wbruwan Posted January 9, 2011 Posted January 9, 2011 my car Head Gasket Repair , i need to fix it i search on Internet ,youtube success this solution ? Bar's Leaks "Head Gasket Repair blue devil K-SEAL REPAIR Quote
0 wbruwan Posted January 9, 2011 Author Posted January 9, 2011 (edited) Youtube video Edited January 9, 2011 by wbruwan Quote
0 jdnet Posted January 9, 2011 Posted January 9, 2011 (edited) If your head gasket is gone you need to tear down the engine and replace it. Using these additives is basically asking for trouble. Pretty sure you cant find bar's product here. Unrelated but this should tell you how bad this stuff is. I used the Bar's stuff for radiators when I had a pin hole leak. It seemed to fix the leak for a while but after driving a few miles I noticed that it started leaking again. Yet the coolant level in the resovior did not change at all. So I aded a little more of that crap and and once again it worked until about 200 miles when my radiator just cracked right through the bottom sending all the fluid gushing out. Oh yeah and the coolant bottle was still full. It turned out the stop leak stuff blocked everything the coolant passed through including the hose that feeds the fluid from the reservoir. I basically had to install a new radiator and flush the entire sytem and clean all the hoses. This just goes to show that you are better off doing it the right way. It will save you money in the long run too.... Edited January 9, 2011 by jdnet Quote
0 Pericles Posted January 11, 2011 Posted January 11, 2011 This is for all those people who don't seem to understand what means http://www.urbandictionary.com/define.php?term=rolling%20eyes NOT appropriate to use on someone who helps you! Quote
0 jdnet Posted January 11, 2011 Posted January 11, 2011 This is for all those people who don't seem to understand what means http://www.urbandictionary.com/define.php?term=rolling%20eyes NOT appropriate to use on someone who helps you! Quote
0 Pericles Posted January 11, 2011 Posted January 11, 2011 Predictable. Knew someone was gonna do that. Quote
0 jdnet Posted January 11, 2011 Posted January 11, 2011 Predictable. Knew someone was gonna do that. Quote
wbruwan
blue devil
K-SEAL REPAIR
7 answers to this question
