Ek3 Ferio Posted March 14, 2011 Posted March 14, 2011 Hi Guys, It seems a small cracked line in the front side of the top of the radiator and it leaks the water. Did a temporary solution, but it seems not working. It is the original radiator which has the plastic top cover. So guys need agent responses. How I'm gonna fix it? Hope you guys know a better methods and good places to get it done. Thanks a lot. Quote
evergreen Posted March 14, 2011 Posted March 14, 2011 Hi Guys, It seems a small cracked line in the front side of the top of the radiator and it leaks the water. Did a temporary solution, but it seems not working. It is the original radiator which has the plastic top cover. So guys need agent responses. How I'm gonna fix it? Hope you guys know a better methods and good places to get it done. Thanks a lot. you can get the tank redone using copper. but best is to replace the radiator. Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 you can get the tank redone using copper. but best is to replace the radiator. Replacing means with a re-conditioned one? Where I can found them and how I gonna know the quality of it? Quote
Rukster Posted March 14, 2011 Posted March 14, 2011 Hi I suggest the best would be to replace the radiator if its leaking. Considering the age of the car, there is a chance that there would be corrosion in the radiator requiring attentionβi.e. replacement. I am not sure about the price, but good if you can get one. Quote
Rukster Posted March 14, 2011 Posted March 14, 2011 Replacing means with a re-conditioned one? Where I can found them and how I gonna know the quality of it? I would suggest getting it brand new with warranty. Quote
evergreen Posted March 14, 2011 Posted March 14, 2011 Replacing means with a re-conditioned one? Where I can found them and how I gonna know the quality of it? yep. a recondition one. you can find them in delkanda area. US axto dehiwala or few places in kandy. you have to fix and see the functionality. there wont be a guarantee as such but you can always return it if found any leaks. Quote
prasa Posted March 14, 2011 Posted March 14, 2011 Hi Guys, It seems a small cracked line in the front side of the top of the radiator and it leaks the water. Did a temporary solution, but it seems not working. It is the original radiator which has the plastic top cover. So guys need agent responses. How I'm gonna fix it? Hope you guys know a better methods and good places to get it done. Thanks a lot. If the Leak is on top of the radiator. U can replace the upper part (plastic tank) at Lianel Radiators - Panchikawatte. it will cost u around 5000 bucks.... regards Prasa. Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 I would suggest getting it brand new with warranty. This is not possible machan, It costs a lot. Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 If the Leak is on top of the radiator. U can replace the upper part (plastic tank) at Lianel Radiators - Panchikawatte. it will cost u around 5000 bucks.... regards Prasa. Will there be found the exact upper part which matches to the ek3 radiator? Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 yep. a recondition one. you can find them in delkanda area. US axto dehiwala or few places in kandy. you have to fix and see the functionality. there wont be a guarantee as such but you can always return it if found any leaks. Are they doing fixing also? Quote
Elvis_Pil Posted March 14, 2011 Posted March 14, 2011 check the radiator core- if its leaking then you may need to replace the whole unit. If its just the top bottle, then you can just get that replaced- with recon plastic one or a copper one from a radiator place at Panchi. (they'll have the size- so nothing to worry on it) Quote
evergreen Posted March 14, 2011 Posted March 14, 2011 Are they doing fixing also? nope. you will have to get hold on to a garage bass. Quote
prasa Posted March 14, 2011 Posted March 14, 2011 Will there be found the exact upper part which matches to the ek3 radiator? yap... I have done once for my es08 7-8 months back.. found the exact radiator tank from them... now its fine.....no leaks..... Quote
