Lancer Cs1 2002 - How To Find The Engine Number
I can vaguely see the engine number in the image you have shared (left to the engine oil dipstick and right above the exhaust manifold heat shield bolt on the left). Edit: Removed image
The exhaust manifold is on the front right? So front. Your car probably has a manifold cover, so you might have to really get in there to see the number.
Should be on the exhaust manifold side of the engine block if I remember correctly.
Mazda Bj5 Ecu Problem
How are you sure that the problem is with the ECU? An erratic RPM could be due to other reasons such as a failing Idle Air Control valve. Edit: Didn't see that your question was answered in the duplicate thread. Hope mods will merge threads.
- Post Whoring - Part 2
Indication Lights Not Light Up
1. Search online for the 2008 Yaris fuse box diagram and check if you can locate the fuse easily 2. If step 1 fails, pull out each fuse and check if one of them is burnt. I get the feeling that this is intermittent according to your description. If so, it might be a loose connection and not a blown fuse.
Dislocation Of A Certain Tube Under The Hood
Looks like the drive shaft (axle), and it seems to be missing a rubber boot. Fallen off due to broken bands maybe? If I'm correct, you will have to take the drive shaft out to replace the boot. While you're at it, make sure you check if that joint has sufficient grease because it looks like some amount of CV joint grease has leaked and splashed on the gearbox and surrounding area.
What Has Happened To Bmw 320D S?
1. I am not an "expert" and I did not claim to be one 2. I never said what your friend is doing is impossible. I know people who have done much much more complex engine transplants. So what your mechanic is doing isn't magic. I however pointed out the significant change that anyone driving that car will experience. It's pointless arguing about this, after the car is done, you and your friend will understand what I mean. Good luck by the way...
- Corolla Axio 2007 Fault
I'm going to assume that Aquaman's friend is swapping the engine of a good old E36 (because he said it was a 300- car). I'm going to assume that the car is was a 318i. If so, the car would have had 113 horses when it left the factory. If it was a 320i, it would have had 148. The Toyota 2C-T on the other hand produces around 87 HP (obviously at a lower RPM due to it being a diesel). So your "everything will be the same except the engine" claim is nonsense IMO because the car will never drive like it used to when it had the BMW engine.
Reupholstering Interior Panels
Sorry for the delay in responding. I got them from Roxy Paint in Wellawatte right opposite the Roxy cinema. A can cost me close to 500 if I remember correctly. Good luck and do post photos of the results.
- Reupholstering Interior Panels
- Car Brake Lathe
- Car Hud Head Up Display
Burnt Headlights - Prius 3Rd Gen
If this is the case, then we can safely assume the model of the bulb is alright and that they would have taken precautionary measures to avoid damaging the bulb while installing. The car's headlight circuit needs to be checked.
1. Are you using the correct bulbs recommended for your car? If you are not sure, check what the recommended bulb is and try using the correct one. The previous owner might have replaced it with the wrong bulb. 2. Did you avoid touching the glass surface of the bulb when you installed it? Touching the glass surface of a halogen bulb can shorten it's lifespan because the protein and fat on your skin will be deposited on the bulb which will cause "weak spots" and therefore premature failure. 3. Do think your headlight has a leak that might cause water to drop onto the bulb in any way? If you're certain that you need not worry about the above points, then it could be due to a fault in your headlight circuit supplying a higher voltage to the bulbs. Testing this is pretty easy. Any electrician will be able to hook up their multimeter to the bulb socket and check if the bulbs are being supplied the correct voltage. I'm guessing it's this because you said that the bulbs on both headlights failed alternatively.
Sat Nav (Gps) Help
Yes you are right, I think the current area that can be saved per map is 50km x 50km. That too if the amount of information in that particular area does not exceed a certain limit. If it does, the size will have to be reduced before saving. Importantly, I assumed that offline navigation is possible, but turns out it's not. Also, the saved maps will automatically be deleted from the phone in 30 days. So Crishan was right. You do need an active data connection for navigation using Google Maps. I will edit my previous post. Sorry for the confusion.
Top Gear/fifth Gear/jeremy Clarkson Videos!
Clarkson, Hammond And May Have Signed With Amazon Prime For Their New Car Show. http://www.carthrottle.com/post/clarkson-hammond-and-may-have-signed-with-amazon-prime-for-their-new-car-show/
Sat Nav (Gps) Help
WoW that was quick! Hope you'll like it. Waiting for your review.
Sat Nav (Gps) Help
If you have the latest version of Google Maps, you can search for an area and then save the map on your phone. Therefore you do not need to have a data connection always. This was introduced a few months back. So if you plan to travel to an area that you are certain will have no mobile network coverage, you can save that area on your phone as an offline map and keep using maps offline. Google for it and you can find out how. EDIT: While the above is true, offline maps cannot be used for navigation. See post #24.
Sat Nav (Gps) Help
According to this link (scroll right down to the "Sri Lanka GPS Map Update History" section), they have been consistently updating the maps. If the map data is comprehensive enough, then you will have no reliability issues. I'm not sure about how comprehensive it is in Sri Lanka. The details are so good in Australia that the maps show speed limits, locations of traffic cameras and even the correct lane you should be on so that you can drive without disrupting traffic (these things are not available on Google Maps - at least not yet).
Sat Nav (Gps) Help
A popular brand in Australia is GARMIN. It's now in Sri Lanka and you can check them out here: http://garminlanka.com/product-category/on-the-road-garmin-gps-navigation/ I have personally used one for about 6 months on my cousin's car and I never missed a turn. Easy to use and they do provide map updates frequently (can simply plug into the PC and update). However, I'm not exactly sure about the quality of maps for Sri Lanka, but I believe they wouldn't be selling the product if the maps were not good. Hope someone using one of these can comment on how good they are in Sri Lanka. What I use currently is my trusty old Anroid phone with Google Maps.
Help On Identifying Crashed Vehicles
Good list by Kavvz. If you are in doubt and if you really want to know if a particular car is been in a major accident, the best way to tell it is by putting the car up on a hoist and inspecting the chassis as well (preferably with a person who knows about what to look for). Major accidents are usually repaired by replacing the entire set of damaged panels or attaching a "cut" from another vehicle, so the body will continue to look straight - especially to untrained eyes. Paint thickness gauges can be used to do that and they're very cheap on eBay. Doesn't scratch the paint and beeps or indicates when the paint is thicker than normal. I wouldn't call a magnet a standard way of checking for the thickness of the paint because the size of the magnet can significantly change the way it sticks on to the vehicle.
