Davy
Top Contributors
  1. Already discussed. Search the forum.
  2. Davy replied to Le Sabre's topic in NISSAN
    If the motor freezes and only the starter solenoid clicks away while you hold the key in the "START" position, then it's probably a starting system fault (starter motor, battery, leads and relays) and not the fuel pump. - Check if your battery terminals are loose - Get the battery checked properly (CCA, Load test etc.) - Visually inspect the live and ground cables that run from the battery to the starter motor and make sure they're not damaged or loose. - Take it to a good electrician and get the starter relay checked After all the above points are covered and if the problem still persists, you probably need to get your starter motor serviced.
  3. Davy replied to Le Sabre's topic in NISSAN
    Wait the motor cranks, drags and stops? Meaning the motor stops despite you holding the key in the "START" position?
  4. Wishing all members a happy and prosperous new year! Drive safe gentlemen!
  5. Davy replied to Le Sabre's topic in NISSAN
    You mean just clicking and the starter motor not cranking the engine? If the motor spins, you're probably looking at a faulty/worn out fuel pump which takes a bit of time to build up pressure.
  6. ShamilFazeel, Can you please stick to one thread and ask all your questions about buying a car instead of cluttering the forum with multiple threads? First a Honda, then an Indian, now a Euro. We understand your enthusiasm, but please search the forum (here's how) and continue an existing thread. Thanks!
  7. Oh, look who's back on the forum after a long time!
  8. Oh I just noticed that trinity's wheels have 8 lugs each and MrCat's has 4.
  9. Whoever told you that the CS comes with a "cable" system is wrong. It has a regular locking system that uses metal rods and hinges. The power window system however is operated by a cable system. You have two options: 1. Go for an aftermarket central locking system Cheaper. You'll have to purchase 4 actuators and have them wired up manually. I believe places like Sun Lanka does this. 2. Get 4 used doors off a GLX Much much expensive. As a plus, you will get power windows as well. You can sell your current doors after the conversion. If you're going for the second option, trinity is the man you need to contact. He got it done on his CS1.
  10. Nice! Same model of wheels as trinity's, except for the colour.
  11. Yes it does. In this case "cold" refers to freezing temperatures. If I'm not mistaken, the number before W is the viscosity when the temperature is 0 Fahrenheit (-17 Celsius). Obviously we don't get anywhere near to that kind of low temperature in Sri Lanka. So the W specification has no effect. As for the smoothness you felt; probably placebo.
  12. PS4 hands down. Grand Turismo 7 will be released late this year or early next year as I remember. As for gaming wheels, I think the Logitech G29 is a good option for PS4. Been using a G27 on PC for a couple of years and loving it!
  13. Far out!!! Superb job machan! Looks like you've got a mini laboratory at home now. Any idea if this would work simply by swapping the ROM chip to the new cluster without resetting the mileage and VIN? Since the values match up with the values on other modules on the car (which I'm guessing is external to the cluster), could there be any issues? Just curious.
  14. Davy replied to MADZ's topic in The Lounge
    lol. Waaay more than once!
  15. The Tesla Model 3 was unveiled yesterday: https://vimeo.com/161138986 More...
  16. Davy replied to MADZ's topic in The Lounge
    This is exactly the kind of retarded driving I observed during the three weeks I was in the country. People just don't seem to give a damn about road markings, signs, traffic lights and worst of all - lives of other people. After a couple of days of driving, I extracted scenes of so many traffic offenses from the dash cam. There were just so many of them, I gave up copying them to the PC at one point.
  17. +1 for checking coil packs. Failing ignition coils usually start giving erratic ignition when the engine warms up. As part of the fuel system clean-up, I assume the Idle Air Control valve and MAF sensor were cleaned as well.
  18. Whoaaa! Very nice! That's a clean AE86. Pretty sure I've seen it on Facebook somewhere.
  19. *** Goes into hiding in a cave *** I think it's best that I don't comment on local garages and spare part suppliers. I clearly have lost touch.
  20. Mahinda has genuine but reconditioned parts. For engine mounts, recon doesn't make sense. But he might be able to point you to someone who does brand new genuine parts. OP, use the following method to search the forum: http://forum.autolanka.com/topic/15808-how-to-search-on-autolanka/
  21. I see. Things seem to have changed a bit over the last couple of years then. When I changed mounts on my CS3, genuines were only available at the agents. Also didn't know about UniMo being a subsidiary of Unit#d Mot#rs. Thanks for the clarification.
  22. Please search the forum. For engine mounts, I don't think you will be able to find genuine parts outside UniMo.
  23. Davy replied to Le Sabre's topic in NISSAN
    The method to paste stickers like this is to first create a soap water solution (mix some car wash/shampoo with water) and spray it on the body where the sticker is to be pasted. Next, peel off the sticker and paste it on the body (yes, on top of the soap water). The soapy water on the body will allow you to slide the sticker on the body and position it exactly as you want it to. After the sticker is in place, you can remove air bubbles if necessary using an old credit card. Once the soap water dries up, the adhesive behind the sticker will stick to the body. The soap water prevents the sticker from sticking to your fingers as well.
