Dinukap4
Everything posted by Dinukap4
  1. So as the topic says Do we need a special sort of permit to bring down Lorrys/Trucks ? Is there a Year/Engine capacity restriction as there is for cars ?
  2. Try, because I went to jj lanka today to get 4 tires and I saw a bunch of wheel spacer with them.
  3. Did you try JJ Lanka Wheels ?
  4. LOl No I was told they were strictly not for sale! And some more
  5. Well I didn't Find a Thread that was For Classics on AL So here we go. These are some shots I took at Rajagiriya-
  6. I would start with checking the Spark plugs and the spark cables.
  7. To join City and guild what are the qualifications needed ? How many O/L subjects should you be passed etc.
  8. I hope his wife doesn't drive it
  9. http://autolanka.com/ad.asp?ID=106645
  10. In my Toyota Aasin Carb there are 2 Solenoids one in the Primary and the other in the secondary So the question is when in ignition does the solenoids get +12V from the start to till the engine is shut down? Or does a ECu control it to vary ? atm I'm rebuilding my Carb and have successfully done a good job just need to know this so that i can power up the solenoids as well. Cheers Edit The Solenoid (A white wire coming out)
  11. Is your 121 from Ian Hamilton's era ? and the axio is from the future I suppose ?
  12. Nissan March from the 1980's is a good deal Drove one recently not bad at all as it goes for around 4Laks Enough of space on the back for 3 adults
  13. You mentioned that they washed the engine ? While doing the service in the engine compartment water might have accumulated water into spark plug chambers or accidentally knocked a spark plug wire loose, what you have to do is start the engine keep it for 1 minute and open up the engine bay and disconnect each spark plug wire from the plugs individually and see if there is a sudden jerk on the engine (Vibration) keep doing it too all the plugs and if there is a issue with one of the plugs the engine wouldn't change a beep after finding the faulty section take off the wire and re fit it and try to drive around and see if it is still rides crappy.
  14. So you are telling me if the battery has to be charged at 30Amps a 45A alternator will provide it ? There should be a maximum amperes for a pb to withstand while charging because my 10A charger charged the 12V upto 10ah in an hour.
  15. The carb was flooded. Its now fixed.
  16. Damn This thread some how makes me miss Top Gear
  17. This might be out of the topic but With how much Amps does a alternator charge a normal 12V lets say 45ah Pb battery ? Like the Maximum Amps that a alternator is allowed lets say.
  18. Well I didn't start the engine for like 2 weeks and this happened I can't get my engine to to start Its a Carb engine So i put some fuel into the carb and cranked it and the carb started to back fire and was almost about to start but didn't kept on cranking the same story so took the carb out again and This is what it looks like, Flooded ? Or is the engine flooded ?
  19. I didn't know the performance thing till now thanks mates, And I will check out the places soon. Cheers
  20. Are you bloody blind mate ? Read the freaking posts. This is a number I dotted down to the phone while at Panchikawattha 0774905223 He will do any type of number plate with no issue thats what he said lol .
  21. its a 3A 1.5L How does it effect the performance mate ?
  22. Sound and looks, Not ricer sorta sound though. Its a Ford Cortina Mk3 (Project/Restoration)
  23. Well I need 2 Custom Exhausts made some thing like this with a clean beat maybe- Any places you guys recommend ? I've seen a lot of places but would be better off with a experienced user And how are the prices ? I just need those 2 barrels done and lil beat.
