January 11, 201115 yr I had a 2007 Toyota Vitz 1000 cc car. I want to know what is the recommended way to change transmission oil (manual or using a special machine). My car service agent said that the recommended way is using manual.They said that Toyota corporation recommended that way for vitz, yaris,vios cars. Is it true?
January 13, 201115 yr I change mine also manual. Actually can it be change using machine as water is going through the gear box for cooling?.In normal atf models transmission oil is going through radiator for cooling and atf changing machine connected through that line. I'm not sure about this , but this is the thing what i have observed.
