Everything posted by Sylvi
A Good Place To Repair Phones ?
Please refer to the post by Kalana only person I can say is this Mr.R Wijgunawardana. His contact number is on that post. Sylvi Wijesinghe.
Wheel Alignment
Miniace, You are correct as for your post that wheel alignment problem will not solve by tire rotation. Wheel alignment advise was requested by the topic starter himself and few members gave their experiences Tire rotation is necessary for equal tire wastage. I only advised the topic starter to do that. Your post gives lot of explanation on the subject it is a very educative post Sylvi Wijesinghe.
Galant 4D68 Engine
's_ampath', There are so many possibilities for gasket to leak,(1) when the radiator is blocked(2) Water is leaking to engine head through a crack on the head. (3) Water line block,can be due to faulty thermostat valve. (4) head is not seating properly on the engine block. Did you check your engine oil. there is no milky color on the oil. Get a good mechanic to examine the head properly or take same to M/s, EDIRISINGHE BROTHERS and request them to examine the head for any cracks tell them that you had changed number of gaskets. After examination let them reface the head. At the same time remove the radiator get it cleaned at a good radiator cleaner by removing the bottom tank of the radiator. If there is no problem in the radiator then definitely problem is the head. Give the feed backs of your problem Sylvi Wijesinghe.
Engine Removeal Toyota Liteace Cr42 33C Engine
'Hoss', I have removed few engines by raising the vehicle then lover down the engine to a wheel tray and pull the tray to do the repair. Sylvi Wijesinghe.
Is It Possible For Convert Rear Drum Brakes To Disc Brakes
'Strikeee' Yes nothing is impossible if you prepared to spend money. for what reason you want this change. It can be done, today no mechanic will want to do a modification like what you need. I have converted disc from hub brakes for better efficiency. Modified the hand brake to center near gear box. It is a very time consuming job All garages will want to do a job with new spares and earn their money. There will be other members who know experienced mechanic who will undertake to do this modification. Please be patient for other members response for your request. Sylvi Wijesinghe.
- Tire Rotation With Different Branded Tyres
Need Help To Troubleshoot Radiator Boiling
'Crosswind', Do you use coolant or any other water for the radiator. There can be a radiator block. Did you check up your radiator heather control thermostat. Above are the things I can say about your problem to examine. Do not use your vehicle get immediately a mechanic to inspect your problem, if not you will end up with so many other problems in the engine. Sylvi Wijesinghe. Sylvi Wijesinghe.
Members. I got this from the web. Tire Replacement, Rotation and Alignment Tire Air Pressure Maximize your tires’ performance and durability by monitoring and maintaining correct air pressure. Air is a gas, expanding when heated and contracting when cooled. For most of North America, fall and early winter are especially important times for checking tire pressure – as the ambient temperature falls, tire pressure goes down. A good rule of thumb is that every 10 degrees Fahrenheit temperature change, tire pressure changes about 1 psi — higher as temperatures rise, lower as they fall. Also, check your vehicle’s owner manual for recommended tire pressure. Under-inflated tires can cause: o Premature or irregular wear o Poor handling o Reduced fuel economy Over-inflated tires can cause: o Unusual wear o Poor handling o Reduced fuel economy Checking Air Pressure Check your vehicle’s tires at least once a month when the tires are cold (let the vehicle sit for at least 3 hours). Look in your owner manual for the recommended tire inflation for your vehicle. Use a quality gauge. Don’t eyeball tires — radial tires can look fine even when they’re under-inflated. Be sure to look for objects that have become wedged in the tread — they can work themselves further into the tire and cause air loss. And don’t forget to check the spare! Since each tire performs different tasks (such as steering or front- versus rear-wheel drive), tires wear at different rates. Rotating your tires at recommended intervals extends their useful life and achieves more uniform tire wear. It’s important to rotate your tires according to the correct tire rotation pattern. Front tires encounter different tasks than the rear tires. And a front-wheel-drive car’s tires perform different tasks than those on a rear-wheel-drive car. Your Owner Manual specifies which rotation pattern is right for your