Davy
Top Contributors
  1. The video gets stuck from 0:15 onwards for me, but the audio goes on. From what I see, the sound seems to be emitted from the throttle body area, and it sounds like an electric hum. Am I right? The only components in the throttle body I can think of that can make this kind of sound is the electronic throttle or the idle control stepper motor, but highly unusual. Is there any issue with the car? Or is it just that the sound is heard and the car operates normally? Also, does the frequency of the sound change/intensify/soften if you gently press the accelerator pedal while the sound is heard? I should try this on my car. Will let you know.
  2. Search the forum before opening new threads. Mahinda is your best bet. @MADZ, can you please merge this thread with the one above? Thanks!
  3. You don't need to blindly replace it. It can be removed and visually inspected determine if it's damaged or if the bushes inside the mount are broken. Remember, this is just one possibility. From memory, the City has a multi-link suspension setup at the back, so a lot more links and bushes that move around to keep the car stable. A more sophisticated design from an average Toyota, but given the age of the car, it probably needs a bit of TLC. So put the car up on a hoist and inspect each link and the ends to make sure that all bushes and linkages are in good condition. As for a garage, I'm afraid being overseas for over two years has distanced me from knowledge about the best places around. Hope another member can help out. You can check out the Mechanics/Workshops thread as well.
  4. Suspension noises (and other noises in general) is a bit difficult to diagnose without inspecting the vehicle in person. My response above was simply to guide you to check the shock mounts. However, when replacing struts, it's better to replace the mounts even if there is the slightest indication of wear. This is to prevent having to remove the shocks again to replace just the mounts. Regarding your question about replacing mounts on both side - yes, replace mounts on both sides, It is important to maintain proper suspension geometry, even at the rear. Get it diagnosed by a proper mechanic first.
  5. Were the shockabsorber mounts replaced during the repair? Since the old shock didn't provide any damping, the mount would have taken a beating. If it was damaged even slightly and reused, there's a possibility that it could be the cause of the sound.
  6. Perform the test below explained by @Rumesh88 to determine if your brake booster (servo) is working normally. According to your description, it looks like the booster is working as it should, but do this yourself since it's easy and we can rule out a faulty booster by doing so. Was the old oil in the system drained and was the system bled on all four corners with the new oil? Was your master pump overhauled with a repair kit? Given that the car was sitting for a long time without being used, new oil is a must and if the pedal sinks, get the master pump overhauled. These are very minor repairs and wouldn't cost you much.
  7. The brakes are self adjusting. A possibility is that the adjusting mechanism on one side is faulty. An inspection inside the drums will tell you. Didn't you have a brake issue on your car recently and get it sorted?
  8. Davy replied to Pramuk's topic in General
    A recall doesn't mean that the issue has to be there from day one, or after x amount of Kilometres. On some vehicles, the issue wouldn't have surfaced at all, but the manufacturer does the repair anyway to prevent the risk. Anyway, I was pointing out the fact that you might be able to get the issue fixed free of charge if this is related to the recall. Up to you to check it out. Recall issue or not, your car shouldn't be on the road until your EPS is repaired - for your safety and the safety of others.
  9. Davy replied to Pramuk's topic in General
    I remember the Yaris having a recall for power steering failure which was due to a faulty EPS control module. If your car was imported brand new, you should be able to ring Toyota Lanka and provide the chassis number and inquire if your car is affected. I wouldn't advice driving your car like this due to the potential risk. Get it checked out immediately. As I mentioned before, diagnostic scan first. If that doesn't show any errors, the EPS system will have to be checked out anyway. The agent is the best place to go for something like this IMO because they will perform proper checks.
  10. Davy replied to Pramuk's topic in General
    Welcome to the forum. Sounds like an intermittent loss of power assistance. Does the Yaris have EPS? If yes, you should get a diagnostic scan done to determine if there are errors in the system. The EPS motor or related components might be failing. If it's just regular hydraulic power steering, it can be a slipping drive belt, lack of power steering fluid. You can get them checked out easily. If they're fine, then the power steering system will have to be checked out for faults in the hydraulic lines, linkages or even the rack itself.
  11. Davy replied to MADZ's topic in General Automotive
    Advertising done right: http://www.roadandtrack.com/car-culture/entertainment/news/a31562/the-grand-tour-is-leaving-crashed-priuses-all-over-london/
  12. Seriously? After all the negative reviews, safety concerns and even owners' complaints? What good is leg space if there's the risk of legs being automatically amputated in the event of a severe accident?
