Nilantha
Everything posted by Nilantha
  1. This is not a good habit.
  2. Nilantha replied to jaga's topic in TOYOTA
    plz refer to http://forum.autolanka.com/index.php?s...ic=4025&hl= (Remember Not To Use 95 Octane Petrol + Full Synthetic Engine Oil Same Time)
  3. My advice is not to buy modified vehicle. Try to buy Original condition BJ40. It will not beautiful but it is valued than modified one because it has only original parts. Sorry for the inconvenience. this is my view.
  4. No. with the agents they have ECU Reader. When you go to the agents they will plug the ECU Scanner to your vehicles ECU Diagnosis socket. From the scanner they will analyst the ECU outputs (the scanner will get and convert errors and information codes which return from the ECU to human readable language). Then every one can see that what are the current problems of the engine and its components. (Plugs, Timing belt, Timing, situation of the sensors, Air inflow, out flow and so on) so technician can fix the errors easily. After fixing defective engine components the technician can rest the ECU. After that the engine works fine.
  5. If your ECU has no problem itself, it will come to default settings. But if your engine components have defects, again it will record to ECU and the ECU work as previous.
  6. There are few way to do manual reset the ECU. Theory is you have to cut off power from the ECU and re plug the power. Anyway to rebuild the ECU programs itself you have to start the engine about 10 minutes until engine comes to working temperature. You shouldn't accelerate the engine until its comes to running temperature.
  7. Nilantha replied to Rastima's topic in NISSAN
    what u mean by ignition noice??? you mean knocking noice? or engine mis?
  8. These vehicles are so far so good. RMV will register this. Only thing is this will register as “ASSEMBLED IN SRI LANKA” Label. These vehicles come under “G7” number plate. May be you all have seen this vehicles on the road. (I have seen few vehicles in Nugegoda and Maharagama area)
  9. Nilantha replied to jaga's topic in TOYOTA
    i will check the price and let you know what is the exact
  10. bit more expencive.
  11. Nilantha replied to jaga's topic in TOYOTA
    try kurunegala,Delkanda and Wijerama used spare parts shops
  12. Nilantha replied to jaga's topic in TOYOTA
    140000 rupees…….. oh crazy……. Only about 50,000/= you have to spend to replace the second hand engine also. There are special chemicals to remove engine sludge. But that can be harmful to engine also. Remember this should have to do by an experience technical guy.
  13. 1- DELL (Dell Inspiron 1525 110,000/=) 2- HP 3- Toshiba 4-ACER Never used - Lenovo
  14. Try US Motors, Hill Street Dehiwala. they had.
  15. http://www.alljapanesecars.com/specsview.p...c=fb14&gn=3
  16. I think if you are able to change the fuel filter it is good. Because of your car mileage is over 120,000. But the cost may be around 8,000- 10,000 but remember to replace with a Genuine filter. Because this EFI system’s fuel filter is special filter than normal petrol filters. The petrol pressure of the EFI System depends on the petrol pump as well as petrol filter. (if your petrol filter not perform well petrol may be blocked. Then EFI petrol pressure will low. Then your car pulling power will low. Also petrol consumption also will high.)
  17. Shell we re-build this using ASP.net???????
  18. whats is your car make and model. is it EFI Model?
  19. try US motors Hill street Dehiwala.
  20. where is the NISSAN?
  21. Nilantha replied to Brian's topic in Electrical problems
    How come TOYOTA bad???
  22. Budu saranai........
  23. I think you have used oil treatment.
  24. Nilantha replied to lasa's topic in TOYOTA
    Try wijerama (Delkanda) cost only around 2000/= try to put Genuin weel cups.
