Everything posted by The Stig
Hard To Start
No machan it cant be the battery cause if it was the exact opposite would happen (wont start in the morning) And you might be right on the fuel pump thing as well Okay i think the battery is not the problem, however there cold be something wrong with your starter motor. They tend to be less efficient when heat builds up in the engine, which explains your "this seems to happen if drive the car sometime, stop it, let it parked about 30 minutes or few hours" theory.Btw when you start the engine do you hear the usually "ignition sound" or do you not hear anything or hear a clicking sound ? AS for the starter motor theory check this page out, its fairly detailed http://www.misterfixit.com/starttst.htm Also the fuel pump theory could be right but im not entirely sure on that,
Hard To Start
Hard to exactly pinpoint the problem, machan can you give more info like the y.o.m, age of battery, any recent parts replaced etc. Also can you explain this with a bit more clarity "Car(EFI, Automatic) is hard to start after drive & sitting for about hours in day time. If we off & try to start after these hard startings, it starts just fine." We might be able to help you out if you give us more info His dads condom failed
Hybrid And Zero-Emissions Vehicles Photos And News
Says the guy who wants a lambo as a daily driven ride and yet ends up with a prius On a side note i forgot you are 12, sorry ill go talk to someone with a better intellect level.
He doesnt have to prove anything to a hippie like you, and for the record he has many more than your imaginary garage in which you have lamobos as daily driven cars
Perodua Viva Elitenew Car
For the airbags yes, but for the ABS its quite the opposite. If you dont plan to crash get ABS
Mufler Defects
What the hell kind of stupid response is that ? The man asks a question regarding his muffler and you tell him to check if his fuel tank has a hole ? Are you trying to impress people by being a smartass ?
Engine Missing And ....failing Green Test..
Like MD pointed out missing is when one or more cylinders dont fire, this will lead to all the petrol in your missing cylinder being unburnt and exiting through the exhaust in its raw form which explains the unburnt fuel theory. If your engine is missing you can sometime hear a noticeable difference in the sound of the engine as opposed to one that is functioning properly. Did you notice that your car sounds different from what it sounded before ? Check your spark plugs, you ignition coil and your ignition timing checked. Also if your car has a catalytic convertor (i think it does) remove it from the exhaust piping and check if it has deposits on it, running a car for a long time store deposits on the CAT so its efficiency goes down.
Maser Quttroporte Landed To Sl
Ha Ha Ha Hilarious ! NOT ! Now now shooo shooo, no one in this thread wants to hear your tree hugging crap
Mufler Defects
Not rocket science you could easily get that hole welded from a nearby shop And as for the drop on fuel mileage i highly doubt if a 5mm hole can drastically increase the fuel consumption
Question On Auto Gear Selection
When i said "acts like a 4th gear" it actually is the 4th gear, see the in the olden days the maximum input:output gear ratio cars had was 1:1 the equivalent of 3rd gear in modern cars. But they installed a separate unit to bring down the ratio in order to achieve better cruising speeds and efficiency.Today there is no separate overdrive unit, the overdrive itself is embedded as a 4th gear, but the term is still in use thus creating loads of confusion "I think (but not sure) that a better description is that it modifies gear ratios to give more speed/less torque - great for easy driving but not so great if you want more "pickup"?" Not exactly machan, turning it off doesn't modify gear ratios but it simply removes the 4th gear. AFAIK the OD wont change the timing of the gear changes as opposed to something like sports mode which would increase the gear shifting rpm range. See when you drive at the optimum shifting rpm range (usually biased towards economy) the gears up shift e.g from 3rd to 4th at around 3500rpm (just a wild guess on the rpm range) but if you dont have a 4th gear (turning off OD) the gearbox cant up shift meaning it will let the engine rev until it hits the rev limiter giving you more top end torque (this explains your theory on turning off OD when overtaking) As for the usage i'd say keep it on always except for the times you need engine braking and when you need that extra bit of torque while overtaking .
Grease Devil (Yaaka)
All of this is utter bull based on rumors and speculations, now stfu without helping it spread anymore ! ! ! This is the most stupidest thread i have ever seen on AL, and this surpasses all other moronic threads started by renowned dumbasses. Peri please do us and the general public a favour by closing this thread and help in stop spreading rumors which do not do any good to anyone.
