Everything posted by Sylvi
Happy Birthday Madz!
Happy birthday Madz and many more birthdays to come to you Sylvi Wijesinghe.
Wheel Alignment
kmcsb, Members had given you the best advice. One more thing you have to change your tires front to rear and rear to front. Rotate tires for even wastage. Sylvi Wijesinghe.
Tata Nano
Members, Bajaj two three wheelers jointed to gather, one Srilankan Automobile engineer designed a four wheeler. It was on the drawing board he showed all designs of same to me. 4 people can travel comfortably. Later he got all into 3D, to a computer and made a complete 4 wheeler with the same frame work of the two three wheelers. Front two Wheels had coil springs with a shock absorber in the middle. rack and pinion searing wheel. Front was modified with same Windshield steering to RHD. Soft hood brakes for all four wheels gear with a shift stick. Same engine same size wheels. two large doors. He later migrated to a developed country for better prospects. Sylvi Wijesinghe.
Oil Leaking To Radiater
name='LancerL' timestamp='1325675671' post='190356'] Please help me guys. I'm in a big trouble.. My engine is Lancer Saturn A75 [/qu ;LancerL, Did you take the car there or removed the head and wanted them to reface same. By looking at a problem no one can come to a conclusion without removing the engine head. Who said at Edrisinghe that the water line is damaged. Some time back they used to do metal-lock on engine heads and stop water leaks, request them to do same they have the technology. Refer following link. http://www.locknstitch.com/metal_stitching.htm Above system charges are high. as it is a specialized job. There are plenty of engine heads you can buy at Delkanda or try at Kurunagala old spare parts shops. Sylvi Wijesinghe.
Alignment Problem
'The Don', You mention of bolts to adjust camber is it oval shape bolts. I don't think you can buy them here, have turn out according to your requirement. Like to have your comments, it is very educative to the members of the forum if you explain more of your experience in camber adjustment. Sylvi Wijesinghe.
Uneven Break Shoe Wear
'luckey007', Lift your car front and get some one to apply brakes very little, ( press the paddle slightly) then examine how the action of the front brake system, if one wheel have more tight than the other wheel if so there can be a some defect on one side supply of the brake fluid. that side is the side have more waste on the pads. You have not noticed any pulling to a side according to your post. Wasting one side means there is some what more friction on that side. Your first post confirms that you had refaced the brake disks. some times the left side may have little rough surface than the other side AS don said look into the brake disk if there is any rough marks on the disk surface your pads will get wasted fast on that side. You did not notice any smell or heat from the side the pads had got wasted when you drive a long trip. One more test you can do brake oil pressure test on the front wheels. for this you have to have two pressure meters connected to disk brake supply line, lift the front, Start the car and apply the brakes then test the pressure on both wheels it takes little time. Both sides will have to give same pressure reading. I have done this system during the time I did mechanical repairs. for front and rear brakes separately. I did all practical methods which was very successful. It is very difficult to come to a conclusion without examining the car front brake system. Sylvi Wijesinghe.
How To Find Out The Genuine Mileage Of A Vehicle
'blkr6', Your advice is correct. Very few Mechanics have compression meter to do a test. Most of our Mechanics are trial and error mechanics. They keep on changing parts which are not necessary. As they are unable to detect the fault at once. When you change parts automatically the fault is eliminated. First thing when they remove a Self starter motor for a service what they do is change Brushes and Bushes. Which are serviceable.they do not know to test brush spring tension. If you change the clutch plate they change the pressure plate and clutch thrust racer which is serviceable till the next clutch plate change. No repair garage have proper equipment to test the faulty part. Sylvi Wijesinghe.
Ac On 4Dr5
'Nishan.dj', You have got the 24 volts DC compressor that is very good. If not you have convert normal 12 volts DC compressor the clutch coil to 24 volts, you have gone over the first hurdle. Next is to get a passenger compartment 2 units plenty of 12 volts used ones are available at Delkanda. try to get 24 volts units. Most units are from Toyota and Nissan vans some used ones are 24 volts DC. IF you cannot get 24 volts it is OK you can have 12 volts two units. Get a center tap from the Battery to power the fans. Better if you buy the new units they will cost around Rupees 20000.00. or more. I bought only one unit new to fix under the meter panel that cost me Rupees 8000.00. New from Colombo 02 A/C shop. They had the hood type also, that was12 volts they quoted Rupees 15000.00. My engine cannot handle big compressor due to low engine capacity. I have fitted a big fan on the hood of the vehicle so that rear seat passengers will be comfortable. Keep the forum update of your A/C fitting project. I like members like you take a challenge to do something new for a vehicle. Sylvi Wijesinghe.