vehicle. Your vehicle’s front and rear tires may also use different pressures — make sure to adjust individual tire pressure to the recommendation for each wheel position. See your owner manual for recommendations. Wheel Rust or Dirt Rust or dirt may not allow proper tightening of the lug nuts and a wheel may loosen over time. When you have your tires rotated, be sure to remove any rust or dirt from places where the wheel attaches to the vehicle and torque the wheel lug nuts to the specification in your owner manual. In an emergency, you can use a cloth or paper towel, but be sure to use a scraper or wire brush later to remove all rust or dirt and torque to specifications. Also, remember that rotating your tires won’t correct wear problems caused by worn mechanical parts or incorrect inflation pressures. Wheel Alignment & Tire Balance Scheduled alignment and balancing are not needed, since your vehicle’s wheels were aligned and balanced at the factory. But if you notice unusual tire wear or that your vehicle pulls one way or the other, the wheel alignment may need to be reset. If you notice your vehicle vibrating on a smooth road, your wheels may be out of balance. A tire that is out of balance often affects ride quality and can shorten the life of tires, bearings, shocks, and other suspension components. A speed-dependent vibration — becoming noticeable around 45 mph and increasing as speed increases — is probably balance-related. Tire Alignment Alignment is critical for ensuring that you get maximum wear and performance from your tires. Poor alignment results from your car's suspension and steering system becoming out of adjustment with each other. The biggest indicators of your vehicle being out of alignment are pulling one way or the other as you drive or unusual tire wear. Improper tire inflation can also cause unusual tire wear. Your vehicle may have both front and rear wheel alignment specifications. Your dealer can recommend the alignment type that's right for your vehicle. Sylvi Wijesinghe.
What Is The Best Car In This Price Range?2.3-2.9 Million?
'LashNeo' This car had 25800 Kilometers on the meter it is definitely altered by the seller. This car was bought imported by a reputed car dealer in colombo 05. After using few months the owner had to change all engine mounts at car mart spending more than rupees 50000.00. Later he had noises on the suspension. I requested him to go and test the shock absorbers. all for was bad only 30% good. Then he changed entire suspension shocks and other related bushes brakes also attended with Steering related joints etc. Which cost him what I said on my early post. Engine did not give any trouble later he got rid of it and went in for a Honda. Sylvi Wijesinghe
Good Place to Paint The Car
'Reckless', You are correct on your post that is the reason Leasing company want reputed agent to give a valuation certificate. For a used vehicle or a unregistered vehicle one leasing company has their own appraiser who examine before they give the lease. Some vehicles are directed to me to give a inspection certificate if he find some fault on the service what I do. To attend to same with a warranty letter. Sylvi Wijesinghe.
Mitsubishi L200 - Reverse Gear Gets Stuck!
isam, there are different opinions for your problem. if you want to verify the gear box you can before do any thing try as under. Get a Mechanic to remove the propeller drive shaft on the gear box side and start the engine then engage normal way. First to front drive then to reverse drive. Do not accelerate the engine. Still engine try to stop when you release the clutch peddle it is definitely on the gear box. Comingto brake issue related to your problem. If brake on one way that means when you drive forward if there is no problem according to your post. You raise one rear wheel start your engine and engage your reverse gear try to release the clutch if engine stops. Then raise the other side lover the raised side try as early if engine stops it is not on brakes. When you raise one wheel and engage a gear rear raised wheel should turn. Or else you can raise both rear wheels put differential on logs so rear wheels will not touch the ground. you can start engine shift your front gears and try to see the wheels are turning. Try reverse gear again again. if engine try to stop this also shows that the problem is not on the brakes. At last you can turn the wheels by hand and to clock and ant-clock rotation to find any friction both wheels raised from the ground this will give you enough evidence that it is not on the brake mechanism. Above is my experience some members will give a different opinion. Sylvi Wijesinghe.
