Lancer ex rattling noise
First of all, I don't think this is a "common problem with the car", but depends on the condition of the roads you drive on frequently. I'm a bit surprised to hear that the agent couldn't diagnose the issue properly. When the rack ends were replaced, we're the tie rod ends also replaced with them? According to your description, my assumption is that the car was driven for some time with the noise which in turn affected the steering rack. Put the car on a hoist and check for excessive free play between the steering linkages. Depending on the extent of damage, you might be able to get the steering rack machined.
No brake after pad change, help needed
To add to what Rumesh has mentioned above, you may not be able to completely remove all air from the brake system if what you did caused air to get trapped inside the ABS module. This is why it's important to take your car to a place that will be able to confirm that the brake system is completely bled out.
Need help to find Mitsubishi Galant
Welcome to the forum! Check this Facebook group: https://#####/galantclubofsrilanka/ Make a post and see. There might be someone willing to sell. Also, do a search on the forum to find information about the car. @Sierra Charlie is your guy for all Galant related advice.
Help With My New Cs3
The gap between the spoiler and trunk lid should be sealed off using a gasket or a bit of gasket maker at least so that water does not seep in through the gap and cause the trunk lid to corrode or leak into the trunk. Read the below post for more information: Note that the part number for the facelift spoiler gasket might be different from what I have got.
Timing belt wheels
I honestly don't see anything wrong with that sprocket. It's just polished off a bit from years of use. Unless the teeth are broken or something, I think using this one is fine. If you still decide to go head for a new one: http://www.ebay.com/itm/GENUINE-L200-K74-SHOGUN-SPORT-96-06-ENGINE-CRANKSHAFT-CAMSHAFT-DRIVE-SPROCKET-/381566763435?hash=item58d726c1ab:g:pE8AAOSwP~tW4own&vxp=mtr Part number is: MD164831
- Repairing A Carina Gt
Nissan Ga13
Petrol isn't hard on plastic, if it was, then injectors and other plastic components inside carburetors should be affected by it. But yes, engine degreaser is the way to go.
Nissan Ga13
Looks like the same issue as OP's. Distributor oil seal.
Mitsubishi CK1
The CK Lancer has been discussed many times on the forum. Search and you will find all you need to know.
- Help With My New Cs3
If it's actually broken from somewhere, you should probably change it. The spark finds the path with the least resistance, so you might occasionally get a miss because the spark doesn't reach the plug. Worse case your car might stall and refuse to start - although unlikely because the part is tightly fit inside the spark plug chamber.
From your description, it sounds like either your ignition coil is the two part variant which has it's rubber boot stuck inside the spark plug chamber, or the single unit of which the rubber part has snapped off. You need to find out which it is. If it's the former, you can still continue to use the coil. If not, you should change it. At Unit#d Mot#rs, they would have taken off the engine cover to replace the spark plug oil seals and the engine cover oil seal. I wonder why they didn't take the stuck part out then and reassemble it back onto the coil or recommend changing the coil. Found this video to help you understand (video starts at 1:14 which is deliberate): Note that he removes the ignition coil that powers the cylinders towards the left of the car and you can see that as he pulls the ignition coil, the rubber boot separates and is still stuck inside the spark plug chamber. He then pulls it out separately. But when he pulls the second ignition coil, it comes off with the rubber boot. Any good garage will be able to fix this for you. Honestly, even you can do this yourself now that you have this video. All you need is a 10 mm spanner to take off the two screws holding each coil in place.
Honda Civic Es5 Low Fuel Consumption
Welcome to the forum! Noticed that you bumped up a few old threads just to make comments about them. Please be mindful of when the thread was last active before responding (date on the most recent post). For instance, this thread has been inactive for nearly 2 years. However, you may use existing threads to discuss new matters. Appreciate you searching and reading up existing content though. Thanks and hope you find the forum useful.
There were several types of ignition coils that came on the CS. Some were a single unit on which the rubber boot was permanently affixed to the coil whereas some had detachable rubber boots. Mine had permanently fixed boots so replacing the ignition coil was the only option. I wouldn't recommend repairing the ignition coil as it can lead to arching and then ignition misses etc. However, if your coil is the type where the boot can be separated, you can buy a couple separately for about 3000 rupees. http://www.ebay.com/itm/2-PCS-Repair-Kit-Rubber-Boots-Ignition-Coil-Mitsubishi-Lancer-4G18-/131955290912 Also, since two plugs share 1 coil, 2 out of the 4 plugs have ignition leads. If they're also swollen, you can buy them separately for cheap. Check link below: http://www.ebay.com/itm/Mitsubishi-Eclipse-Galant-Lancer-Mirage-Outlander-Spark-Plug-Wire-Set-NGK-ME96-/320919605019?fits=Make%3AMitsubishi|Model%3ALancer&hash=item4ab84c8f1b:g:FUsAAOSwf-VWaI~r&vxp=mtr Something that needs to be mentioned is that the coils don't need to be replaced just because the rubber is swollen ("idimila" as they say). Although the rubber boot doesn't go all the way in, there is no impact on the operation of the engine. Also, this swelling happens not because the rubber came into contact with oil, but because of the age and prolonged exposure to engine heat. I had the same issue and what I did was apply a small amount of rubber grease on the collar of the boot and use force to push it in. Never had an issue.
