March 16, 201115 yr OP wants cars that are easy to handle. 800s and Altos handle horribly. And they're cumbersome to drive. Yep.. and clutch balancing is gonna be very difficult in these cars. they are no smooth like japs. Edited March 16, 201115 yr by MkX
March 16, 201115 yr imho...a larger vehicle scares away lots of these three wheel and bike buggers... case in point... compared to my car days...there are only a few morons who come close to the truck let alone try to cut across etc... If i had a bull bar installed...i'm pretty sure those few morons too can be taken out of the equation Agree. Also a Loud horn would be helpful too Edited March 16, 201115 yr by kelum_wj
March 16, 201115 yr imho...a larger vehicle scares away lots of these three wheel and bike buggers... case in point... compared to my car days...there are only a few morons who come close to the truck let alone try to cut across etc... If i had a bull bar installed...i'm pretty sure those few morons too can be taken out of the equation Yep something like this would do AFAIK these are banned now in SL isnt it ? Edited March 16, 201115 yr by The Stig
March 16, 201115 yr Personally I think the barrier is mostly psychological than physical. I thin on most vehicles even if you are under 5 feet tall, with a bit of adjustment you should be able to reach the pedals comfortably. The big issue is getting over the psychological barrier that the vehicle is too big. I mean people drive by instinct, and you develop a perceptual understanding of where the ends of the vehicle lie and then use this to govern steering and manoeuvres. In SL we call this knowing the corners of the vehicle and it is aided by our ability to perceive depth (you need stereo vision for this). Sometimes you need a bit of time to get used to it but generally after a while you know instinctly where the edges lie. So a bigger vehicle would not be an insurmountable challenge especially on the road, though things like parking obviously can get a bit tricky. We should not limit ourselves just because we're a bit short second that.....friend of mine, female - around 5' 2", drives a Patrol Y60...no issues
March 16, 201115 yr Don't worry bro. Your wife could drive any car with a cushion. My wife is 4'11" only 3" difference and she drives a Passo and my FD1 with out a cushion.
March 16, 201115 yr Personally I think the barrier is mostly psychological than physical. I thin on most vehicles even if you are under 5 feet tall, with a bit of adjustment you should be able to reach the pedals comfortably. The big issue is getting over the psychological barrier that the vehicle is too big. I mean people drive by instinct, and you develop a perceptual understanding of where the ends of the vehicle lie and then use this to govern steering and manoeuvres. In SL we call this knowing the corners of the vehicle and it is aided by our ability to perceive depth (you need stereo vision for this). Sometimes you need a bit of time to get used to it but generally after a while you know instinctly where the edges lie. So a bigger vehicle would not be an insurmountable challenge especially on the road, though things like parking obviously can get a bit tricky. We should not limit ourselves just because we're a bit short This is so true. it's just a matter of thought. Both my sister and mom are under 5 feet. They drive all our vehicles with no issue, or a cushion for that matter.
March 16, 201115 yr Yep something like this would do AFAIK these are banned now in SL isnt it ? they are supposed to be yes....but most of those smart cab have them and also so many others on an unlucky day i bet you can get pulled over and fined...
March 16, 201115 yr Author Guys, Thanks a lot for valubale responces. Will try swift or Vitz. Demio and vios seems out of my budget. Looking for something in range of 10-16 LKS range. Thanks agin Edited March 16, 201115 yr by lasa
March 16, 201115 yr try the punto..not the newest model but the one before...the missus is only 5ft and she drives that car around with ease.
March 16, 201115 yr they are supposed to be yes....but most of those smart cab have them and also so many others on an unlucky day i bet you can get pulled over and fined... So what about vehicles that came with bull bars as standard ? Going a little out of touch i know but i had to ask
March 17, 201115 yr the wifey drives the 2002 swift.. then again she dirves the b4 as well.. so cant compare there.. but i agree with DON... once u get then hang of it u can drive anyting.. my wife is only 5 feet.. but i belive the swift has the clearest vision. i am talking about the earlier swift not the beetle swift...
