Davy
Top Contributors
  1. Hi Guys, My car is at the painter’s and since most of the external parts have been taken off for painting, I wanted make use of the opportunity and clean the fog lamps. One of the fog lamps in my car was badly discoloured due to water leaking into the assembly causing one of the screws to corrode and spread the corroded metal particles everywhere (see the images below and you’ll see what I mean). So anyway, I thought of writing a DIY for whoever might be interested in doing a full cleanup of their headlights or fog lights. I found a couple of DIYs on the forum about headlamp restoration, but thought of posting this since this is a full cleanup. Here goes… What you need: A heat gun (optional) | Silicone sealant | Sandpaper 1200 grit and 2000 grit | 3M rubbing compound (or Brasso) | Clear coat spray can (optional) | Masking Tape | A bowl of water | An old toothbrush | A little car wash | Tools to take the fog light assembly apart, a set of spanners and screwdrivers would do. 1. Take the fog lamp assembly out of your vehicle. My fog lamp assembly looked like this: See what I mean about the discolouration? Remove the mounting brackets and set them aside with the screws and clips that hold the lens and reflector in place. 2. Use the heat gun on the edge of the lens to heat the sealant and carefully pry out the lens using a screwdriver. Follow safety precautions specified on the instruction manual of your heat gun to avoid risk of injury. Once the sealant is heated up, it will start to melt partially and the lens will come out easily. There is another method to remove the lens and that is to pre heat an oven to about 200 degrees Fahrenheit and put the lens in there for about 3 – 5 mins max. Leaving the light in the oven for a longer time will cause the entire assembly to melt, so you might want to be careful with this method. 3. To avoid the sealant sticking to your hand and every surface it touches, cover the sealant using masking tape. I initially thought that the masking tape wouldn’t come off due to the sealant sticking to the tape itself, but I had no problem, it came off fine. 4. Using water and the sand paper cut away the dirt and discolouration on the lens. Tear a small part of the sand paper and dip it in water and start sanding evenly across the front of the lens. I had some paint marks on my lens so I had to use the 1500 grit sand paper on those areas while I was able to sand the other areas with 2000 grit. Make sure there is enough water on the lens while sanding. The lens will become a bit foggy after sanding, don’t worry about that as we’re going to take care of it in the next step. I had to sand the inside of the lens as well. 5. Apply 3M rubbing compound (or Brasso) on the lens and polish it until the lens is nice and transparent. BEFORE AFTER Continued...
  2. Welcome to the forum! Can you please be more specific on the noise? Is it a whine? a roar? a click?
  3. Fuel smell from the exhaust, black smoke and low fuel economy are all signs of an engine running rich. Your carburetor needs to be properly tuned to get around the issue. I'm not sure about a carburetor repair workshop around the area, but for the service, you can try L@ughs at Maharagama or Koswatta.
  4. I think terra is right. Either you're letting go of the accelerator a bit too late or your foot is a bit too heavy on the accelerator. Go easy on the accelerator and let go as you start to press the clutch. One other thing I think you have got mixed up is that the clutch is disengaged when you press the clutch pedal and engaged when you let go. So terra is right when he said "disengage the clutch".
  5. Congratulations guys! All the best in keeping AL clean!
  6. Davy replied to MADZ's topic in The Lounge
    Agree with Peri and Schiffer. I went when I saw the photo and when I read the caption. lol
  7. And what some people don't know is that most of these fake phones don't even conform to radio frequency emission standards, thus prolonged use can be hazardous to health. One cannot be "practical" while being ignorant.
  8. Seriously? Honestly speaking, if you feel this way when you travel in any air conditioned vehicle, then you'd better see a doctor as JD suggested as you might be suffering from asthma or something. If it happens only in your car, first check if others are also experiencing the same. Try getting rid of any strong air fresheners you might be having in your car, and stop cleaning your interior with liquids that are strong. Some people can't stand them. If the situation persists, get your AC serviced, and inspect the ventilation duct (beneath the rear bumper in most cars) to see if it's blocked.
