members, I read all above posts. I am in industry for few decades. Please understand today we do not have very understanding and knowledgeable mechanics in industry. Almost all of them are very young people. Last few decades plenty of new technologies developed. Therefore you need to scan a unit Scanners and analyzers. Without them no one can do a correct fault analyses. Electronic parts most cannot be repaired have to change to new ones. Like good old days, cut and chop mostly mechanical parts take from another severable unit and fix same to correct a faulty unit. That is how the old parts dealers existed early and exists today. Therefore some mechanics exploit their costumers by this method. Delaying jobs having parts with them say had to buy out side. To earn few Rupees they inform the customer all sought of lies. Coming to Mr. Mario Dias I had a conversation yesterday with him over the telephone. As for him UDA wanted that property they wanted to develop that area with removing all slums. Therefore he shifted to his home to do repairs. He admits about comments on A/L towards him. I did not want to talk more on that subject with him. Once I recommended him there were negative post replies. I did not recommend him after that. His name came up on this thread I posted a reply. Criticizing is one common thing in the world. I was objected to my charges since I joined to this forum. I am the only person for 21 years who existed in active uninterrupted service in this modern Automobile technology. I deviated from my original Electrical maintenance because I felt this service is necessary for our Automobile community. Medical profession did not have all advanced instruments and other scanners early, mostly they depended on X-ray reports. Good luck for all A/L forum members. For the comming season. Sylvi Wijesinghe.
  20. Charith H Jayasinghe. I did as I said in my early post. I find it is a very good white bulb. Not so bright as HID. Good for town running well lighted roads. I do not think this light will give required brightens in dark roads where you want long distance sight. I am planing to build for that long distance 2 LED bulbs with 50 watts fabricated to a reflector. Will inform when I do same very soon. LED bulbs consume very little current. I have all Led bulbs in my house. CEB Electricity bill came down 1/3 of CFL Bulbs. Cost of LED bulbs are coming down daily. Sylvi Wijesinghe
  21. Sylvi replied to DNP's topic in News & Updates
    Super - Natural, I wanted to say the past. You are doing your entrusted duty. I hope? OK as you wish. Thank you for your reply. Sylvi Wijesinghe
  22. Crosswind, I too do not use supper glue. their are special polymer resins to fix that. With no marks will remain after.Please Read under. http://composite.about.com/od/whatsacomposite/a/What-Is-A-Polymer.htm Sylvi Wijesinghe.
  23. Sylvi replied to MADZ's topic in The Lounge
    Members, You all can watch on the web under flight Radar tracker if they leave from our country on registered Aircraft's. All who came to S L leaving our Island. Flightradar24.com - Live flight tracker! If the aircraft is not registered like military aircraft's and V*P.This system do not have way of tracking.Only way to track them by listening to their messages. To use a decoder with a scrambler which will take some time for the listener to get the correct method. Sylvi Wijesinghe.
  24. Sylvi replied to MADZ's topic in The Lounge
    Members, Not only Daren. His farther Mr. ######## Weerasinghe was also in motor sports. Sylvi Wijesinghe.
  25. cefiro, Mr. Mario Dias is also very good at automobile tuning Old school Auto mobile Engineer. Thank you for your comment any time contact me and my gate is open for all Automobile users. Sylvi Wijesinghe.