Yes keep it on always unless you dont want your car to shift to 4th like in a situations where engine braking is required while going downhill. Yes OD in this context actually works as the 4th gear itself http://auto.howstuffworks.com/automatic-transmission9.htm So in short keep the OD on even in traffic cause it will give you better mileage where as turning it off will give you better torque which would not be of much use if you arnt carrying a huge load. Also note that turning the OD off when you are going downhill will actually help your car brake better (engine brake) which would be the only practical situation where you would want to turn it off
Ferrari 458 Italia
Well actually there is no real way of giving credit unless you contact the artist and ask for permission. Dont worry too much about it, if your video doesn't get above average hits they wouldn't notice the copy write infringements anyway.
okay lets start from scratch L1 = this only engages the 1st gear and is mainly used for when you are towing some sort of weight S2 = not very important in countries like SL but is mainly used for driving downhill and for driving on snow and only uses 1st and 2nd gear. D3 = its mainly for city driving and only uses 1st,2nd and 3rd gears As for your other question your car should have an overdrive mode on the gear lever or some button nearby. use that when you are cruising outstation. (usually marked as OD)
##### Fuel And Engine Additive
This picture reminds me of you As for the OP's question we have had plenty of discussions about these products, please feel free to run a search (thats the nicer way of saying "learn to use the search function ! " )
Belt 100Cc
Contrary to popular belief that a car with a bigger engine has less fuel economy its not about how big the engine is, its about the weight to power ratio of an car.Everything works better in an optimum range too much power you get less economy, too little power you still get low economy; it should be the perfect balance. For an instance a 1300cc march does more km/pl than a 1000cc march cause the 1000cc engine is underpowered. same goes for the belta, the 1300cc version is more powerful and yet gives more gas mileage compared to the 1000cc version. However i would advice you to try and get a 1300cc 2010 version if possible cause the 2010 version came with ABS and stability control as standard AFAIK. But if you are not in the budget for a 2010 1300cc i'd say go for the 2008 1300cc. Thats the dumbest thing i have ever heard ! ! ! So in your opinion a higher displacement engine lasts longer than a lower displacement engine ? where did you learn about that ?
If you actually bothered to use that brain of yours, you would realize that we dont care about the opinion of people who cant distinguish the difference between an alloy and a hubcap on his own car.
- Engine Oil Level Drop/burn
Okay so from the information i got from you i would say this is not a problem that would need immediate attention from a mechanic, my suggestion would be to run it for at least another month and make sure that there is no oil level drop again. As for the change from dropping to not dropping i can think of 2 things that could have gone wrong, 1) would be that who ever serviced the car used a lower grade of oil than recommended or 2) simply they didn't plug in your oil drain plug properly/ or faulty oil drain plug. http://www.ehow.com/video_2326731_inspect-motor-oil-drain-plug.html Take a look at this video but dont remove your plug now , just remember to check the plug the next time you service it. BTW did you notice any oil drops on your garage or wherever you park it ? Edit: also take note of rippers valve seal theory ( sorry didnt come to my mind at first)- Ferrari 458 Italia
Nice ! But you should give credit to the authors of the song otherwise youtube will remove the audio track, shame if that were to happen- Account Not Authorized To ....
LOL PM peri about this- Engine Oil Level Drop/burn
When you say white smoke do you mean the white smoke that comes in the morning ? if so this is not unusual but if it continues after the engine has built up heat its definitely engine oil leaking into your cylinders, this causes white smoke and might as well explain your reduction in oil levels. Possible reasons could be worn out piston rings, worn out cylinder heads etc. Im guessing this is somewhat of an old engine ? if so its time for an engine rebuild or a replacement of an engine- Hybrid And Zero-Emissions Vehicles Photos And News
If you dont mind doing a hip replacement surgery and spine surgery my the time you are 30 sure there is nothing else wrong with the idea of having a lambo as a daily driven car- Wheel Spin
yes absolutely. If you keep your car on a flat surface and shift to D and let go of the brakes you will notice that it actually moves forward without pressing the accelerator, the reason for this is that even thought you are not pressing the accelerator the idle throttle level is already there so the torque convertor pushes the car forward when the brakes are released. If its not a steep hill sometimes in an auto you dont need to use the brakes to stop the car from rolling back, but if the power/torque is not enough to keep the car stable it will roll back meaning you have to apply more brake force if you want to stop in rolling back downhill. Hope i didn't confuse you, in essence there could be various reason like less torque at low revs compared to your old cars, worn out torque convertor etc. Also on a side not never use both feet in an auto, always use only the right for both accelerator and brakes- Well I've Gone And Done It Again!!! Got Another Subaru!!!
One question mean green since i am not very familiar with the boxer setup much, can you actually replace the park plugs easily on that thing when the engine is mounted ? looks like a tight fit - Engine Oil Level Drop/burn