March 17, 201115 yr The new alto (the jdm version) should fit perfectly. Japanese are not particulary tall people, so most JDM small cars should fit the bill I remember seeing somewhere in the net, Suzuki marketing this particular model (HA 24) especially for Japanese ladies. Edited March 17, 201115 yr by samishka
March 17, 201115 yr Guys, My wife is not tall(shes's 4'7). Can you guys recommend a good car for her which is easy for her to handle.B'cos she's not that tall its hard for her to paddle and view road from winscreen from most of vehicles(mostly bcos meter section in dash board). Any recommendation guys? Also is there a height requirment when applying for driving license? Iยm recommending Mazda 2 ( demio ).... stylish, 5 star safety & better fuel economy.... Edited March 17, 201115 yr by dillongt
March 17, 201115 yr Compare to swift, Vitz & vio, Mazda Demio is a better build vehicle. All mazdas build on triple H structure ( check you tube for mazda safty ), independent suspension system, vented front disk brakes ( ABS with EBFD ), front and rear stabilizer bars (better handling in corners). lot of stranded options..... test drive all other cars before you test drive mazda demio then test drive mazda 2โฆyou can see a major differenceโฆ.
March 18, 201115 yr Where can we find some performance oriented parts for a DY Mazda2? Also need the engine specs/manual for the Asian region which came with the Jap ZY/ZJ engines but in English, can you help dillongt?
March 18, 201115 yr What do you ppl think about Micro Geely. it is1.3 engine. The price is around 1.4 ml. looks nice competed to Maruti, Alto and Cherry which are in same price tag range. According to them it is Chinese with Volvo techno. But only manual transmission available.
March 18, 201115 yr What do you ppl think about Micro Geely. it is1.3 engine. The price is around 1.4 ml. looks nice competed to Maruti, Alto and Cherry which are in same price tag range. According to them it is Chinese with Volvo techno. But only manual transmission available. If you can't drive manual, not worth exploring it any further, right?
March 18, 201115 yr If you can't drive manual, not worth exploring it any further, right? Did I, Iโm driving manual from the day I start and Iโm one of the person agree that you cannot feel the driving pleasure when you drive auto. Since this topic discussing about a car for a girl, I thought to highlight it . (for any girl who like manual)
March 18, 201115 yr What do you ppl think about Micro Geely. it is1.3 engine. The price is around 1.4 ml. looks nice competed to Maruti, Alto and Cherry which are in same price tag range. According to them it is Chinese with Volvo techno. But only manual transmission available. Yeah its a good car, if you want to die i on one that is http://motortorque.askaprice.com/news/auto-1010/geely-ck-scores-lowest-possible-safety-score.asp @ Rangerover dont you dare accuse me of plagiarism Edited March 18, 201115 yr by The Stig
March 18, 201115 yr Yeah its a good car, if you want to die i on one that is http://motortorque.askaprice.com/news/auto-1010/geely-ck-scores-lowest-possible-safety-score.asp It is a crash test .All vehicles after crash test like that.We saw recently Toyota Allion and corolla 121 accident pictures.So if you want to die in bit expensive way buy Allion or 121.
March 18, 201115 yr It is a crash test .All vehicles after crash test like that.We saw recently Toyota Allion and corolla 121 accident pictures.So if you want to die in bit expensive way buy Allion or 121. Did you even bother click the link? Wake the hell up man!!!
March 18, 201115 yr Did you even bother click the link? Wake the hell up man!!! pointless mate! a retard will always be a retard... sleeping or otherwise! Gotta say there seem to be 3 other idiots who agree with this fool! It is a crash test .All vehicles after crash test like that. according to him...all cars offer same safety in a crash do you need any more proof to see how much of an utter idiotic fool this guy is
March 18, 201115 yr according to him...all cars offer same safety in a crash do you need any more proof to see how much of an utter idiotic fool this guy is let's see whether the old retard can see how passenger compartment is intact in this crash test .. Edited March 18, 201115 yr by harshansenadhir
