Everything posted by GKWKK
Toyota Service Manuals - Free Download
Below link also helpfull, Worth trying http://www.toyodiy.com
Corolla Ae91/ee90 Door
Your Opinion is 100% true, I called "Taiyo" & they confirmed me that they have stocks for the requred door. So last froday I went to Mt.lavinia to bring it. But that bugger mistakenly counted lefet hand doors as Right Side ooops Sofar no luck.
Dear Memebers Where I can find reconditioned AE91/EE90 Front Right Side door (Winder/Normal) for my Car? I searched Kurunegala & Delkada/Wijerama area but sofar no luck. Can someone please help me ? Thank you
Auto Technical Data Books-pls Request Yours
Hi Priya Can you please email following mannuals if you have below mannuals please. My email is [email protected] Corolla 1.3 (EE90) 87 - 90 Corolla 1.3 (EE90) 90 - 92
- Dash Board Replacement
This is EE90 4D Sedan
Dear Memebers I'm looking for a dash board for my EE90 car since exsisting one got damaged with mice attacks printed boards /circuits badly damaged.Where Can I buy used dash board, aproximatly how much does it cost? Thank you
Fuel Filter !!!
As per my car mannual they have mentioned it as Part #23300-15010 (VIC FC-146) but I noticed that prevoius owenrs has changed the fuel filter to some other model ( L Shape as per Mech, guy) . THefore Can I I replace original part ( Which connect 02 fuel pipes from top) instead of existing filter? Or Are there L shape filters also in same design. (VIc filter FC-146)? THank you
Corolla 2E Engine 1300Cc
It's carb model, Do you have any idea about price range please?
Dear Members I'm looking for a 2E 1300cc petrol engine for a Corolla car? Any idea about the cost ? Will it be possible to find reasonably good one in Panchikawatta area? Thank you
Solution For Engine Oil Leak In To Sparkplugs
Recently I got my spark plug checked & mechanic said that 02 spark pluges were effected with engine oil leak. Therefore he replaced those 02 plugs with Shorter thread NGK plugs instead loger thread plugs. Will this solve my problem ? or is thre any other issue with this move. If I repair my engine with new rings set How much does it cost, Mechanic told me that only his charge about 14K (Inaddition to that he wanted Gasket set also). Does any one knows a place to find a Carb needle in colombo area (I need a EE90 Carbrator neelde it is not supplied with carbrator repair kit also. ) Thank you
Hard To Start When I Stop The Engine
I have done aprox 600km after buying this car, Air filter is not bad when i checked at the service station 1month ago. No such sudden engine stoping when I take foot from the accelarator. But as I said it's really dificult to start after running few km since last week. Also I've noticed vissible smoke too during these days..
Thanks for all comments Starter Motor is in good condition, This problem crop ups when I resart the vehicle after parking (After 30-40 Min drive). I have no idea about the petrol filter replacement date as I bought this car 7 months ago. Can this be due to worn carbrator needle ? or something I can remember one mechanic adviced me to replace the Carb needle but still i could not find this around panchikawatta area too.
Recently i'm having a problem with my vehicle EE90 (1300 Carb model) it's not starting at all if I stop the vehicle after running few kilometers. Can't start without a push. I got the battery also checked but no issues with that. Also I have noticed that I need to accelarate hard to move the vehicle compared to earlier occasions. Seems to be a engine missfire? What Can I do to fix this issue? Can this be a petrol filter or spark plug issue (But Changed plugs before 2 Months ago.) Thank you
Left Turnning Power Steering/tie Rod Issue
Dear Members I'm having a issue with my vehicle steering rack/Tie rod. Recently I did a wheel allignment, unfortunately I can't turn steering weel as I turn to the right side (Vehicle can turn to right side al most 90' degrees but left turn is onle 45-50 degrees). A mechanic told me that this vehicle is having a steering rack of nissan FB13 so it is not suitable for toyota corolla. What I can do to get this issue sorted. Can this fixed by changing tie rods or Power steering rack? If I change power toyota Corolla EE90 steering rack (reconditioned) How much does it cost? Please advice.
Steering Rack/tie Rod Issue
Seat Belts
I need only front seat belt with holders. As existing pair is dirty & metal parts corroded..
Seat Belts
Dear Members Does anyone know a place to bye a seatblet set arouund colombo area? Also aprreciate if you all can give rough estimate of the cost Thank you
Digital Clock Problem
No. it's only a slight change 01 hour / or 30min..
Digital clock in my car isn't showing the correct time although I set it correctly. When I start the car it get changed.. Is this due to a electrial issue..
Engine Oil Level Drop/burn
I use this vechicle only during week ends that may be the case for the excessive smoke as you all mentioned.but nosign of oil drops on my garage floor so far. Thank you again for your valuable comments.
Yes, it's during the heating period gradually decrease after heating the engine. Although this is old car this got through the emission test also easily. After the vehicle service & oil change engine oil level has't gone down as earlier but I may have see a good mechanic for this issue. Thanks
Thanks .. What do you suspect cause for this issue? Is this need urgent attension or Can I repair later
I have observed little oil level dropring in my EE90 corolla. After 260-290 km I had to refill 250ml engine oil is this unusual? Also there is slight white smoke when engine runs at higher RPM. Is there a connetion with oil burnning please advice..
