kmcsb Posted January 5, 2012 Posted January 5, 2012 last two days i feels ,when i start the engine car gets vibrate unusually...having 94 carb model..it normally rasibg a few minutes and back to normal beacuse of auto choke feature..i thnik its normal...(discussed last topic).. but question is when it comes back to idel (normal) feels getting vibrate..what do u thnik guyzzz????? is it 4m the choke or???? is it a choke porblem should i need to replace or can it repair??? hw much it will be...??? should i need to go honda mechanic like upul or can be done from normal garge guy.....??? plz help Quote
Sylvi Posted January 5, 2012 Posted January 5, 2012 last two days i feels ,when i start the engine car gets vibrate unusually...having 94 carb model..it normally rasibg a few minutes and back to normal beacuse of auto choke feature..i thnik its normal...(discussed last topic).. but question is when it comes back to idel (normal) feels getting vibrate..what do u thnik guyzzz????? is it 4m the choke or???? is it a choke porblem should i need to replace or can it repair??? hw much it will be...??? should i need to go honda mechanic like upul or can be done from normal garge guy.....??? plz help 'kmcsb', Most Mechanics understand carburetor engine problems. easily repairable. Get a opinion from a good mechanic for your vibration problem. Sylvi Wijesinghe. Quote
kalinga Posted January 5, 2012 Posted January 5, 2012 last two days i feels ,when i start the engine car gets vibrate unusually...having 94 carb model..it normally rasibg a few minutes and back to normal beacuse of auto choke feature..i thnik its normal...(discussed last topic).. but question is when it comes back to idel (normal) feels getting vibrate..what do u thnik guyzzz????? is it 4m the choke or???? is it a choke porblem should i need to replace or can it repair??? hw much it will be...??? should i need to go honda mechanic like upul or can be done from normal garge guy.....??? plz help can be due to a low RPM or a bad engine mount can be many reason or even maybe the car running on less then 4 cylinders in ideal. take it to a honda guy if can, else take it to a normal micanic. but always get a 2nd opinion. Quote
Sylvi Posted January 6, 2012 Posted January 6, 2012 can be due to a low RPM or a bad engine mount can be many reason or even maybe the car running on less then 4 cylinders in ideal. take it to a honda guy if can, else take it to a normal micanic. but always get a 2nd opinion. 'kalinga', There is some truth what you say one cylinder may be not working at low RPM. due to faulty plug or some other problem on that cylinder. Bad engine mounts also contribute for vibration. Sylvi Wijesinghe. Quote
NahoY Posted January 8, 2012 Posted January 8, 2012 and I thought this thread was going be on such a different topic ...... 1 Quote
Duminda_CR Posted January 12, 2012 Posted January 12, 2012 check plug wires as well.. one of them might be loosen or some thing. but better option is checking with a garage guy since there may be so many problems which cause for vibration.. as so many guys said it might be a bad engine mount even.. Quote