  9. Sounds to me like your air flow is set to "fresh" instead of "re-circulate". If the switch is already in the "re-circulate" position, it could be that the air direting mechanism is jammed (leaving the fresh air vent partially open) or because the spongy insulation around the vent doors are leaking fresh air into the car.
  10. If you hear a clunk when shifting into a particular gear while pressing the clutch, it could be because: 1. You are not pressing the clutch all the way down, thus the transmission is still (paritally) connected to a spinning engine. 2. Your clutch requires adjustment. I'm not sure if the Zen comes with a clutch cable, or hydraulic, but if it's the former, you should be able to get the cable adjusted so that the clutch disengages properly when the pedal is fully pressed. Hope this helps.
  11. Thanks Don, I understand what you mean and I agree with you on the fact that it’s better to get the trunk lid with the spoiler rather than messing up the existing one by drilling holes etc. 34K is something I am not too comfortable with right now, so the best bet is for me to give up my trunk lid and get the lid with the spoiler following a payment of 24k. As for fabricating a spoiler… I don’t think that’s something I want to settle for machang. I guess my requirement is too specific. Oh and the Evo VII spoiler is not the one, that is bigger and a bit more aggressive than the one in the image I have shared in my post above. But you’re absolutely right about the higher price online. Anyway, my car is at the paint workshop right now and it’s still being prepared for the bodywork, so I have a couple of more days until I can hunt for one. Got to know about another place at Bellanthota (thanks to trinity) and I will be checking it out tomorrow. Fingers crossed…
  12. Hi Guys, I was hunting for an OEM spoiler for my Lancer CS3A for about a week or so without luck. Did a clean sweep of the Delkanda strip (from Nugegoda to Kottawa), Checked Eur0Nipp0n, U$ @uto P@rts, J@pan L@nka and many other places including places that supply recon parts to UniMo. Even gave a call to a guy in Kurunegala (waiting on his response). However, there’s this one place that has a Cedia trunk lid (which is a perfect match) with an OEM spoiler and the guy is quoting 34K for it. He was willing to reduce only 10K if I gave my trunk lid in exchange. I'm not too happy about the deal. If you guys know of any places that could sell me an OEM Lancer CS spoiler, or if you seem to spot one in a shop on your way home , please let me know. Thanks! The wing I am looking for is a 2 spoke one (there is a 3 spoke version as well, not that) and it looks as follows: Cheers! PS: trinity, I hope you don’t mind me hijacking your thread a little bit.
  13. Davy replied to MADZ's topic in The Lounge
    Maan... poor Evo!
  14. Happy birthday mate! Have a good one and an awesome year ahead!
  15. 240D Type R (Spotted at Biyagama)
  16. Spotted at Dehiwala
  17. Nope, it isn't. Came across the same car again... and this time, it was parked.
  18. I didn't know there was a 0.0L version of the Cruze. (Spotted at Dehiwala)
  19. Discussed before. Please search. http://forum.autolanka.com/topic/11255-mazda-3-axella/page__hl__+axela%20+mazda%20+3
  20. Great! Will keep doing the same in the future as well. Sorry, not with me mate.
  21. Mitsubishi Space Gear (L400) Download Catalog (PDF) Preview:
  22. Rpm
    Davy replied to kmcsb's topic in HONDA SRI LANKA
    It looks to me like the mounting screw holes are identical to what OP already has. The only thing bigger about the photo with the RPM meter is the image resolution. As for the installation, I agree with Watchman on installing the OEM guage cluster. The tachometer wiring is built into the wire harness as far as I know (EG8 experts should be able to confirm), so all you'll have to do is just swap the cluster. If you want to retain the mileage of the car, you can take both old and new clusters apart and put your speed o' meter into the new one (or you can match it manually).
  23. Mercedes Benz 190/190E Download Catalog (PDF) Preview: PS: This catalog is very old (I've been having it since I was a kid ) so please excuse the degraded state of the catalog.
  24. It's an image [http://i.imgur.com/eQMUX.gif] that goes well with the set of AL emoticons!
