March 7, 201115 yr Yesterday I did the service @ carmart meantime they did general checkup and told me problem is in the suspension system. and the Cost will be around morethan 100 Thousand. Guys can you please advice me is there any other good place to check the problem again and place where I can buy the spare parts. Finally I have noticed the sound is comming only when putting the reverse gear Whatever you do, DO NOT GET THE WORK DONE AT CARMART ! Their usual approach to problem solving is replace anything that doesn't sound right, without actually investigating what the problem is. If it is actually suspension, they it sounds like it will be a fairly straight forward fix. I assume you have checked all your engine mounts to make sure they are all ok, and the engine is definitely not knocking ... EDit: Sorry, I only realised AFTER I posted this that it was the mount as I myself suspected and Dilan pointed out some time ago Edited March 7, 201115 yr by The Don