'luckey007', As CARBON B4 had advised to you (get the calipers checked out from a good place before you replace the pads). I will like to suggest get a complete brake system checked up including rear wheels removed and cylinders cleaned if the mechanic think you need a brake system flushed do that also. Change with new oil completely. I had endless problems using a new vehicle without attending to brake system for 25000KMS entire system failed with brake binding had to replace lot of spares with a cost of 15000.00 rupees. Always better to check brake system annually or 10000 KMS. FOR SAFETY. Sylvi Wijesinghe.
- Ac On 4Dr5
Ac On 4Dr5
'Nishan.dj My address is on the post name, contact numbers are 2573690/0712222420. [email protected] (or) [email protected] Did you get a 24 volts A/C UNIT if not you have to rewind the clutch coil of the compressor to 24 volts. Fans can go in series. First of all get the compressor and the double ac units mounted. before you do any thing. Please inform what is the unit you got for fitting a original 24 volts. or 12 volts. Because it can be 12 or 24 volts the person who fix the unit has to do it carefully. Sylvi Wijesinghe.
Alignment Problem
'tglk', Thank you sharing your experience with "Nalaka" I have not had any problems with them. Next time must try back again Wellawatha Car Care.This place is closer to my place. Sylvi Wijesinghe.
Ac On 4Dr5
'Nishan.dj', Yes definitely there will be a more draw of amperes from your system. For two A/C fans and A/C compressor clutch coil. Do not worry fix the duel A/C. Alternator will give you enough current for your draw of current for all your Equipment. if you have an problem please do drop in at my place I will check your charging system and advice you accordingly. Free of charge as I do not do any more Auto electrical systems, but have all equipment to test and the know how. Please inform what is the amperage of your Alternator. your system is 24 volts DC. Do you have the brake vacuum exhaust-er unit fixed to your alternator back side. With oil pipes attached. Do not hesitate. Go ahead with your plans. Fix a duel A/C unit and enjoy driving with your family. Sylvi Wijesinghe.
My Experience When Importing Car From Japan
'KMG', As I have told early opinion differ from person to person. You are fortunate to get a good agent in Srilanka to handle your import to your satisfaction. Clearing charges Rupees 18000.00 is very reasonable, as at the moment rate vary from 20000.00 to 25000.00 Rupees. How much did you pay for their charges as handling? Every buyer is not educated and do not have computers to access to Auto lanka to know all what prospective buyers are discussing. So most of the buyers had to go for vehicle dealers to buy vehicles. if not delears are existing. There are thousends living on this industry. If I am not mistaken Indian vehicles you cannot buy used in India in srilanka so you have to buy new ones through A*W. I don't think India allow to export used vehicles out of their country. Sylvi Wijesinghe.
Ee110 Burning Oil
'raveeJaya', You are perfect correct by your statement, must stay by the side of the car then job will be done quickly, no extra charges will be added to your bill. I came to know Mr. Mario Dias because he wanted my services and I did same to his satisfaction few years ago. He said himself, a motor garage owner. When he was on my work shop a relative of mine rang me up and wanted help as she cannot move her car and it is struck with a wheel problem on the road at Bullers road near Radio Ceylon junction. I requested him to help her on the way. Which he did very satisfactory by using a breakdown truck taking the vehicle to his garage repairing the differential the bill was few years ago Rupees 15000.00. She was informed the problem and approximate cost by telephone. Which was OK as for my relative car was driven to Mallasekara mawhta colombo 07, handed over in four days. After the job was completed without taking a cent the bill was collected after few days. I have heard about him before he came to me from leading motor vehicle importers as a very good tuner of engines and he use to solve their ECU problems as well as electronic problems of their imports. Later I have directed few of my friends to his work shop. they were all satisfied for his work.Although charges were high. As you said charges are high, may be he had billed you for a job what he has not done. You trusted him and left the vehicle on his hands to do the job. If you were there you would have saved few thousand rupees. Every day we study people and lessons.Please note all five fingers are not same. Even I was accused in this forum for quoting rupees 15000.00 for a job about a year ago, Which the same member did that job on my advice by himself with elbow grease. I do same with a machine. Today a good mechanic do not work less than rupees 1500.00 for a day helper is about Rupees 800.00. What about other overheads considering all this charges a person have to charge high to do a job, as you say billing for what is not done is not correct. you will think twice to go to the same garage again. Sylvi Wijesinghe.