Ripper Posted March 14, 2011 Posted March 14, 2011 places like pioneer motors carry new top tanks and that would be the cheapest option if your core is ok. If the core is not good and fins are damaged etc...you might wanna consider going for a unit from one of those breaker joints around delkanda area. I bought one with the fan assembly for about 8k. Afaik the copper top tank option is not possible if you radiator base is aluminum as it was the case with mine. I'm sure finding either a plastic top tank or a recon radiator shouldn't prove too difficult since the car is a common model Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 yap... I have done once for my es08 7-8 months back.. found the exact radiator tank from them... now its fine.....no leaks..... Thanks for the info mate. Do you have any contact no there? Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 check the radiator core- if its leaking then you may need to replace the whole unit. If its just the top bottle, then you can just get that replaced- with recon plastic one or a copper one from a radiator place at Panchi. (they'll have the size- so nothing to worry on it) Thanks for your reply, but how I'm gonna check the core, I went several radiator joints, all of them trying to promote the newly made copper radiator to be fixed. Quote
Ek3 Ferio Posted March 14, 2011 Author Posted March 14, 2011 places like pioneer motors carry new top tanks and that would be the cheapest option if your core is ok. If the core is not good and fins are damaged etc...you might wanna consider going for a unit from one of those breaker joints around delkanda area. I bought one with the fan assembly for about 8k. Afaik the copper top tank option is not possible if you radiator base is aluminum as it was the case with mine. I'm sure finding either a plastic top tank or a recon radiator shouldn't prove too difficult since the car is a common model Please can you give me the contact no of Pioneer Motors? As I'm not much technical guy, so I'm unable to get the correct one from delkanda area. So I think it is better to go with a radiator guy, but the most places I went a suggesting me to replace the whole radiator with copper. It costs around 20k. So do you know a good place to check the core? Does a normal garage bass can do it? If so please let me know a contact. I thinks a issue is with only the top part as I can see the water leak through it when engine starts. But after the guy who serviced the car applying a glue, now it is not visible, but the sponge which fixed in-front of the radiator gets wet. SO I guess the leaking is going on the same place. Many Thanks, Quote
Pericles Posted March 14, 2011 Posted March 14, 2011 Thanks for your reply, but how I'm gonna check the core, I went several radiator joints, all of them trying to promote the newly made copper radiator to be fixed. Has it occurred to you that might be coz its the best solution? Someone here mentioned that too. Quote
CB3A Posted March 14, 2011 Posted March 14, 2011 (edited) Hi Guys, It seems a small cracked line in the front side of the top of the radiator and it leaks the water. Did a temporary solution, but it seems not working. It is the original radiator which has the plastic top cover. So guys need agent responses. How I'm gonna fix it? Hope you guys know a better methods and good places to get it done. Thanks a lot. Hi, I also had the same kind of issue in my car. The plastic top of the radiator cracked and water leaking (not only one, there were few cracks in that plastic top). A mechanic instructed me to buy some adhesive to try fixing it. I did it my self a few months ago and no problems so far. It is just a half an hour work.... by the way you must not use car for at least 16 hours once you apply that adhesive. The name of the adhesive is "JB Weld"... you can buy that from 'Link enterprises' at Jubilee post, Nugegoda... Price is around Rs. 800+ . Google for the name 'JB weld' you will find lot of references about it. That is an American product and as far as I know... a very good one..... Resistant to 500 degrees Fahrenheit. Take care when you mix them together..... do not touch, always use some kind of tool to mix and apply that on the surface. PS: I am not a salesman trying to sell that product. It really did the work for me and saved me few thousand rupees, so I thought of telling you guys. Hope this helps!!!! (By the way I've been going through the forum since beginning but never signed up until today. ) Edited March 14, 2011 by CB3A Quote
macroxx Posted March 14, 2011 Posted March 14, 2011 Hi, I also had the same kind of issue in my car. The plastic top of the radiator cracked and water leaking (not only one, there were few cracks in that plastic top). A mechanic instructed me to buy some adhesive to try fixing it. I did it my self a few months ago and no problems so far. It is just a half an hour work.... by the way you must not use car for at least 16 hours once you apply that adhesive. The name of the adhesive is "JB Weld"... you can buy that from 'Link enterprises' at Jubilee post, Nugegoda... Price is around Rs. 800+ . Google for the name 'JB weld' you will find lot of references about it. That is an American product and as far as I know... a very good one..... Resistant to 500 degrees Fahrenheit. Take care when you mix them together..... do not touch, always use some kind of tool to mix and apply that on the surface. PS: I am not a salesman trying to sell that product. It really did the work for me and saved me few thousand rupees, so I thought of telling you guys. Hope this helps!!!! (By the way I've been going through the forum since beginning but never signed up until today. ) You are very welcome bro. Quote