So the oil seals alone cost 18.5K? That's insane! I remember @trinity replacing all spark plug oil seals in 2014 or so for a couple or hundred rupees. 20K seems about the right price at the agents, but you can buy brand new ones from eBay for about 8000 LKR (both). There are used ones for sale for cheap too, but for components like ignition coils, new is always better IMO. UM was advising me to replace the coils ever since the car hit 90,000km, but I never ran to issues with it. I believe it was replaced by our resident member @s.madura (who is the current owner of the car) recently. And this is after about 50,000 more KMs. Maybe he can share more info. Having said that, the workshop manual says replace them at 100,000k Km if I remember correctly.
Converting Manual Doors To Power Shutters
Stumbled upon an image with the part you're looking for while I was browsing through an Australian Lancer forum. Here's the part number. You should be able to locate this on eBay or Amayama or any other parts site. For example: http://www.ebay.com.au/itm/OE-MR951187-Rear-View-Power-Mirror-Switch-Folding-fit-Mitsubishi-2004-Endeavor-/112030087639?hash=item1a158379d7:g:sikAAOSw-4BXYIfz A bit pricey though.
Mitsubishi Lancer RalliArt
After over a year and 15,000 KM later, I thought of giving an update. I've added a couple of videos to my last post (the Gravel road drive) as well. If you've been following this thread, you may remember the rattling clutch which was solved after a transmission oil change. As I suspected, it resurfaced again and despite everyone telling me it's normal, I got it checked out. It was found that the clutches were on their way out and were replaced under warranty. I was told that the clutches cost about 300,000 LKR brand new. I think I got pretty lucky. After the repair, the change was pretty obvious. The shifting is now flawless and the car responds perfectly. The car has mostly been a weekender. Mainly because I use public transport to get to work and back. But I did many trips ranging from about 150 km to a trip of 759 km (round) which is the one worth mentioning about. Got to drive on snow, and when all other sedans were crawling slowly up the mountain with snow chains on, the RalliArt had no trouble going up without snow chains, thanks to the AWD and the AWC which I switched to "snow" as soon as the road became icy. Out of the 380 km one way trip, about 90km was snow and ice. Here's a video: The door sills were slightly scratched, so I touched them up and ordered a set of genuine scuff plates. Installed them myself and here's what it looks like now. I also blacked out the front grill with plasti-dip. Was not a fan of the chrome surround. Now it looks a bit more like the Evo from the front! I like how it came out. Thought of going for a set of Evo X Enkei wheels. They're hard to find and pretty expensive. I found one set and went to inspect it a couple of weeks back, but the rims were not in good shape. One was bent and I was not willing to get them repaired at about 15,000 LKR a wheel. After a bit more research, I found out that the Evo X wheels have clearance issues on the Lancer and RalliArt. The Evo has wider fenders and the wide wheels (Stock RalliArt wheels are 7.0 inch wide with +46 offset whereas Evo wheels are 8.5 inch wide with +38 offset) so there will be rubbing of the rear wheels. The fenders need to be rolled up to prevent this, and I'm in two worlds about doing this because I was thinking of going for BC Racing coilovers to lower the car a bit. The gap between the front wheel and wheel arch is a bit too much for my liking (as seen in one of the photos above).
- 108 replies
- 2
- cy4a
- twin clutch
- cy
- sst
My 2016 Honda Grace Rear wind shield no visible when get rain
Strange. None except only one of the cars I've owned/used upto now has had a rear wiper and I've not had an issue. The defroster clears up the rear windscreen in just a couple of minutes. However, I guess I can see this being a problem in vehicles where the rear windscreen is a bit further away from the driver (station wagons, some hatchbacks, vans etc.), and if it's raining cats and dogs outside!
Toyota Corolla 141 ABS modulator
There are two errors in there. The first one C0273 is the one related to your ABS system. The error is a continuity issue, so you shouldn't blindly replace the ABS module and expect the issue to go away without checking the simple things first. - The first thing you should check is the ABS relay in the engine bay fuse box. - Check all wheel speed sensors and continuity from wheel speed sensors to ABS actuator. If you're unable to identify the issue, I suggest taking the car to Toyota Lanka so that they can do a much thorough diagnosis. The second error is also a continuity issue in the CAN BUS. This may or may not be related to the ABS error, but your wire harnesses definitely have a lose connection. Time to do a thorough clean-up of all the connectors. Do you observe any lack of power or high fuel consumption?
@effdog, your quote seems to be messed up, so quoting an old post to respond. Did any of the 5 mechanics test the ABS relay first? The ABS relay is located in the fuse box under the bonnet. To me it looks like replacing the ABS module without checking anything else isn't a good idea.
- Toyota Corolla 141 ABS modulator
Side Skirts & A Spoiler For Lancer
Crosswind is right, the black one is a pre-facelift CS Lancer whereas your one is the newer facelift (post 2004) model. Also, you will not be able to simply swap the current trunk lid with the older one, because they're different and won't fit. The pre-facelift trunk lid has a straight bottom edge. Yours has a curve. This means the bumper also will have to be modified/changed and I don't think it's worth it. I think you just need a rear bumper skirt to match the rest of the car. Also your rear number plate is a square one which ruins the look of the car IMO (It's running out of the number plate space). The rectangular one looks much better. Edit: Added photo
Looking good! The side skirts appear to be custom made ones? By the way, you need wheels!
- Allion 240
Welcome to the forum! A properly maintained petrol engine can easily run over three times as much as that. 125,000 km is nothing if that is the genuine mileage of the car. If that's the only thing holding you back and if the rest of the car checks out, go for it. Also, search the forum to find more information about the car. It has been discussed in detail. - Allion 240