Mitsubishi - Lancer Gl
'Iroshw', There is another thread active at present on this forum regarding fuel savers please read that. Better put your money to FD rather spending for that electronic unit. Sylvi Wijesinghe.
Truth About Fuel Consumption Circuit Which Increase 20%-30%
Irosh, This subject was discussed before long before this electronic came the magnets was existing and there is a USA patent for same. I being a automobile technician for few decades done lot of experiments on fuel savers in Srilanka but non of them give the performance what they advertise. Tried the electric magnetic 12 volts DC USA patent which gives very high magnetic affect on to their specifications to the fuel line but it was also a failure. Contacted the Dehiwala people who advertised this electronic device the say they have fitted to few thousand cars. I said i will give a bank guarantee of Rupees 5000.00 and a official agreement signed in front of a lawyer to pay full amount of rupees 5000.00 at the end of 30 days. All other expenses on my account. If my fuel figures improve 10%. which I keep all records of my way of pumping petrol to my vehicle. They were not agreeable to that. I have to pay up front the cost in full cash and I have to tryout. No refund. Legally they do a wrong thing by conditional sales, if some one complains to consumer protection authority then they will have go before courts. I appreciate member terrabytetango's: Post That's nothing, I know a guy who turns lead into gold and water into gasoline. I am posting through experience nothing of this Fuel savers will work as it is advertised. One thing I have to mention I have tried Acetone recommended dose to engine it gives about 1 Km for liter of petrol more but in the long run can ruin my rubber parts if the fuel line so I use only once a month when ever I go out of Colombo for full tank. Sylvi Wijesinhe.
- What Are The Good Quality Car Battery For Vits Scp10
Problem With Air Filter In Fb 14
'The Don', This member has given you a advice you follow his advice first before you do any thing. Sylvi Wijesinghe.
'Malkoba', As for my knowledge when the engine is under compression this happens Normal air filters do not have oil, get the engine compression checked by the agents. I do not know do they check the compression, because it is done totally different to Petrol engine. if any assistance is necessary you post to the forum. where is your location. Sylvi Wijesinghe.
Alignment Problem
'Gyiman', Re your post,Car Care you have not given the location. Is this is located at Wellawatha on a by road before you come to junction when you go towards Dehiwala. I have got their services they were good but later I found the mechanic who used to do my work was not there. this is the reason I shifted to "Nalaka". Sylvi Wijesinghe.
Ee110 Burning Oil
'raveeJaya', As your post says he said he did a tuning and used a chemical. What was the cost. I want to know the cost and are you happy with his work or not? Keeping the car for three days is bit too long it is one days job. So that for future reference I can recommend his services. Sylvi Wijesinghe.
Registration Plate Size Problem
'Dhanu DaGreat', You did not get the new plates up to now.Get your plates first. they have a slandered size Old Plates last year RMV gave front is 20.5 X 4.5 inches rear is 11X7.25 inches. Your measurements are in CM, I have measured in Inches. The given size by you is small. I got the measurements (the size) from the two vehicles what I have in my home, the both have the same measurements. Once you get them,if there have any difference in size complain to RMV. that you cannot fix them. I don't think you will have a problem. Sylvi Wijesinghe.
Air Bubbles On The Radiator
'The Don', I agree with you. When a engine head is refaced not much of metal from the head is removed only the cleaning and little bit of leveling. Sylvi Wijesinghe.
Alignment Problem
Try "Nalaka" at colombo 02 next to Richard Peri's show room. Please read following link. http://www.ozebiz.com.au/racetech/theory/align.html Sylvi Wijesinghe.