prasa Posted March 15, 2011 Posted March 15, 2011 Thanks for the info mate. Do you have any contact no there? C.T Lionel Radiator 0723317954 Quote
Ripper Posted March 15, 2011 Posted March 15, 2011 Hi, I also had the same kind of issue in my car. The plastic top of the radiator cracked and water leaking (not only one, there were few cracks in that plastic top). A mechanic instructed me to buy some adhesive to try fixing it. I did it my self a few months ago and no problems so far. It is just a half an hour work.... by the way you must not use car for at least 16 hours once you apply that adhesive. The name of the adhesive is "JB Weld"... you can buy that from 'Link enterprises' at Jubilee post, Nugegoda... Price is around Rs. 800+ . Google for the name 'JB weld' you will find lot of references about it. That is an American product and as far as I know... a very good one..... Resistant to 500 degrees Fahrenheit. Take care when you mix them together..... do not touch, always use some kind of tool to mix and apply that on the surface. PS: I am not a salesman trying to sell that product. It really did the work for me and saved me few thousand rupees, so I thought of telling you guys. Hope this helps!!!! (By the way I've been going through the forum since beginning but never signed up until today. ) how long has this cold weld held up??? depending on the location of the leak...JB weld or similar epoxies sometimes fail over time... imho...this is not a permanent solution...simply due the the nature of the issue... you wouldn't want a busted radiator when hundreds of miles away from towns Quote
Ripper Posted March 15, 2011 Posted March 15, 2011 Please can you give me the contact no of Pioneer Motors? As I'm not much technical guy, so I'm unable to get the correct one from delkanda area. So I think it is better to go with a radiator guy, but the most places I went a suggesting me to replace the whole radiator with copper. It costs around 20k. So do you know a good place to check the core? Does a normal garage bass can do it? If so please let me know a contact. I thinks a issue is with only the top part as I can see the water leak through it when engine starts. But after the guy who serviced the car applying a glue, now it is not visible, but the sponge which fixed in-front of the radiator gets wet. SO I guess the leaking is going on the same place. Many Thanks, if you'r going to delkanda to buy the radiator...best is to take the old one and go with you cos that makes 100% sure of a proper fit during assembly most radiator repair shops can pressure check the core for possible leaks...one can do a visual inspection and see also if lots of the fins are damaged etc. A pressure check would cost you about 100 bucks... Ironically...the new copper radiators does NOT come with a warranty. which is crazy when you're busting that much of money for it. This was the case for me when i checked from a reputed place in panchi. these guys have top tanks even for some rarer models... worth a check Pioneer Motors 155 & 226 Panchikawatte Rd Colombo 10 Tel : (011)2432168 Quote
CB3A Posted March 15, 2011 Posted March 15, 2011 how long has this cold weld held up??? depending on the location of the leak...JB weld or similar epoxies sometimes fail over time... imho...this is not a permanent solution...simply due the the nature of the issue... you wouldn't want a busted radiator when hundreds of miles away from towns It's been around three months now... and still looks alright... Yes, this may not be a permanent solution... but for me it worked very well.... Quote
Ek3 Ferio Posted March 15, 2011 Author Posted March 15, 2011 (edited) if you'r going to delkanda to buy the radiator...best is to take the old one and go with you cos that makes 100% sure of a proper fit during assembly most radiator repair shops can pressure check the core for possible leaks...one can do a visual inspection and see also if lots of the fins are damaged etc. A pressure check would cost you about 100 bucks... Ironically...the new copper radiators does NOT come with a warranty. which is crazy when you're busting that much of money for it. This was the case for me when i checked from a reputed place in panchi. these guys have top tanks even for some rarer models... worth a check Pioneer Motors 155 & 226 Panchikawatte Rd Colombo 10 Tel : (011)2432168 I contacted them, but they don't have Honda parts. By the way thanks for the help. Edited March 15, 2011 by Ek3 Ferio Quote