Hard To Put It To First Gear
'FreakSL', What is your car, normally for what reason you want to use 1st gear on a moving vehicle. if you have full synchronized gear box. 1st Gear you can shift at 20 kilometers.If you release the clutch at that speed your engine will speed up and car will act as you step on your brakes. Shifting down gears can be used if brakes fail. Now days drivers do not use gears to slow down the speed of the vehicle they depend on brakes. Drivers use low gears to come down on hills instead of using brakes. Some vehicles have exhaust brake. Sylvi Wijesinghe.
Members, If you change the color you have to inform RMV and get a endorsement on your CR. but it is not done in the past twenty years. In 1970s I used to inform whenever I changed the color had to pay like Rupees 50.00 and show to RMV for the endorsement on the CR book. Because inflow of vehicles increased most owners ignore this. I too had done this for my vehicles without informing the authorities. Insurance companies do not take a notice of this it has become a practice now. Sylvi Wijesinghe
Wheel Alignment
Kalinga, You as a heavy user more than 5000 Kilometers for a month, had given your experience and opinion to the members of the forum. I appreciate your post. AS a person in automobile service industry. Sylvi Wijesinghe.
Buying A Diesel Vehicle
Members, Diesel engines some start without preheating in the morning. some need to heat once or three times. This happens due to low compression. The compression build up inside the cylinders are not enough to ignite diesel. Some members will have a different opinion what I post under. I know a person who used to inject Kerosine oil 3 CC into the air intake with a injection syringe in the morning for a quick start. That worked till he sold his Peugeot car. That car had after 40000 miles cold morning start defect. Due to low compression. Sylvi Wijesinghe.
Vibrate
'kalinga', There is some truth what you say one cylinder may be not working at low RPM. due to faulty plug or some other problem on that cylinder. Bad engine mounts also contribute for vibration. Sylvi Wijesinghe.
DHoRK, Go for a Honda spares are little bit expensive but good cars. Do not go for a Mazda because they give problems with their suspension, relative of mine bought a Mazda and spend another two hundred thousand rupees. Toyota also good easily you can sell them back. Sylvi Wijesinghe.
- Ist 2002/2003 Medel-How Best This Vehicle &performane
'isam', I too suspect as The Don says, it is in the gear box. May be reverse gear wheel get engaged with some other gear wheel that locks your gearbox. This problem is a very unusual thing, inside the gear box. as your one is a manual transmission gearbox, it is easily rectified by a good mechanic. Before any other problem happens immediately get your gear box removed and examine the gear engaging system and do the necessary repair. I don't think it is not necessary to touch your Clutch mechanism side because you can engage forward gears without any problem. You need not go for a new gear box. Sylvi Wijesinghe.
Oil Leaking To Radiater
LancerL, There are epoxy fillers they can be used on different conditions. I dont think that canbe used on a compression area as your head is cast iron it is very difficult to do correct a welding. Welding cast iron has a different prosess. If there is space you can drill a bigger hole and fix a bolt which will fit in tight. Must examin personally and advice you for your head problem. Try to get a complete engine. Sylvi Wijesinghe.
Vibrate
'kmcsb', Most Mechanics understand carburetor engine problems. easily repairable. Get a opinion from a good mechanic for your vibration problem. Sylvi Wijesinghe.
- Ac On 4Dr5
Uneven Break Shoe Wear
'luckey007', I do not have any person to inform you immediately who do repairs only for brake systems. I have a good engine mechanic he do brakes also I will give his contact number you give a call to him. Get a complete brake overhaul front and rear as your master cylinder is OK you need not do any thing on that section. His Name is Shelton 5024072 please get a quotation explain your problem first he is a very senior Mechanic who has lot of experience. You request him to call me I will instruct him, first test your front pad problem and then do the job correctly. Sylvi Wijesinghe.
- Uneven Break Shoe Wear
