CJ5
Everything posted by CJ5
  1. The Montero Sport is available in Germany , in NZ as the Mitsubishi Challenger, in the UK as the Shogun Sport etc etc just to name a few. In the US it was available under that name and then replaced by the Mitsubishi Endeavor. So to say it was made for lower income countries does not hold water. As for the ruggedness just watch a few video clips on youtube and the reviews by people. The Prado is not much of a "tough SUV" than the Pajeros, Monteros, etc and all rank more or less on equal ground. The Defender is in a class of its own though. For comfort, handling and build quality no SUV available in the SL market can match-up to a Merc, Beemer or Jag.
  2. If so then the Ford Everest would remind you of the Ford Ranger double cab. I don't know about the Fords but the Toyota and the Mitsubishi D/Cs have completely different suspensions (at least in the rear) compared to the MS and the Fortuner and the latter are much more comfortable than the D/Cs.
  3. CJ5 replied to YALA's topic in General
    Did you speak to the Jaguar specialist at Moratuwa?????
  4. Thought of the Toyota Fortuner?????
  5. CJ5 replied to racerboy's topic in OTHERS
    WOW!!!!! What luck! The 504 is one of the most comfortable cars I've been in and still remember how the seats virtually wrap you in for the ride. I assume it has the original engine. If so I hope you are not considering any conversion. An uncle of mine has a 8sri car which he got B/N and used as the sec. of a ministry and got it when he went on retirement. Splendid condition and I am eyeing it as he is now on the verge of doing his finals!!!! Is yours the Summit model which the police also had ( late 6 sri- early 7 sri series) or is it the three meter model which were the early 70s models imported used, mainly from the UK? The door upholstery boards would not be much of a problem to replace isn't it??? Most cars of that vintage just had the plain hard board as a base and the vinyl covering with a thin layer of sponge isn't it? There are quite a few places that would do it professionally but that place at Nawala would be the best going on personal experience. You can also contact the peugeot owners club in the UK for assistance and advice. http://www.clubpeugeotuk.org/ Waiting for the photos and wish you all the very best in the restoration!!!!
  6. CJ5 replied to lasa's topic in The Lounge
    Just remove the tyres and run on the rims!!!!!
  7. A look under the bonnet will also reveal the fact. A timing belt is housed in the plastic casing, which is usually black in color and roundish at the top, near the V-belts. The timing chain is housed inside the engine and so there is no plastic cover on the outside near the V-belts, as in a vehicle having a timing belt.
  8. CJ5 replied to lasa's topic in The Lounge
    I am not sure of getting a higher milage but I am sure that there is a very high risk of a blowoutl!!!
  9. In NZ 4 cars is average for a family of 4 ( 2 children 16>) averaging 1:1. So anything more is too many!
  10. Are you sure the Swift has a timing belt and not a timing chain????? The Suzuki Alto (Jap) does not have a timing belt it has a timing chain which does not need periodic replacement. I am not sure if the Swift is the same but reckon it might be so . Check, it may be why there is no mention of a timing belt change in the manual.
  11. As for me, I will NEVER convert a petrol to a diesel for all the reasons mentioned above and even more. Rather I'd buy an original diesel vehicle if I need one.
  12. Thanks guys for your views! As there is nothing visible my mechanic, after speaking to the Walana guys as well, suggested that we take out the rear axle assembly and check the whole thing out from the mounting anchors on the body.
  13. No. Their suspicion was that it was either the "radius arm" or the coil springs which they advised was a mechanics job. My mechanic is yet to check it out. Tyres are the standard 155/12.
  14. Thanks! Yes, when I get back a few feet keeping the car on a level surface the rear wheels can be seen at a slightly negative camber. There is nothing seen to be bent or damaged. One of the hub racers was replaced due to a hum the other was also checked and is ok. The Alto has a rigid axle in the rear with separate coil springs and shocks (not struts) so there are no camber bolts as such and cannot be adjusted. Carcare Wella did the allignments on another vehicle and I found that it was not very good. The owner I hear is quite competent but its the ordinary golayas who now do the job and the owner sits inside his a/c office relaxing!!! There is a place at Walana Panadura which has quite a good reputation for allignments going by the large clientele queing up from 6.30am everyday!!! They use a time tested mechanical method for the allignments and I have had absolutely no complaints about their work.
  15. Dear experts, There is uneven tyre wear on the inner side of both rear tyres on a Jap Alto (H23S, 2004 model), which has a fixed camber. The allignment guys could not find any damage to the suspension as a probable cause. The vehicle has been very carefully used, never overloaded and always run on Colombo roads. The allignment guys said it might be a problem with the "radius arm/s" or it could be that the rear coil spring has lost its tension and gone down a bit resulting in the negative camber and ultimate uneven wear. An opinion from you guys would be helpful to get to the root of the problem.
  16. You got a point there BUT....OP also says.... If it was an issue with the timing wouldn't it have been present through-out???? Just asking
  17. How good is the clutch plate and pressure plate? When you say "trying to accelerate in slow moving traffic" is it that you try to pickup on the 2nd from standstill in slow moving traffic?
  18. iRage, Good posting!
  19. Sylvi, As I see it, on most of your responses to posts of fellow members you make it obvious that you have misunderstood/misconstrued the gist of that post and as a result you respond in an unrelated way, sometimes going way off the topic as well. May be careful reading and comprehending what exactly the post is all about would result in a more rational response in your posts, don't get me wrong but even the grammar and the way you put forward a point is rather confusing at times and that also could be a contributory factor to members marking you down.
  20. Sylvi, Can't you do something about your "Bombay looking Calcutta seeing" responses????????
  21. Sylvi It was not me who marked you down!!
  22. I don't know what process involved the "reconditioning" , but what I know is that there were only two categories of vehicles being imported from Japan, and they were "brand new" or "reconditioned" vehicles (and those terms are still used today). All "reconditioned" vehicles even as far back as 1981 had this Export Inspection Certificate and even the last reconditioned vehicle I bought in 1994 had this certificate, suggesting that reconditioned vehicles did go through some form of examination by an authority prior to being exported from Japan, contrary to what "dpbatagoda" had mentioned that there was "no JAAI or such thing to examine when you buy vehicles". As to what covered the examination of a vehicle to become eligible for the Export Inspection Certificate then and what covers the examination by JAAI now I do not know, but the fact is that vehicles were examined then and even now.
  23. I don't think you are correct there. All recon jap vehicles had some kind of an inspection before being shipped out of Japan. It was the Export (or Expert??) Inspection Certificate usually pasted on the front passenger window. It was a light-blue sticker with some japanese letter (or logo??) in white in the center, and on the reverse the details of the inspection were given in japanese. All recon vehicles that came to SL had this pasted even as far back 1981 when I can remember, and may have been there even before that.
  24. CJ5 replied to Pericles's topic in NISSAN
    I don't know about the performance of the Juke-R but the aesthetics are downright hideous to say the least. The rear looks like Chandrika bending over, and the front has a severe constipated look.
  25. May be the case if you are bigger made than a british guy after all these cars were made for them isn't it???? I am 5'9 and fitted in alright. I've never owned one but used one and it was fun though I should say not as comfy as any of the japs or other new models.