  13. Good job! Nice to see more people doing the double din conversion.
  14. How about buying one of those tents that you can assemble yourself with a waterproof canvas? This way, when you decide to leave the annex, you can take the garage with you. I haven't used one of them but I have had to resort to using a canvas sheet that I bought from the roadside (in front of SLIIT in Malabe) for about 2 years and it held up pretty well. I secured the sheet to two walls on either side and made sure that water doesn't gather on it and cause it to tear. It wasn't the best, but it did the job of keeping the car off the sun and rain. If you are parking the car on an unpaved surface (grass or dirt), then you should also keep in mind that the moisture from the ground can also result in the undercarriage developing surface rust which may cause corrosion. As a solution, you can buy some cheap concrete tiles and lay them out and park the car on top of that.
  15. I see. I think your best bet to identifying the issue is to first get the crank position sensor checked out. The sensor has three wires (I fail to remember the colour codes now because it has been a long time) and you need to perform three tests using a multimeter. Note that all the tests need to be done with the ignition in ON position with multimeter in DC, and the ignition coils disconnected from the connectors. If your mechanic has experience as you say, he would know where to find the crank position sensor connector. You can basically access it from the top of the engine. 1. Positive: Check the + of the sensor with the chassis of the car or battery negative terminal. It should give a 12v reading. 2. Ground: Check the ground line of the sensor against the battery positive terminal. This too should give 12v. 3. Signal: Check the signal line of the sensor against chassis of the car (or battery negative) while someone manually spins the crankshaft with a tool attached to the sprocket. You should see the voltage alternate between 0 and 5V, twice between one revolution of the crankshaft. Again, if your mech has the said experience, he should be knowing all this. You can also refer to the workshop manuals that are already shared in the forum in this thread. Also, have you considered that the camshaft might be out of balance or something due to the timing belt slippage? Considering that your valves were also bent, this is something I would look into since you say there is a 1mm difference in alignment. Hope this helps and do keep us updated.
  16. The ignition signal is determined (by the ECU) by looking at the signal from the crankshaft position sensor. When your timing belt slipped, the crankshaft would have ended up in a different position than normal which would have caused the sensor to pick up the signal at different time than when the ignition coil (that supplies current to two plugs) requires a trigger. So my guess is that whoever carried out the repair messed up alignment of timing marks when installing the new belt. I can't see how the factory ECU could fail just because the belt slipped. Take the car to a good garage, or better - the agents themselves and explain the situation and get it sorted. Make sure you put that old ECU back in. Good luck and keep us posted.
  17. Do a diagnosic scan and find out what the errors are. That's your first step. I'm guessing it's a connection issue. Maybe the mechanics unplugged a connector/relay and failed to put it back in correctly?
  18. Having had personal experience with a car catching fire, I would never say no to having a fire extinguisher on board. In my case, it was during the first trip after the car bring stored away for about 6 months. Rats had chewed up the wiring in the car which lead to a short circuit. Long story short, it was one of the scariest days of my life. Thanks to the good people who came to my assistance, I was able to save the car. Others are right about using a Co2 one and keep it inside the car (under the seat or dash - basically somewhere within arms reach ) and not in the trunk. Finally, don't contemplate on your car catching fire, just look after it well and do your regular maintenance on time.
  19. Looking awesome Hoonigan! That retro looking dash. Wow! Love to see her in person some time when I'm there.
  20. That looks like a result of being exposed to the sun regularly. Another option is to cover the entire door card with rexine. Check the following thread . If you want, you can use plastic primer and then paint the surface again, but the soft and powdery stuff need to be lightly sanded and that will result in the original texture of the surface being lost . Check page 2 of the above thread .
  21. You can also try using a file to flattern two opposite sides of the bolt so that a smaller spanner can be used to remove it. Will probably take longer than the chisel and hammer, but lower risk of the bolt breaking off IMO. This will only work if you have enough space around the bolt to manoeuvre a file.
  22. Nissan purchases 34% controlling stake of Mitsubishi. Source: CNet
  23. My RalliArt has shims, so I'm guessing the EX also has although brakes are a bit different between the two. However, I doubt it's due to missing shims because OP says that the rattle can be felt through the steering.
  24. I used a TOA spray can. I don't think 2K will be harsh on the lenses. But you can do a pretty decent job using just a spray can, provided that you clean the surfaces well before, and that you spray even coats, about 20 minutes apart. After all coats have been applied, the surface might look a bit textured (just like when a car is newly painted and before polishing). But that will go away after wet sanding (2000 grit) and then polishing.
  25. I have used clear coat and that works well too. After three coats of clear, wet sand and polish and it looks as good as new, and holds up well against the local sunlight.
